Predlog za odvetnika v zvezi s copyright infringment
embi ::
Živjo,
Torej (brez moraliziranja, prosim):
1) Dne x.4.2021 Downloadam s spletne strani dotičnega podjetja v ZDA določen software (direkten link (do iso na spletni strani dotičnega podjetja) našel na netu, verjetno ne do eval, ampak full verzije).
2) Instaliram
3) Keygen (Ja, ok, vem)
4) Ugotovim da to ni to, kar rabimo
5) x+14 dni dobimo v službo mail podjetja iz ZDA $$$
6) x+14 dni odinstaliram
EULA med drugim pravi:
22. EVALUATION LICENSE. Licensor is the owner and provider of certain proprietary software and documentation that Licensee desires to have tested and evaluated on the terms and conditions of this Section 22("Software"). For a term not to exceed fourteen (14) days ("Evaluation Period") without Licensor's written authorization, the Software will be provided solely for evaluation purposes for Licensee's own internal use ("Evaluation") and Licensee is hereby granted a nontransferable, nonexclusive, limited license to operate and use the Software for such Evaluation. The Evaluation Period begins on the date Licensee downloads or unseals the Software. At the end of the Evaluation Period, Licensee shall cease using and shall remove the Software from its systems. This requirement applies to copies of the Software in all forms (partial and complete) on all types of media and computer memory and whether or not merged into other materials. Licensee agrees not to cause or permit the reverse engineering, disassembly, modification, translation or decompilation of the Software. Licensee shall not copy the Software, or write or develop any derivative software. Licensee shall not release the results of any Evaluation testing or other performance results of the Software conducted under this Section 22 to any third party without Licensor's prior written consent for each such release.
Če pozna kdo kakšnega (dobrega) odvetnika, ki bi seveda za solde, svetoval kako naprej
Hvala.
Embi
mirator ::
Ko sem jaz rabil odvetnika, sem se povezal z https://www.iurall.com/. Z njihovo storitvijo sem bil več kot zadovoljen. Pa da ne bo to kot reklama, so tudi druge podobne firme, jaz sem pač prišel do odvetnika preko njih.
VaeVictis ::
Poskušaj še tukaj nasloviti vprašanje, ziher ti bodo pomagali, če ne ti pa bodo svetovali in te napotili v pravo smer.
PravnaPomoc-Zaposleni.si
Let's Go Brandon!
Slo-tech.com je postal greznica in izguba časa!
Adijo!
Furbo ::
Kako pa vedo kdo si?
embi ::
iso downloadan z njhovega serverja, verjetno je installer tudi spyware.
Furbo je izjavil:
Firma static ip / ime službenega pcja ?
Aja, outbound fw ni uporabljal, ko je program 'klical domov'.
Če si moral uporabiti keygen, potem je bolj probna verzija kot cela.
Daš link na zs, bom testiral v virtualki.
  • spremenilo: sbawe64 ()
Furbo ::
Verjetno morajo biti ti podatki pridobljeni zakonito..
Evolve ::
Furbo je izjavil:
a tako zakonito kot je on spiratiziral zadevo? ne sanjaj
Furbo ::
Irelevantno.
embi je izjavil:
Tak software komunicira z domačo bazo, ker tako sledijo legalnim in nelegalnim kopijam...
Nič novega...
bluefish ::
Evolve je izjavil:
Da, zakonito.
Primer "Balkanski bojevnik" je bila odlična javna lekcija, ki upajmo ne potrebuje dodatne razlage.
Ziga Dolhar ::
bluefish je izjavil:
Evolve je izjavil:
Da, zakonito.
Ampak nima veze.
https://dolhar.si/
Kako naprej? Razumeš kitajsko? Ne. Tudi angleškega pravnega jezika ti ni treba.
Ko boš dobil SLO dopis, pa lahko naprej razmišljaš.
Smurf ::
Ponavadi se da pogoditi tako, da kupis to licenco.
UganiKdo ::
Evolve je izjavil:
Da, zakonito.
Mesas civilno in kazensko pravo. Niso enaki standardi.
Barakuda1 ::
Na kratko.
Dokler ne dobiš uradnega dopisa od nekoga iz Slovenije, v katerem bo jasno zapisanao kaj sploh hočejo in zakaj, pozabi na vse skupaj.
Ko pa boš (če sploh boš) tak dopis prejel, takrat pa razmišljaj o pomoči s strani kakšne odvetniške pisarne. Takrat tudi ne odlašaj, pač pa si pomoč poišči čimprej.
Ti pa odsvetujem, da iščeš pravno pomoč preko nekih spletnih (odvetniških - pravnih) strani, neglede na to, kako dopadljivo in prepričljivo so takšne spletne strani narejene.
Preden se razburiš pomisli, če ne gre morda za sarkazem
  • spremenilo: Barakuda1 ()
Lahko narediš po slovensko (glavo v pesek) in čakaš kaj bo.
Lahko pa napišeš en dopis, opišeš situacijo in basta. V končni fazi se lahko celo zlažeš, da to ni bil tvoj IP naslov, da si našel nekoga v firmi in ga kaznoval, itn.. in je to to... predvsem ne pozabi napisati, da programa NE uporabljaš in da te dopis čudi.
