Forum » Programiranje » CSV file
CSV file
zero22 ::
Pozdravljeni!
Dobil sem CSV file za katerega moram spisat skripto, ki kot input vzame podatke CSV datoteke,
CSV prebere in obdela tako, da dobimo kot rezultat listo dictionerjev - ki bo zgledal nekako tako:
"Username" : "booker12",
"Identifier" : "9012",
"One-time password" : "12se74"
"Recovery code" :"rb9012" ,
"First name" : "Rachel",
"Last name" : "Booker",
"Department" : "Sales",
"Location" : "Manchester"
https://files.fm/u/4u98vzgmt#/ (csv file sem uploadal)
Tole je največ kar mi uspe naredit, več mi ne rata, zelo bi prosil za pomoč.
with open('username-password-recovery-code.csv', 'r') as my_file:
data = my_file.read()
rows = data.split("\n")
for row in rows:
info = row.split(",")
print(type(info),info)
for row in rows:
HotBurek ::
CSV file ni dostopen, vsaj meni ne. Neki login na slack sprašuje...
Ali lahko objaviš sample 10 vrstic iz CSV-ja kar tule gor (lahko ga daš znotraj "Vstavi kodo", da bo izgledalo kul)?
root@debian:/# iptraf-ng
Please resize your window
zero22 ::
Username; Identifier;One-time password;Recovery code;First name;Last name;Department;Location
booker12;9012;12se74;rb9012;Rachel;Booker;Sales;Manchester
grey07;2070;04ap67;lg2070;Laura;Grey;Depot;London
johnson81;4081;30no86;cj4081;Craig;Johnson;Depot;London
jenkins46;9346;14ju73;mj9346;Mary;Jenkins;Engineering;Manchester
smith79;5079;09ja61;js5079;Jamie;Smith;Engineering;Manchester
Al pa če copy-paste naredm v .txt file pa uploadam?
- spremenilo: zero22 ()
HotBurek ::
#!/usr/bin/python3.9
# init empty list
list = [];
# source csv file
csv = "";
csv = csv + "booker12;9012;12se74;rb9012;Rachel;Booker;Sales;Manchester" + "\n";
csv = csv + "grey07;2070;04ap67;lg2070;Laura;Grey;Depot;London" + "\n";
csv = csv + "johnson81;4081;30no86;cj4081;Craig;Johnson;Depot;London" + "\n";
csv = csv + "jenkins46;9346;14ju73;mj9346;Mary;Jenkins;Engineering;Manchester" + "\n";
csv = csv + "smith79;5079;09ja61;js5079;Jamie;Smith;Engineering;Manchester" + "\n";
# split file into rows
rows = csv.split("\n");
# go for each row
for row in rows:
# split row into columns
columns = row.split(";");
# init new empty dictionary
dictionary = {};
# go for each column
for i in range(0, len(columns)):
# write each column into dictionary
if i == 0:
dictionary["Username"] = columns[i];
elif i == 1:
dictionary["Identifier"] = columns[i];
elif i == 2:
dictionary["One-time password"] = columns[i];
elif i == 3:
dictionary["Recovery code"] = columns[i];
elif i == 4:
dictionary["First name"] = columns[i];
elif i == 5:
dictionary["Last name"] = columns[i];
elif i == 6:
dictionary["Department"] = columns[i];
elif i == 7:
dictionary["Location"] = columns[i];
# append dictionary to list
list.append(dictionary)
# print
print(list);
- spremenilo: HotBurek ()
HotBurek ::
Zgornjega posta ne morem več popravit. Tole je nekak finalna verzija:
# import
import os;
# init empty list
list = [];
# init empty csv file
csv = "";
# read csv from file
if os.path.exists("username-password-recovery-code.csv"):
file = open("username-password-recovery-code.csv", "r");
csv = file.read();
file.close();
# go for each row
for i in range(0, len(rows)):
# skip first line, it is header
if i > 0:
columns = rows[i].split(";");
dictionary = {};
for j in range(0, len(columns)):
if j == 0:
dictionary["Username"] = columns[j];
elif j == 1:
dictionary["Identifier"] = columns[j];
elif j == 2:
dictionary["One-time password"] = columns[j];
elif j == 3:
dictionary["Recovery code"] = columns[j];
elif j == 4:
dictionary["First name"] = columns[j];
elif j == 5:
dictionary["Last name"] = columns[j];
elif j == 6:
dictionary["Department"] = columns[j];
elif j == 7:
dictionary["Location"] = columns[j];
# print
print(list);
HotBurek ::
Dokumentacija:
https://stackoverflow.com/questions/322...
