Jutri se grem cepit
Jutri se grem cepit
vostok_1 ::
Fantje, s tem novim info sem še bolj prepričan, da se morate cepit.
Čimprej v čimvečjih dozah in čimveč različicah cepiv.
Prosim vas, gre za dobrobit...družbe!
There will be chutes!
It came from the lab.
Kumbaja ::
vostok_1 je izjavil:
@gus5
So, the next time someone claims these "vaccines" do not alter the human genome or DNA, you can refer that individual to Tal Zaks of Moderna, Inc. who claims otherwise.
Samo za nepismene teoretike zarot. Kje v tem članku piše da katero koli od MRNA cepiv, ki so v uporabi spreminja DNK? To, da je vsake dva odstgavka blodenj porinejo noter en nepovezan citat samo kaže na nizek intelektualni doseg, ki ga imate odjemalci teh vsebin.
  • spremenilo: Kumbaja ()
zztop ::
@gus5
Bo potreben link do izjave, da vidimo kaj misli pod "alter the human genome or DNA".
vostok_1 ::
At about the 4:00 minute mark, Zaks begins discussing mRNA vaccines for cancer. Immediately following that, Zaks discusses a children's condition where a gene or "code" is missing that causes production of a certain enzyme critical for metabolism where the current treatment is to transplant an entire organ - in this case, the liver. Zaks proposes to inject mRNA that codes for the missing gene, a gene contained in DNA on the human genome, it would "correct" the genetic defect.
Out of the words of Tal Zaks of Moderna, mRNA can alter the human genome. Whether by design or "unintended consequences", this technology is being used to do just that.
Kumbaja ::
zztop je izjavil:
@gus5
je celoten tedx na voljo https://www.ted.com/talks/tal_zaks_the_...
Brez pompoznih medklicev fanatikov kot je vostok, je zadeva precej bolj znanstvena in bistveno manj senzacionalistična.
Vostok ima pač težave z razumevanjem tega kaj je teoretično možno, kaj se dejansko dogaja in kako si sam zavezat čevlje.
vostok_1 ::
Tako je.
Zato se morate čimprej cepit. Prosim vas!
Human existance is on the brink of extinction, če ne naredimo nič za covid-19!
sharp126325 ::
Dobra zadeva ta mrna tehnika za nesmrtnost elite in pa zelo slaba za rajo.Ampak to je spet območje teorij zarote, tako da se ni treba bati cepljenja.
carota ::
kuglvinkl je izjavil:
carota je izjavil:
The Washington standard:
Bombshell: Moderna Chief Medical Officer Admits mRNA Alters DNA
A to nej bi blo nekaj slabega?
Video je star 3 leta, torej je to nekaj novega, za kar še ne poznamo možnih dolgoročnih učinkov. Cepit večji del populacije z nečim nepreverjenim, se mi ne zdi nekaj slabega, se mi zdi nedopustno. Človeški organizem je tako kompleksen, da ne poznamo kaj so lahko stranski učinki.
Ko so delali cepivo za prejšnji SARS virus so ugotovili, da je bolezen pri cepljenih ljudeh bistveno hujša kot ne-cepljenih, ko pride jo ponovno v stik z virusom, zato so cepivo opustili.
Nekatere študije so pokazale, da Covid vpliva tudi na testise. Morda tudi cepivo vpliva na testise. Če se bo izkazalo, da je povečuje neplodnost, ali pa bodo otroci cepljenih staršev neplodni, kdaj bomo vedeli?
Zadnjič sem bral en feed ene ameriške medicinske sestre, ki je zagovarjala cepljenje in je po par dneh od cepljenje splavila. V kolikšnem času bomo vedeli ali so cepljene ženske manj plodne/neplodne?
"A to nej bi blo nekaj slabega?" ostaja retorično vprašanje.
UganiKdo ::
točno tako. Vsako cepivo/zdravilo mora vsaj 30 let odležat v zmrzovalniku preden se lahko začne z uporabo...
in kaj ima starost videa s starostjo tehnologije? Zadnjim sem gledal dokumentarec iz leta 2019 o prvem telefonu. Bog ne daj to nepreverjeno tehnologijo uprabljat, če video še dve leti ni star.
mogoče se ti pa končno spustijo.
zadnjič sem bral en feed ukrajinske eksotične plesalke, ki je zagovarjala cepljenje in je po par dneh od cepljenja padla z droga in so zlomila nogo. V kolikšem času bomo vedeli ali cepljene ženske niso več primerne za eksotične plesalke?
  • spremenil: UganiKdo ()
ajdov2 je izjavil:
Fritz je izjavil:
Jutri druga doza AZ.
A maš 1 mesec razmak med dozami? A niso dali 3 mesece?
