V vzhodni Ukrajini internetni promet že teče prek Rusije
15 / 78
TezkoDihanje ::
https://twitter.com/mhmck/status/154151...
Unbearable grief as a man recognizes a loved one killed by Russian shelling in Lysychans'k
The Russians fired "Grad" rockets at civilians collecting drinking water. Eight people were killed and 21 injured in this barbaric attack.
TezkoDihanje ::
Mr.B je izjavil:
Temu se reče, no budala neizobražena, kot večina Covid izobraženih vojakov iz Qanon društva.
Ej bebček. Končano imam 8. stopnjo. A tvoja žena še puca sekrete na Dunaju?
TezkoDihanje je izjavil:
Mr.B je izjavil:
A to si kupil na ERUIDO? :D
TezkoDihanje ::
D3m je izjavil:
Kjut. But no.
Mr.B je izjavil:
Torej je Ukrajincem zmanjkalo raket. Zgleda ne morejo dobiti ruskih raktet, ki so se izkazale za učinkovite, ampak zahodne.?
Da so ruski sistemi PZO prej porazni (sploh ta novi Pantsir) kot pa ne, smo se lahko prepričali 4 leta nazaj. Eno je, ko se tolče ruska tehnika z rusko, drugo pa, ko je vmes zahodna tehnika.
Že zdaj vemo glede na videno iz Ukrajine, da so Rusi ter Sirijci lagali leta 2018 (The Russian military reported Syria's air defences shot down 71 of 103 cruise missiles).
2018 missile strikes against Syria
Allies dispute Russian and Syrian claims of shot-down missiles
"The US armed forces said all missiles hit their intended targets without interference, and according to Lieutenant General Kenneth McKenzie, the Syrian air defences fired 40 intercepting surface-to-air missiles but failed to hit any of the targets. He said most were fired after the last incoming missile had struck its target."
"Similarly, France said none of the twelve missiles it fired appear to have been intercepted, although there were reports that between three and seven French missiles were not fired due to malfunctions."
Zagotovo si hotel nekaj povedati, nekaj full pomembnega, ampak sej bo. Hudo mora biti co copy pastaš vse kar ti pader, brez da preveriš vire, ali kot se reče, pet minut, prede pritisneš pošlji. Sej poznamo tvoje YT prispevke. NA sreča večina takih , ki imajo edino vsebino Rusija in točno to v naslovu, kar zahodnjo tipkarski vojak rabi za moralno potešitev, svojega doprinosa na terenu.
 Samo zate, da boš bolje spal.
Mr.B je izjavil:
  • spremenil: Mr.B ()
D3m je izjavil:
Kjut. But no.
 Ni potrebno  potrjevati da si tele
  • predlagal izbris: shmandi ()
TezkoDihanje ::
Mr.B je izjavil:
Kaj pa zdaj cviliš? A zdaj pa izobrazba ni več pomembna, a? >:D
You are fucked in your head.
TezkoDihanje ::
https://twitter.com/ukraine_map/status/...
USA plans to announce that they will provide the NASAMS Air Defense system to Ukraine RU. NASAMS is the same system used by US to protect the sensitive airspace around the White House and US Capitol in Washington
NASAMS can use AMRAAM that fly at 4 Mach and go as high as 21km
NASAMS system was made by USA and Norway
NASAMS consists of 12 missile launchers each one carrying six AIM-120 AMRAAM missiles and it can fire 54 missiles at different targets within 12 seconds. It can hit targets over 25km away and can use the IRIS-T missile
l0g1t3ch ::
Mr.B je izjavil:
Mr.B je izjavil:
Mr.B je izjavil:
Boomer ma spet memete :)
Kak srčkano :*:*
D3m je izjavil:
Mr.B je izjavil:
Na SGGEŠ.
Hja, so neumni ti americani. Mar bi pobili vse prebivalce in prikljucili ozemlje. 51st state. Ne bi bilo nobenih problemov....
Vidim je Pac-man v damage control na RTVSLO. :D
link_up ::
Se vedno mi ni jasno zakaj Moskva se stoji, ce so Ukrajinci taki zlobnezi? Zakaj tolcejo po svojih mestih in ne po ruskih?
