Forum » Navijanje » AquaMark 3: Countdown!
boštjan ::
v primerjavi z 3dmark2003 bo zanimivo spremlat rezultat
.pa še zahteve
- spremenil: boštjan ()
kuglvinkl ::
Jep, upam, da bo tole spet ena dooooooooolga tema.
Bomo videli 15. + počakati bo treba še za dostojne reviewje od denimo Beyond3d.com, 3dcenter.de, aceshardware.com.
kuglvinkl ::
On this date at 3:00 pm, Massive Development is set to release long awaited DirectX 9 benchmark, AquaMark 3. It is based on same engine, krass Engine, that's used by AquaNox 2: Revelation and the upcoming title, Spellforce.
The basic application will be available as a free download on a large number of mirror sites around the world. This version supports the AquaMark TRISCORE™ benchmark test and free online access to the ARC.
The AquaMark online shop will offer a range of extended versions for private as well as for commercial use. All of these licenses contain the capability to check the customer’s system extensively. They also comprise a wide range of unique features like pixel rate tests and pixel shader complexity tests. Prices start at $9.95 (€ 9.95 for EURO countries) for the fully featured Professional Version.
boštjan ::
€9.95 niti ni drago,upam da si ga po plačilu lahko kar iz strani dol povlečeš,drugač pa kazaa.
morphling1 ::
Jep AM3 zna bit ok test predvsem zato, ker je narejen na pravem game enginu in ima to lepo lasnost da bo delal na vseh karticah kompletno (ne tako kot 3dm ki določene teste izpusti) samo rezultati bodo nižji na dx7.dx8 karticah
BoLhCa ::
tic@ bo treba novo grafo=)))
pa prnes mi ze digitalca!
aja glede novice, pa komi cakam, dost naprimer obeta tudi half life 2 bench...
Zheegec ::
Janez Janša, 29.04.2014
Zheegec ::
In že špekulacije o zmanjšani kvaliteti slike pri Detonator 5x.xx driverjih!
rap3r ::
Je že kdo dol potegnu program?
Ne droga, ne trava me ne mika, le kakšna promilja alkohola se učasih po krvi mi potika:)
| » | Mam probleme z 8800gts 320mbOddelek: Pomoč in nasveti | 1552 (1297) | j3rn3jk |
| » | Slo-tech 3d team: AquaMark 3 (strani: 1 2 3 4 5 )Oddelek: Navijanje | 53729 (37931) | Yuka |
| » | Benchmark programiOddelek: Navijanje | 1241 (1105) | speed machine |
| » | AquaMark 3 results (strani: 1 2 3 4 5 6 7 )Oddelek: Navijanje | 20722 (15649) | DjTonic |
| » | Novi Detonator 4 gonilniki so res eksplozivniOddelek: Novice / Grafične kartice | 2513 (2513) | tejo |