Noup, točno 1 mesec. Seveda bo jutri cepljenje samo, če vlada danes umakne prepoved za AZ, drugače bo pač kak dan kasneje.
UganiKdo ::
sem že celjen in še kar čakam na sprembo v testisih. Upam, da se bo sperma začela svetit po noči. Je pa res,da mi ga po cepljenju malo na desno vleče. Naključje?
vostok_1 ::
Z dvema odmerkoma? AZ?
UganiKdo ::
bah, si pa amater. Zakaj bi se cepil s tem zastarelim sranjem? mRNA all the way, hočem svetlečo spermo in pika.
vostok_1 ::
UganiKdo je izjavil:
Čak torej se nisi še cepil?
na statističnem uradu so vsakega 8. v mesecu dali podatke umrlih prejšnjega meseca. Februar že pošteno zamuja. Najbrž je bilo toliko smrti pa se ne upajo preplašit prebivalstvo, zato bodo najbrž obdržali podatke, dokler se ne spomnejo kaj.
https://pxweb.stat.si/SiStatData/pxweb/...
UganiKdo ::
seveda sem se, pa še kar nič od obljubljenih genskih sprememb. Razumem, da glow in the dark sperma rabi malo časa, ampak kaj pa vse ostalo kar ste teoretiki zarot obljubljal? Da ne bo na koncu vse kar imam od tega cepiva odpornost na eno brezvezno gripo.
kuglvinkl ::
Kumbaja je izjavil:
CoolBits je izjavil:
carota je izjavil:
Še nekaj dejstev, ki se jih mediji in vlade izogibajo.
https://www.bitchute.com/video/P7pTjitc...
Povej kaj bluzijo, samo linke na videe bom brisal.
Bluzijo točna dejstva, ki jih vi nočete razumet, ko vam jih mi povemo torej naj vam še kdo drug pove enako.
Lahko pa tudi brišeš, me ne obremenjuje, če vas kognitivna disonanca je*e.
Pa bomo zvedl, kaj bluzijo?
Se splača poslušat, odličen stand up. Zmaga pa tista o tem kako proteini, ki jih mrna cepiva ustvarijo lahko napadejo 55 razlišnih tkiv v telesu in zato je praktično vsaka stvar,ki se ti zgodi po celpljenju stranski učinek cepiva. Vkljčno s tem, da si zlomiš nogo ko padeš po stopnicah. Ker napadejo tako širok nabor tkiv ima seveda vsak posameznik drugačne stranke učinke in tako prikrijejo resnično škodljivost. Če citiram: Its a very well designed killing tool... po njeno so mrna cepiva potrjeno ubila več kot 1100 ljudi, ampak tukaj se šov šele začne. Ker seveda vlade na vsak način želijo prekrit je v resnici vsaj 10x več primerov torej vsaj 11000 potrjenih mrvih. In potem naprej izpelje, da v resnici se prijavi samo 10% je torej prava številka 110000 mrtvih, ki pa ne vključuje še vseh tistih,ki so navidez umrli zaradi drugih razlogov.
Kot rečeno, odličen stand up nastop. Pomoje njen najboljši, pri ostalih čist preveč dramatizira in se resno jemlje.
Hahajaja :)
vostok_1 ::
Torej, koliko odmerkov in s katerim cepivom si se?
vostok_1 ::
Kot sem napovedal
"Prišli smo do jasne znanstvene ugotovitve, da je to varno in učinkovito cepivo,"
https://www.24ur.com/novice/korona/ema-...
Zadeva je varna. Gremo fantje. Zavihat rokave.
Poudarila je, da so pri analizi sodelovali z najboljšimi strokovnjaki.
Ta naj najboljši strokovnjaki, so potrdili, da je super duper.
Niamte več izgovorov, da se ne cepite.
  • spremenil: vostok_1 ()
oopticom ::
Smo se že.
Ti se ne boš?
Kot sem napovedal
https://www.index.hr/vijesti/clanak/nor...
"Ovu vijest je danas ujutro objavila norveška novinska agencija NTB, prije nego što je EMA objavila svoje izvješće."
""Znanstvenici nemaju odgovor zašto je baš to troje zdravstvenih djelatnika dobilo krvne ugruške, a ostali ljudi ne.
"Imamo teorije, ali ne znamo zašto neki to dobivaju, a drugi ne", rekao je Holme."
""Nema ničeg drugog osim cjepiva što može izazvati ovakvu reakciju""
"Jučer je preminuo muškarac (33) iz Siska, 12 dana nakon cijepljenja AstraZenecom. Prvom dozom je cijepljen 5. ožujka u Sisku."
