Definicija spola
Definicija spola
BFVV ::
jype je izjavil:
Nobenega paradoksa ni.
Največji feministi ste največji nasilneži nad ženskami.
Mi primitivni balkanci vam ne sežemo do kolen s spolnimi in fizičnimi zlorabami žensk.
GregiB ::
FormerUser je izjavil:
Uradna statistika policije in tožilstva torej zate ni dovolj dobra podlaga, ker jo je uporabila feministka,
So so, absoultno, ampak ne tarna nad ugotovitvami, ampak metodo, kje mene "mine" je, ko gledam njene argumente:
-It is about domestic abuse and/or conflict, not domestic violence
Abuse = violence, period. Tukaj seveda hoče pod preprogo pomesti psihološki teror, ki ga je deležen marsikateri moški od svoje partnerke.
-The data does not differentiate between cases where there is one incident of physical conflict/abuse/violence or those where violence is repeated. If we look at the data for where there have been four or more incidents, then approximately 80% of victims are women
Zloraba matematike... Sicer ne vem, ali je dejansko temu tako a govora je o številu žrtev. Če te nekdo pretepe, si žrtev. Če te pretepe 5x, si še vedno žrtev...
-The data does not differentiate between incidents where violence and abuse are used as systematic means of control and coercion and where they are not
Unsystematic violence = violence...
-The data does not include sexual assault and sexual violence
No, tule pritrdim, zaradi bioloških razlik med spoloma ženska precej težje spolno zlorabi moškega, kot obratno, drži. If you can't get it up.... well, you can't...
-The data does not take account of the different levels of severity of abuse/violence, ‘gender symmetry’ is clustered at lower levels of violence
All levels of violence = violence. Sicer (spet) zaradi bioloških danosti obeh spolov je moška roka težja od ženske, je je tudi t.i. intimni terorizem dokazano (vsaj v Novi Zelandiji) enak pri obeh spolih
-The data does not take account of the impact of violence, whether the level of injury arising from the violence or the level of fear. Women are six times more likely to need medical attention for injuries resulting from violence and are much more likely to be afraid
Tukaj empirično raziskavo skuša ovržti z novim parametrom... stopnjo prestrašenosti. Obenem pa želi iz računice izvzeti psihično nasilje. Po lastnih izkušnjah ima več dedcov strahospoštovanje do partnerk kot obratno prav zaradi aktivnega izogibanja psihičnemu nasilju.
-The data does not differentiate between acts of primary aggression and self-defence, approximately three quarters of violence committed by women is done in self-defence or is retaliatory.
Evo, tole pa je najbolj kontroverzna trditev od vseh... Self-defence. Obramba pred nasiljem, pred grožnjo... Ko dedec prilima ženski klafuto, ker se počuti ogrožebega, napadenega... self-defence? ojej...
FormerUser ::
GregiB je izjavil:
Hinavka... Stavka, ki ga "citiraš" v članku ni.
Ampak OK, ti si napisala spolni stereotip, bom jaz napisal spolna vloga... to tudi učim podmladek. Sina učim, da spola nista enaka in nikoli na bosta. Da bo v zrelosti znal prevzeti in "odigrati" vlogo moškega v družbi. A začuda ga ne učim, kako pripalit ženski eno na gobec, jo plačati manj za delo, ji ne dovoliti na srečanje s kolegicami. Učim ga ženske spoštovati, jih ljubiti in ščititi, jim znati prisluhniti, jih podpirati, z njimi želeti sobivati... Za nekatere stereotipi.... works for me...
Nisem nikjer trdila, da je, gre za slovenski povzetek. Sicer pa članek govori o tem, da se fantje že zgodaj, v svojih primarnih družinah, naučijo, da se gospodinjska dela prepusti ženskam, medtem, ko sami uživajo v prostem času.
Sicer je pa z otroki tako, nekateri postanejo podobni svojim staršem, prevzamejo njihove vrednote, nekateri gredo pa povsem kontra, tako da tudi za tvojega sina še obstaja upanje, da se ne bo razvil v šovinista kot je njegov ata.
BFVV je izjavil:
Narobe. Največji feministi se ne pretvarjamo, da blažje oblike nasilja od umora niso nasilje, tako kot to počnete desničarji.
GregiB je izjavil:
Moški, ki se ne zna postavit zase, itak ni pravi moški.
GregiB je izjavil:
Aha, ko moški zaradi ideološke indoktrinacije ne sprejmejo jasnih rezultatov, temu rečejo "zloraba matematike".