In and Out
D3m je izjavil:
Na RTV je cenzura, ne spustijo vsaj meni niti enega komentarja več. Sploh ne moreš pisat kaj proti Rusiji. V glavnem tam so Rusi dobri, Ukrajinci pa slabi pri moderatorjih. Brezveze naj imajo svojega Putlerja in kapelico! :D
Ter navijajo za svoje idole, Putlerja in Lukašenka ter genija Lavrova in Peskova, to so ti modeli za naslednjih 100 let! :D
Sem šel tam sedaj brat komentarje na RTVSLO, sam svet inteligence. npr. ta komentar:
Če zahod nebi pošiljal orožja, bi se Rusi in Ukrajinci že pogovorili! Ampak potem nebi služili vojni dobičkarji!
Revnih ljudi je vsak dan več, bogati imajo vsa dan več bogastva, srednji razred pa izginja. :(
Pojdite si malo tja pogledat kaj govorijo na javnem mediju in kaj pustijo govoriti in kaj cenzurirajo! :D smešno za zjokat!
Primer Litva, si lahko tak bedak, da to napišeš! Država, ki spuštuje evropske sankcije, da s tem vojno napoved Rusiji, NATO pa je potem ne bo branil! :D Odgovoriti pa ne moreš ker ne spustijo skozi! :D
Se zavedaš, da zaveza o kolektivni obrambi ne velja v primeru, da agresijo sproži država članica NATO? Vsaj tako so povedale ZDA še marca ... in Litva je tista, ki je sprožila agreijo z vojnim dejanjem zoper Rusijo, kot si se strinjal. Člen o obrambi velja v primeru, da članici nekdo napove prvi vojno, ne v primeru, ko članica prva sproži vojno (vojno dejanje je namreč po mednarodnem pravu vojna napoved) in nato dobi to, kar izziva.
Čakamo še na videe, take velike napovedi še skoraj ni imel kdaj. :)
Increased Russian losses over the past day:
> 250 killed
helicopters +1
tanks +15
armoured combat vehicles +17
anti-aircraft warfare systems +1
military vehicles and fuel trucks +14
special equipment +1
artillery systems +7
https://twitter.com/mhmck/status/154174...
D3m je izjavil:
Zadnja dva dneva je po mojih izkušnjah bolje. Skozi pride 80%+ komentarjev.
Vrhunska ruska raketna tehnologija je tovarno zgresila za nekaj 100m in zadela trgovinski center. Druga raketa pa je celo zadela tovarno, pa se to bolj slabo.
Nemske zaloge plina ze napolnjene do 60%. Kje je se zima. Madzarske samo 39%. Bogi Orban. Avstrijske 44%.
vlad, preberi si to:
https://oilprice.com/Energy/Crude-Oil/U...
Če bi zadela trgovinski center ne bi od centra nič ostalo. :)
Je treba počakati na info.
Kot recimo tole....
https://twitter.com/RWApodcast/status/1...
Hoces reci, da so Ukrajinci sami zazgali trgovski center? Kaj tocno je tvoja teorija? Hvala za info!
Vžig zaradi ogorelih ostankov po detonaciji.
Nihce ni slisal eksplozije in pocakali so v trgovinskem centru, da pomrejo. Zanimiva teorija.
D3m je izjavil:
Pa mi ti povej kaj je zadela
https://twitter.com/hallbjorny/status/1...
Industrijski kompleks za trgovskim centrom je nepoškodovan.
Druga raketa je priletela na drugo stran kompleksa, blizu parka.
uporabnik97 ::
Ma ne to jim nacisti niso pustil it ven... :(
D3m je izjavil:
Sem podal link. :)
Tak, da se ne delaj neumnega.
P.S.
Daj še pokaži krater v trgovskem centru, hvala. :D
  • spremenil: D3m ()
sds ::
Se sploh ne bi cudil.
I have no mouth, and I must scream
Nič niso požgali.
Prej zaradi gorečih ostankov, ki so prileteli na trgovski center.
Torej je bil trgovski center edina vnetljiva rec okoli tovarne? Goreci ostanki so leteli samo na trgovski center? Tista hisica na ribniku ocitno ne gori?
Zanimiva teorija. Taka, prirocna.
Meni se zdi najbolj verjetna teorija, da raketa ni natancno zadela cilja. Ampak, to sem jaz.
Če bi zadela trgovski center balistična raketa X-22 bi imel en lep KRATER.
Kako ves, da ga nima?