  • spremenilo: Telbanc ()
oopticom ::
Index.hr, res verodostojna novičarska stran.
hormilo ::
oopticom je izjavil:
Res mam pun k... takih komentarjev...pa preveri sam ce ne verjames...evo par sec guglanja...
https://www.google.com/amp/s/norwaytoda...
oopticom ::
Se pravi 30 ljudi na 17 mil (glede na UK številke) imajo premočno imunsko reakcijo, in zaradi tega nastanejo strdki?
Četudi to drži, je to še vedno zelo, zelo nizka številka in je cepivo varno. Pa še vedno ni korelacije.
Oziroma vprašanje ostaja: ali bi pri teh ljudeh vsakršna imunska reakcija dvignila tveganje za nastanek krvnih strdkov, ali specifično imunska reakcija zaradi cepiva.
Dokler na to ni odgovora, je težko zagotovo rečt da je krivo cepivo.
  • spremenilo: oopticom ()
showsover ::
Nič, reportaža s terena se zaključuje, vsi rezultati negativni. Do naslednjič.
HappyPills ::
Kot sem napovedal
Končno.
kugl, če gre verjeti index virom bo naslednjih 12-14 dni kritičnih.Sedaj vemo, zakaj Jelko to časovno obdobje Jelko stalno omenja.
Imej torej 112 na speed dialu, kdo bo potem brisal vse antivaxer flatearh 5g trole, če tebe pobere (pegasus in bigwhale dvomim da bosta zmogla).
ajdov2 ::
V Nemčiji je bilo v tednu po cepljenju 7 strdkov takega tipa, katerega bi za celotno Nemčijo pričakovali 15 primerov na leto.
6 od 7 pri zdravih ženskah pod 40 let.
vostok_1 ::
Smo se že.
Ti se ne boš?
Dva odmerka? AZ?
oopticom ::
ajdov2 je izjavil:
"So far, the Astrazeneca vaccine has been administered more than 1.6 million times in Germany. Seven cases of thrombosis occurred in connection with the vaccination. Three of them were fatal."
7 na 1.6 milijona je zelo, zelo malo.
Na leto v EU (6 držav) je takšnih dogodkov 465.715. Strdki so zelo pogost dogodek v zdravstvu.
https://pubmed.ncbi.nlm.nih.gov/1793879...
The estimated total number of symptomaticVTE events (range based on probabilistic sensitivity analysis) per annum within the six EU countries was 465,715 (404,664-538,189) cases of deep-vein thrombosis, 295,982 (242,450-360,363) cases of pulmonary embolism (PE), and 370,012 (300,193-483,108) VTE-related deaths
The total number of deaths occurring inFrance, Germany,Italy,Spain, Sweden, and the UK has beenre-ported to be 2,982,816 perannum (40).Our model estimates that370,012 (300,193-483,108) (12%)deaths per annum in these sixEU countries are duetoVTE, withthe proportion varying from10%inthe UK to 14% in Italy.
Če najde kdo bolj ažurne podatke, se priporočam.
vostok_1 ::
Tako je. Cepiva so varna.
Cepite se kdor se še ni. Dajte se na spisek.
Imagodei, si se napisal na eupravi?
HappyPills ::
ajdov2 je izjavil:
Ja res je sem preveril. pri 1.2 Milijona cepljenih z AZ je bilo 7 primerov strdkov 3je so umrli.
Zdej pri 2.6 milijona potrjeno okuženih je bilo 74.000 mrtvih. Torej pri isti številki je to torej 10000x več mrtvih kot pri cepivu.
Zdej seveda bi mogoče kdo rekel ja bom pa aspirin čvoknu da se izognem strdkom. Hja, kle je pa jeba, ker je pri 1 milijona vzetih aspirinih 25 mrtvih od stranskih učinkov in bi si s tem dejansko poslabšal možnosti lol.
vostok_1 ::
HappyPills je izjavil:
ajdov2 je izjavil:
Tako je.
Si cepljen? Na spisku?
HappyPills ::
Sem še na spisku, ker sem še premlad. So pa v družini starejši že vsi cepljeni. :) Aja in tudi mlajši za vse potrebno. Sej veš moja tamala je 1 teden po cepljenju shodila in začela govort. To ne more bit naklučje vostok.
oopticom ::
Smo se že.
Ti se ne boš?
Dva odmerka? AZ?
Seveda. Ti se ne boš?
vostok_1 ::
Ne sprašujem o ostalih cepivih. Ampak covid cepivu.
Aston_11 ::
Se je še kdo čipiru te dni? Danes sem dobil še čip za klope. Upam, da se signala ne bosta motila.
