Windows XP in modem
Windows XP in modem
ttnm ::
mam motorolo 56k fax modem pa sm vceraj na novo instaliral windowse xp in instaliral vse driverje(od maticne, graficne, monitorja) na koncu pa se modem. modem mi je sicer prepoznalo vendar driverje od modema s cdja ni hotlo instalirat ker kao nima windows xp ditigal sign al nekj tazga. no pol sm pa tm izbrau standard modem 56k in je uspesno driverje instaliralo. Ko sm se hotu povezat na net mi pa je javlo naslednjo napako:
error connecting to arnes
opening port...
Error 692: there was a hardware failure in the modem(or other connecting device)
pod more info pa se pise:
692
-Your modem (or other device) is not responding because of the following:
-The modem is turned off, malfunctioning, or is not securely connected to your computer.
To resolve this problem, do the following:
-Reset your modem. For more information, consult your modem documentation.
-If you are using an external modem, ensure that you are using a proper serial cable and that it is connected securely. You may want to try replacing the modem cable. Also, if you are using an adapter to connect your external modem to your serial port, ensure that the adapter is wired properly for modem communication. For example, a 9-to-25 pin adapter for a mouse does not work properly with a serial network connection.
-Test the serial port or multiport adapter, and replace it if necessary.
-Ensure that the handshaking options for the modem are configured properly. Consult your modem documentation for information about different handshaking options available for your modem.
-If your modem is not supported by Network Connections, switch to a supported modem.
-Verify that another application, such as HyperTerminal, is not using the communications port. If the port is being used, subsequently starting -Network Connections may cause this message to appear.
For more information, see Microsoft Product Support Services.
__________________________________________
...in, je meu mogoce kdo kdaj ze podobne tezave...sm mogu kej se dodatno instalirat, nastavit..mogoce u biosu?? v modem properties pod device status pise: This device is working properly. je pa tud cudno, da se nc ne slis modema ce dam speaker volume na high. V port(com1) in port(com2) tud pise Device is working properly.
no zdej se pa prosim razpisite in povejte kako ustrezno resitev..
Lp,
ultras
sash ::
Ta modem sem tud jaz učasih mel in kot prvo je potrebno inštalirat gonilnike za 2000, čeprav ti javi da niso vredu in da niso podpisani zadeva preverjeno dela in kot drugo je potrebno v nastavitvah modema ugasnit "čakaj na znak centrale", ker pr nast to kao ne špila in potem bi moralo delat
Think different...
TOROiD Group
TL-MR3040 Prenosni usmerjevalnik
Oddelek: Omrežja in internet
71638 (1290) MajorM
Siemens I-surf USB ISDN modem problem...
141934 (1720) amigo_no1
connecting own dialling router to siol adsl
92749 (2645) enis
ISDN disconnect problemi
81796 (1622) Hux
115 k
141605 (1386) Boky