Rešitev:
Rešitev:
# import
import os;
import json;
# init empty list
list = [];
# init empty csv
csv = "";
# init file path
filepath = "username-password-recovery-code.csv";
if os.path.exists(filepath):
file = open(filepath, "r");
csv = file.read();
file.close();
else:
print("Warning: file does not exits.");
print("Path: " + filepath);
# go for each row
if i > 0:
dictionary = {};
if j == 0:
elif j == 1:
elif j == 2:
elif j == 3:
elif j == 4:
elif j == 5:
elif j == 6:
elif j == 7:
# print
print(json.dumps(list, indent=4));
zero22 ::
Super. Deluje. Dolžn sm ti za pivo.
Hodim na tečaje smartninja če si že slišal. Pa nevem slabo uči. Ful hitr gremo čez snov. In sem čist
zgubljen, maš mogoče kak nasvet al napotek kje bi se še lahka kar se da naučil vsaj teh osnov tolko da razumem
ta koncept programiranja. Imam zakupljen tudi course na udemy. Ženska res fajn razlaga nimam kej rečt. Sam me
zanima če se še kje v Sloveniji izvaja kak tečaj. Ker kolkr so hvalil smartninja žal niso nevem kaj.
kunigunda ::
Tole zgoraj verjetno deluje samo, ce ni ; v samem stringu.
a;b;"something;and this";last
tony1 ::
Priporočam Courserin tečaj Google Crash course on Python, ki pa je, če se ne motim, prav tako plačljiv.
Če te zanimajo knjige pa priporočam karkoli za Python začetnike avtorja Ala Swigarta iz založbe No startch press. Nekaj njegovih knjig se da dobiti zastonj na njegovi spletni strani https://inventwithpython.com/hacking/
- spremenil: tony1 ()
HotBurek ::
Zagotovo je tako. Če ne drugega, bi prišlo vsaj do napak oz. zamika. In kako bi to (elegantno) rešil?
Python je sel naprej od verzije 3.9 in podpira tudi switch statement ...
Imam Debian in to je najnovejša verzija, ker je tu gor. Kaj "switch" omogoča oz. izboljša napram uporabi "if/elif/elif"?
Tisti del bi se dalo sicer rešit tudi bolj "na trdo", ob predpostavki, da je v vsaki vrstici vsaj 8 podatkov.
Primer:
dictionary = {};
# fill up dictionary
dictionary["Username"] = columns[0];
dictionary["Identifier"] = columns[1];
dictionary["One-time password"] = columns[2];
dictionary["Recovery code"] = columns[3];
dictionary["First name"] = columns[4];
dictionary["Last name"] = columns[5];
dictionary["Department"] = columns[6];
dictionary["Location"] = columns[7];
list.append(dictionary) root@debian:/# iptraf-ng
kuall ::
kako le? ko najdeš " rečeš weAreInString = !weAreInString
pol moraš pa še na to računat, da je lahko " v stringu:
if weAreInString and curChar = '"' and prevChar != '"'
weAreInString = false
kunigunda ::
Nardis si nek simpl tokenizer, ce ze ne obstaja v jeziku (al pa regex).
Ce ta python podpira regex v split lohk das npr
csv.split(";(?=(?:(?:[^\"]*+\"){2})*+[^\"]*+$)")
- spremenilo: kunigunda ()
zero22 ::
Ko smo imeli html pa css in bootstrap je bilo zanimivo oziroma končno sem začel dojemat kako in kaj in potem
smo že šli na pyhton. Evo tu se je pa men ustavilo, nikakor nevem kako bi se učil da bi razumel, ali je res
programiranje zgolj ta tiste ko jim je vse samoumnevno.
HotBurek ::
Sem poizkušal z regex, pa ni šlo po načrtih. Najde celoten line, ampak ga ne split-ta.
Če ima kdo rešitev, kar pogumno.