Reycis ::
Verniki bodo verjeli ne glede na to kakšni argumenti bodo pred njimi pa naj si bodo to mamilaši ali pa anti-vaxerji. Prav zanimivo mi je opazovat ta efekt v tej debati. Res pa je tudi, da nobena stran v bistvu nima NOBENEGA resnega argumenta. Oboji so verniki - samo v nasprotno stvar.
vostok_1 ::
Kakšna pa je moderate pozicija?
Aston_11 ::
Reycis je izjavil:
Nope, eni so znanstveniki, eni pa bedaki. Vernikov je bolj malo, razen tistih, ki v nekaj verjamejo.
oopticom ::
Reycis je izjavil:
Imaš številke in študije in te so dovolj zgovorne kot argumenti. Ne vem točno, kakšen dodaten argument bi še moral imeti.
Kot tehničar/inženir sem bolj naklonjen stroki ter znanju in trudu, ki gredo v razvoj in testing takšnih metod in cepiv.
Nekdo drug pač raje verjame sosedu, politiki ali novici v časopisu.
vostok_1 ::
Reycis je izjavil:
No. Zato pa si cepljen. Priden.
Naredil si en korak za človeštvo. Sedaj treba samo še počakat.
oopticom ::
Pa ti?
krucymucy ::
Pa ti?
Cepiva zanj nazalost se dolgo ne bo.
Jaz bom najbrz izkoristil priloznost in se cepil v tujini.
koli99 ::
Vostok, malo v razmislek: ali si morda kdaj pomislil da ti ta koronavirus/kriza/cepljenja povzroca toliko stresa, da si nadpovprecno ogrozen za bolezni ki izvirajo iz le-tega (precej hujse kot covid po tvojem mnenju)?
Nebi raje pocel nekaj stress free? Ne spremljam vsake teme in vsakega posta a kamorkoli kliknem si tam, kar mi pove da potrosis ogromno energije in casa na podrocju katerega zanikas oz. banaliziras.
Sam ne kadim a mi na kraj pameti ne pride da bi kadilce utrujal z njihovim wrongdoingom.
Ti se cepil ne bos, razumemo. Ostali naj se odlocijo po svoji vesti.
vostok_1 ::
koli99 je izjavil:
To je v bistvu izredno dober point.
Meni (in daljni večini prebivalstva) je stres zaradi covid lockdowna bolj nevaren od samega virusa.
Toliko o apokalipsi.
Saj imaš prav. Ampak vedno se vračam, ker znova in znova se zaletim v debilne steklene stene lockdowna, ki so jih postavili.
Če bi zadeva bila omejena na koronarje...i wouldn't care less. Problem je, ker mi greni življenje IRL.
Računam, sa si spremljal moja pisanja in najbrž veš zakaj druga poved tega odstavka ni tako trivialna kot jo predstavljaš?
Je pa pegasus vsaj nekaj povedal potencialno resničnega.
Če ne bo državljanske vojne oz. nekega masovnega upora proti temu dokumentiranemu nategu stoletja in se bo pač večina odločila biti ovca za powers that be.
Zgleda, da bom res moral postati puščavnik.
Honestly. Če bi ime fuck you money, bi resno že prospektiral lokacije za se odselit iz te nočne more.
Vseeno pa upam, da se folk strezne in sproži državljansko vojno. Z veseljem se pridružim. I've got some scores to settle.
jest10 ::
Oh revček bo čakal, da drugi nekaj naredijo za njegovo rit, sam se bo pa skrival z tipkovnico:))
koli99 ::
Kako ti greni zivljenje?
Mene osebno korona situacija sploh ne obremenjuje. 99% stvari delam istih kot prej. Meni je bil recimo prvi lockdown super, cele dneve z mojimi otroci, delo od doma, etc... sedaj pa potujem isto kot pred korono, nazaj se druzinsko druzimo/pikniki, etc. Razen obcasnik obiskov restavracij ne pogresam skoraj nic, pa se te nadoknadim v tujini kjer so restavracije odprte.
Edina 'nevsecnost' so bila neprestana testiranja za vstop nazaj v Slo ampak sedaj po cepljenju sem se se tega resil...
zmaugy ::
koli99 je izjavil:
Pa imaš tudi in person sestanke?
Biseri...
neumnosti.
koli99 ::
Of corse
vostok_1 ::
koli99 je izjavil:
No saj, če se kreativno izogibaš ukrepov še kar gre.
Kar tudi počnem. Ne tako dolgo nazaj sem že riskiral par kEUR kazni.
Šure se da, ni pa to life.
16 / 71
Kako do visoke precepljenosti? (strani: 1 2 3 4 … 10 11 12 13 )
604145229 (126731) BigWhale
Antivaxx club (strani: 1 2 3 4 5 6 )
25877494 (74499) ahac