Saj nisi v postopku pred sodiščem, da ne smeš lagati...
mahoni ::
Si dobil mail? Ne.
Se kaj?
Tu je bil nesramen podpis, ki mi je prislužil naziv, ampak mi dol visi za tem.
Ales ::
Invictus je izjavil:
Da te ne bo slučajno kak revež še poslušal in se zajebal.
joze67 ::
embi je izjavil:
22. EVALUATION LICENSE. Licensor is the owner and provider of certain proprietary software and documentation that Licensee desires to have tested and evaluated on the terms and conditions of this Section 22("Software"). For a term not to exceed fourteen (14) days ("Evaluation Period") without Licensor's written authorization, ...
Ti očitajo uporabo keygena, ali enostavno štejejo, da si uporabljal sw 15. dan in se s tem strinjal z nakupom? Ker od tega je odvisno, kakšnega odvetnika iščeš.
Ziga Dolhar ::
Ales je izjavil:
+1.
https://dolhar.si/
embi ::
Zaključek zgodbe, na kratko: not great, not terrible.
Poiskali nasvet odvetnika (@mirator hvala za nasvet, priporočam). Odgovorili na email, se posipali s pepelom. Na koncu se zmenili, da kupimo ne ravno enterprise, ne pa tudi personal edition licence za dotični software. Za rep ujeli tudi še nek akcijski kupon.
Tako da je strošek sprejemljiv, vsaka šola pa tudi nekaj stane.
Hvala tudi vsem ostalim za bolj ali manj pametne predloge.
Vaš embi.
Naredili ste kar so hoteli, prestrašili ste se in kupili licenco. Če jim ne bi odgovorili, se bi pa zgodilo nič.
No, če ste program želeli uporabljat, vse OK.
embi ::
Je šlo za "malo" dražji program kot WinZip, tako da nisem čisto prepričan v alternativen potek dogodkov (če bi ignorirali). Ker smo ga kupili, ga bomo seveda tudi uporabljali.
Gagatronix ::
Jah usrackali ste se. Kot je bilo ze veckrat povedano, dokler ne pride pravni dopis v SLOVENSCINI iz SLOVENIJE, je vse ostalo natepavanje crknjenega konja oziroma iskanje tocno takih kot ste vi.
Lepo ste se pustili ostric.
OP, malo povej koliko drugače stanejo licence pa koliko ste placali za njih in koliko je šlo za odvetniške storitve.
mahoni ::
Ne samo usrackali, se zasvicali so - full.
Ne vem, zakaj očitki. Ljudje plačujejo tudi za prometne prekrške iz tujine.
Mirna vest pa tudi nekaj stane.
V tem primeru je dejansko šlo za situacijo, ko je ponudnik SW-ja imel konkretne podatke o kršitelju in bi lahko zadeva eskalirala.
Če h končni situaciji prišteješ še morebitne sodne in pravne stroške, se je kar dobro izteklo.
Smurf ::
embi je izjavil:
Vaš embi.
Realni zakljucek. Vsi, ki fantazirajo o tem, da problem izgine, ce zapres oci, fantazirajo.
Eni tu očitno mislijo da je najdražji sw na svetu windows za 200 eur. V resnih nebalkanskih firmah gre lahko že za par ljudi strošek v več 10k eur, in potem še letno nekaj k eur na licenco. In niso to nobeni izvenserijski laboratorijski programi. Ko pa je to še vezano na stroje, pa je še ekstra veselica.
  • spremenil: Machete ()
mahoni ::
Vseeno dopis je v anglescini bil in bi ga lahko odpikal, ker ga ni razumel.
EULA je pa razumel v angleščini? :)
KraitPay ::
Mi smo prvič od Solidworksa dobili od enega Italjanskega podjetja, v strokovni slovenščini. Na sodišče si nismo upali in smo se na koncu pogodili za licence.
bluefish ::
Postopek na sodišču je ravno za Solidworks ne tako dolgo nazaj fasala ena firma s štajerskega konca - tožba za znesek 500k. Domnevam, da so se prav tako pogodili - razpisan en narok, drug preklican.
  • spremenil: bluefish ()
Ampak najbrž je zgolj kak % situacij kjer gredo v tožbo. In najbrž je več emailov in nato dopisi po pošti. Skratka direkt na prvi email reagirat je malo prehitro.
mahoni je izjavil:
Če pšosluješ v mama svetu, si to lahko privoščiš.
Če posluješ mednarodno, je to malo težje...
UganiKdo ::
Lonsarg je izjavil:
Problem je ker se tukaj meša fizične in pravne osebe. Ja tožbe zoper janeza, ki download par filmov so neumnost. V corporate svetu pa je druga pesem.
Stanje CAD licenc pri nas (strani: 1 2 3 )
Oddelek: Programska oprema
10426422 (19019) vres.ales
Potekli patenti za MPEG-2
Oddelek: Novice / Industrijska lastnina
2410703 (8432) AndrejO
Kje dobiti AutoCAD 2000-2008?? (strani: 1 2 )
9122322 (20662) strojix
Legalno ali nelegalno?
132411 (1709) poweroff
SUSE 8.1
Oddelek: Operacijski sistemi
472515 (2084) shock