Spodaj sample:
Output:
Spodaj sample:
import re;
input = "a;b;\"something;and this\";last ";
# sample 1
print("sample 1 **************************************************");
matches = re.split(";(?=(?:(?:[^\"]*\+\"){2})*\+[^\"]*\+$)", input);
print("len=" + str(len(matches)));
for i in range(0 ,len(matches)):
print(matches[i]);
# sample 2
print("sample 2 **************************************************");
reiter = re.finditer(";(?=(?:(?:[^\"]*\+\"){2})*\+[^\"]*\+$)", input);
for iter in reiter:
print("aaa");
item = input[iter.start(), iter.end()];
print(item);
# sample 3
print("sample 3 **************************************************");
reall = re.findall(";(?=(?:(?:[^\"]*\+\"){2})*\+[^\"]*\+$)", input);
print("len=" + str(len(reall)));
for i in range(0 ,len(reall)):
print(reall[i]);
Output:
sample 1 ************************************************** len=1 a;b;"something;and this";last sample 2 ************************************************** sample 3 ************************************************** len=0
Ahim ::
Kako naj bi pa to sploh delovalo? Patterm mora ustrezati enemu stolpcu.
Namesto tega zongliranja eksplodiraj input string s podpicjem kot delimiterjem, nato pa zlepi skupaj elemente od (vkljucno) prvega, ki se zacne z ", do (vkljucno) tistega naslednjega, ki se konca z ", za vsako pojavo " na zacetku elementa.
https://www.w3schools.com/python/ref_st...
kunigunda ::
Spodaj sample:
import re;
# sample 1
print(matches[i]);
# sample 2
for iter in reiter:
print("aaa");
print(item);
# sample 3
print(reall[i]);
Output:
len=1
len=0
Zgleda da mal drugac regex interpetira kot drugi jeziki.
Probi tkole:
matches = re.findall(r'"[^"]*"|\'[^\']*\'|[^"\';]+',input)
HotBurek ::
Ja, to pa deluje.
Sample:
Output:
Sample:
import re;
input = "a;b;\"something;and this\";last";
regex = '"[^"]*"|\'[^\']*\'|[^"\';]+';
reall = re.findall(regex, input);
print("item(" + str(i) + ")=" + reall[i]);Output:
len=4 item(0)=a item(1)=b item(2)="something;and this" item(3)=last
bemfa ::
Predno diplomirate:
import csv
import json
csvfile = open('file.csv', 'r')
jsonfile = open('file.json', 'w')
fieldnames = ("Username","Identifier","One-time password","Recovery code","First name","Last name","Department","Location")
reader = csv.DictReader( csvfile, fieldnames)
for row in reader:
json.dump(row, jsonfile)
jsonfile.write('\n')
kunigunda ::
Hvala za pomoc. Jaz pythona ne poznam niti ne vem kaj vse ze ima built-in, zato so bli tud nasveti temu primerni :)
HotBurek ::
V katerem programskem jeziku (ali več njih) pa programiraš, da ti je uspelo zaobit Python?
kunigunda ::
Sej jeziki so si dost podobni vids pa dobis filing ostalo se pa sprot naucis k zacnes delat v posameznem. Pythona sicer ne maram ker mi je osebno grd tko k mi ni kitajscina lepa pa jo miljardo plus govori :)
HotBurek ::
Sej Python omogoča uporabo podpičja na koncu vsakega ukaza, tako da izgleda vsaj half decent.
Je pa res, da se ne da uporabljat curly brackets na tak način, kot to gre pri nrp. JavaScript.
kunigunda ::
Jp, kle so sli mal nazaj. Tale indent blokov me zlo spominja se na cajte Cobola cist na zacetku. Pac stvar navade.
Ga pa zlo po solah forsirajo vidm.
| » | python regex splitOddelek: Programiranje | 814 (719) | HotBurek |
| » | (Java) Iskanje manjkajoči podatkov v tabeliOddelek: Programiranje | 1467 (1232) | noraguta |
| » | Python - pomoč (strani: 1 2 3 )Oddelek: Programiranje | 21087 (11835) | black ice |
| » | Naloga iz Putka - UPMOddelek: Programiranje | 2692 (2028) | NejcSSD |
| ⊘ | python pomočOddelek: Programiranje | 3950 (2871) | Mavrik |