Saj ti je Paco dal slikico. :)
D3m je izjavil:
Sem podal link. :)
P.S.
@ 0:35 se vidi že goreč trgovski center, nato prileti še ena raketa bližje parku in ga zasuje s šrapnelom
P.S.
Je razlika, če zadane zemljo ali železobetonski temelj. Ni za kaj.
Glava ima 1000 kg eksploziva.
Ne nakladaj o lastnosti železo betona, da vzdrži. :)
Potem pa potrebujemo se en krater. Najdes posnetek? Ali sta 2 eksploziji tudi fake audio?
UkrFTW! ::
D3m je izjavil:
Zajebano je bit človek, ki relativizira življenje v sklop formalnosti in išče izgovore za zločine rusov.
sds je izjavil:
Zajebano je biti človek, ki ne premore niti malo empatije in sposobnosti presoje podatkov.
  • spremenilo: UkrFTW! ()
Zajebano je biti UkrFTW :D
UkrFTW! ::
D3m je izjavil:
Nič niso požgali.
Res je zajebano relativizirati človeška življenja na način, na katera so ljudje preminuli. Verjetno te čaka obračanje v grobu.
D3m je izjavil:
Zajebano je iskati izgovore, kako center ni bil porušen in na kakšen način so ljudje pomrli.
D3m je izjavil:
To je pa lepo slišati. Če bi se strinjal z mano, bi me skrbelo!
D3m je izjavil:
Najbolj so mi seveda smešni ljudje na RTV, ki se zgražajo nad Orbanom, podpirajo pa Putlerja, ampak ne to nikakor tam ne gre skozi! :D
vem, da bi te.
I'll play along.
Sc0ut ::
D3m je izjavil:
Sem podal link. :)
P.S.
P.S.
Otroci so bli v parku, normalen folk. Fuck no, te rusi so gnilobe 21. stoletja. 20. so bili nemci, zdaj pa so rusi popolnoma prevzeli primat.
Sc0ut je izjavil:
D3m je izjavil:
Sem podal link. :)
P.S.
P.S.
Lahko bi izstrelili rakete ponoči,ko ni ljudi na ulici. Kot,da bi namerno pobijali civile.
UkrFTW! ::
Sc0ut je izjavil:
+1
Brez vsakega dvoma.
Sc0ut ::
Pol pa se najde spet nas rusofil ki bi se se kar pogovarjal z rusi. Z rusi se ne pogovarjas, razumejo samo ustrahovanje.
https://www.24ur.com/novice/tujina/nato...
D3m je izjavil:
Ja ja sigurno! :D Idi pa zakuri tako na hitro trgovski center z ogorelimi ostanki... :D
To ni vžigalica, kot si predstavljaš. =)
TezkoDihanje ::
D3m je izjavil:
1. X-22 ni balistična raketa ampak cruise missile (leti kot letalo)
2. ena tona eksploziva ni veliko
3. eksplodirala je na ostrešju okoli 15 metrov visoko
Tako da ne, nobenega kraterja ne more bit. Bedarija na kvadrat.
D3m je izjavil:
Saj sem podal link. :)
Vidim enega. Ne dveh.
Mr.B je izjavil:
 Hvala poroöevalec.  Novice iz ukrajine imamo polno in to kvalitetne, naprav tvojim virom.
 Idealno , V ukrajini kejr so za ruse problematični rel tim podatki, jim potsaviü tako stacionarno tarčo.
TezkoDihanje ::
https://twitter.com/bellingcat/status/1...
New June 28th high resolution satellite imagery from
@Planet shows the destroyed #Kremenchug shopping mall, damage to the factory complex, and no damage to the train station, highlighted in this claim from the Russian Embassy.
15 / 78
Rusija čedalje bolj izolirana od interneta in elektronskih plačilnih storitev (strani: 1 2 3 4 5 6 )
27182767 (50525) Mr.B
Londonsko vozlišče prenehalo izmenjevati promet z ruskimi operaterji
2911479 (8958) jotunn2
Nedeljski izpad CenturyLinka promet po internetu oklestil za 3,5 odstotka
65547 (4909) SmeskoSnezak
Rusija se bo poizkusno odklopila od interneta
3014106 (10084) Mare2
Veliki Brat na internetu: tudi v Sloveniji (strani: 1 2 )
Oddelek: Novice / Zasebnost
8814745 (14745) GBX
