Forum » Pomoč in nasveti » Noče brisat!?!?
Noče brisat!?!?
YuGo ::
Pri več katerem filmu, ki ga iz neta potegnem, mo potem ko ga želim izbrisat napiše, da ga ne gre izbrisat in da naj poskrbim, da datoteka zaščiteno oz. je ne bo uporabljal kater drug program...lahko izbrišem, če grem pod save mode in v "DOS" vendar se mi prostor na disku ne sprosti...
kaj naredit?
hvala
LP!
kaj naredit?
hvala
LP!
ali3n ::
Zbrisat verjetno ne moreš zato, ker ga nekdo tist trenutek vleče od tebe - prek p2p programov.
Izklopi ta program, pa briši...
- "Rozi vidm." "S psom!"
Nutcracker ::
Tole sem enkrat našel na Annoyances.org; preverjeno deluje
The fix for Windows XP not letting you delete .avi I've seen this coming
> up more and more all over the place so I figured I'd stick it here. Avi
> files (divx) can be trouble in xp. there is a fix to let xp behave much
> better so it's possible to move or delete large avi files. The obnoxious
> bug in XP that causes Explorer to read the entire contents of broken AVI
> files before allowing any access to them is caused by bad behavior of
> shmedia.dll. To correct this misbehavior in Windows XP, remove the
> following registry key.
> HKEY_LOCAL_MACHINESOFTWAREClassesCLSID{87D62D94-71B3-4b9a-9489-5FE6850DC73
> E}InProcServer32 This will prevent Explorer from loading shmedia.dll in
> response to file property queries on these files. Just an extra note, if
> you do a "search" for this key it will not be found, look for it manually
> it is very easy to find. As always newbie or not, if you FUBAR your
> registry its your own fault. This fix does work, I use it and have applied
> it to many XP machines.
| » | Pri pregledu vsebine map se Explorer sesuje?Oddelek: Operacijski sistemi | 1749 (1679) | jackorsen88 |
| » | Ne da se zbrisat filmaOddelek: Pomoč in nasveti | 1827 (1614) | andper |
| » | Datoteke ne gre izbrisatOddelek: Pomoč in nasveti | 1376 (1267) | Zdravko |
| » | Ne gre mi zbrisat avi file!Oddelek: Pomoč in nasveti | 1469 (1359) | david |
| » | Windows XP in AVI datotekeOddelek: Novice / Operacijski sistemi | 4022 (4022) | AtaStrumf |
