Noče brisat!?!?
Noče brisat!?!?
YuGo ::
Pri več katerem filmu, ki ga iz neta potegnem, mo potem ko ga želim izbrisat napiše, da ga ne gre izbrisat in da naj poskrbim, da datoteka zaščiteno oz. je ne bo uporabljal kater drug program...lahko izbrišem, če grem pod save mode in v "DOS" vendar se mi prostor na disku ne sprosti...
kaj naredit?
hvala
LP!
ali3n ::
Zbrisat verjetno ne moreš zato, ker ga nekdo tist trenutek vleče od tebe - prek p2p programov.
Izklopi ta program, pa briši...
- "Rozi vidm." "S psom!"
YuGo ::
nimam vkloploplenega p2p programa, saj v tem je ravno hec...
Nutcracker ::
Tole sem enkrat našel na Annoyances.org; preverjeno deluje
The fix for Windows XP not letting you delete .avi I've seen this coming
> up more and more all over the place so I figured I'd stick it here. Avi
> files (divx) can be trouble in xp. there is a fix to let xp behave much
> better so it's possible to move or delete large avi files. The obnoxious
> bug in XP that causes Explorer to read the entire contents of broken AVI
> files before allowing any access to them is caused by bad behavior of
> shmedia.dll. To correct this misbehavior in Windows XP, remove the
> following registry key.
> HKEY_LOCAL_MACHINESOFTWAREClassesCLSID{87D62D94-71B3-4b9a-9489-5FE6850DC73
> E}InProcServer32 This will prevent Explorer from loading shmedia.dll in
> response to file property queries on these files. Just an extra note, if
> you do a "search" for this key it will not be found, look for it manually
> it is very easy to find. As always newbie or not, if you FUBAR your
> registry its your own fault. This fix does work, I use it and have applied
> it to many XP machines.
YuGo ::
Najlepša hvala, zadeva deluje...
Pri pregledu vsebine map se Explorer sesuje?
Oddelek: Operacijski sistemi
71749 (1679) jackorsen88
Ne da se zbrisat filma
121827 (1614) andper
Datoteke ne gre izbrisat
101376 (1267) Zdravko
Ne gre mi zbrisat avi file!
71469 (1359) david
Windows XP in AVI datoteke
184022 (4022) AtaStrumf
