Active Pen in kompatibilnost
SmeskoSnezak ::
Dell pisalo PN557W in/ali PN556W noceta delati z AIO Optiplex 7640, Windows 10.
Gonilniki se tudi niso zeleli namestiti za 557W verzijo.
Zna kdo pomagati pri temu? Je potrebn kaki drugi kuli? :))
@ Pusti soncu v srce... @
SmeskoSnezak ::
Nasel sem tole:
Capacitive touch screens; this is different from a touch screen with a active digitizer. Think of a digitizer as a radio receiver, and active stylus has a radio transceiver, and will send signals to the digitizer without actually touching the touch screen. So you can hover an active stylus over a digitizer screen and the screen will detect the stylus and move the cursor accordingly even though you aren't actually touching the screen.
A capacitive touch screen detects a break of current when an object like your finger or a stylus presses down on the touch screen. Unlike an active digitizer direct contact must be made and you can't hover the stylus over the screen. A capacitive touch screen only detects where you are touching the screen, not how hard or at what angle you are touching like an Active digitizer screen will do.
OptiPlex bi naj prisel z kapacitivnim monitorjem in bi naj pisalo delalo , ce ga pritiskas na monitor... kar pa dejansko ne deluje, kolikor se testiralo.
Lahko kdo potrdi ali ovrze to tezo za pisala ali taksne monitorje?
Menjava notranjega stekla ( S4)
Oddelek: Mobilne tehnologije
193340 (2998) klinker
Pisalo za tablice z majhno konico
145144 (5007) RejZoR
Sony`s new Xperia phones; T, V, J and TX
206058 (5329) GeForce
HP Slate z Windows 7 opažen v trgovinah
2812173 (11413) PrimozR
"Miška" na notesniku (Compaq) je zelo samosvoja !
82224 (2131) Cokolesnik