GregiB je izjavil:
Ne, ni dokazano. Niti izmerjeno ni.
  • spremenilo: jype ()
Unilseptij ::
Vsekakor je zame edina konsistentna pot k vecji enakosti moskih in zensk (in vseh drugih) ta, da jih dejansko obravnavamo enako... in ne, da si izmisljujemo sto in en nacin, kjer moramo nekako "uravnoteziti" naravne razlike (recimo z dodatnimi zakonskimi zascitami zensk, locenimi WC-ji, itd.). Ce resno mislimo, da smo enaki, potem je vsaka posebna ureditev, ki "sciti" ene pred drugimi, priznanje ravno nasprotnega, to je, da v resnici nismo enaki, ceprav naj bi (po nekih ideoloskih predstavah) morali biti... torej v nekem smismu korigiranje napak narave, ki nas ni naredila enake. To je pozicija, ki jo danes radikalni feminizem zelo pogosto vsaj posredno zagovarja, pri cemer pa na ta nacin pricakovanega napredka ne bo. Na ta nacin se tudi nekako zamegljuje, da bo na koncu tega procesa "izenacevanja" se vedno moral ostati nekje moski s svojo moskostjo, da bo lahko normalno sobival z zensko. Ce je cilj radikalnega feminizma, da se vloge samo obrnejo (torej od patriarhata v matriarhat), potem to jasno ni prava pot in nihce ne bo imel nic od tega.
Tipicen primer je recimo nasilje nad zenskami, kjer se vedno poudarja, kako je vsaka tretja (ali nekaj takega, govorim na pamet) zenska bila zrtev nasilja s strani moskih. Ne pove se pa recimo, koliko moskih je bilo zrtev nasilja (drugih moskih)... jaz bi rekel, da precej vec kot zensk. In potem zenske vs. zenske itd... iz celotne slike bi se potem dalo potegniti kaksne pametne zakljucke, drugace je vse skupaj samo nastevanje nekih statistik, ki same po sebi nic ne povejo.
Unilseptij je izjavil:
Nihče tega ne misli.
Eni pravijo, da bi morali biti moški zaščiteni pred ženskami.
Ne, je ne. To je pozicija, ki jo nasprotniki enakopravnosti predstavljajo kot feministično, pa ni.
Ker smo moški vsi v isti ekipi in se lahko zmenimo, da se nehamo tepst.
Saj se jih da: Družba tolerira specifične oblike nasilja, med katere spadata družinsko in spolno nasilje, čeprav je jasno, da obe vrsti močno škodujeta tako žrtvam kot družbi.
FormerUser ::
@Unilseptij
Slika pove več kot 1000 besed, ti se zavzemaš za rešitev št. 2, feministke za rešitev št. 4.
Unilseptij ::
jype.... vsi smo v vsakem primeru v isti ekipi, tako moski kot zenske. Ravno to je tisto, kar pravim. Takoj, ko zacnemo govoriti o dveh ekipah in kaj ima ena in cesa nima druga, resna diskusija postane nemogoca.
Kaj je torej razlog, da lažeš o feministični agendi?
Unilseptij ::
Ce je recimo vsak drugi moski zrtev nasilja in vsaka tretja zenska, potem so pac moski na slabsem... za zrtve je nepomembno ali jih tepe moski ali zenska, vsaj zame bi bilo.
Ce je recimo vsaj drugi moski zrtev nasilja in vsaka tretja zenska, potem so pac moski na slabsem... za zrtve je nepomembno ali jih tepe moski ali zenska, vsaj zame bi bilo.
Drži, a žal se MRAji nič ne zavzemajo za ničelno toleranco do nasilja, zgolj feministi se.
Unilseptij ::
@Unilseptij
ja, samo resitev 4. pomeni, da podres ograjo, ki je predvidevam tam z nekim razlogom. In feministke z radikalno agendo se odlikujejo ravno po tem, da jih nic ne zanima, kaksne bodo posledice podrtja ograje oziroma verjamejo, da je ograja tam brez vzroka, samo zato, da bi nagajali prikrajsanim, kar pa le redko res drzi.
FormerUser ::
Če se vsi strinjamo, da je glavni problem moško nasilje, zakaj tako burne reakcije, ko se to jasno in glasno pove, zakaj obtožbe o domnevnem feminističnem sovraštvu do moških, zgolj zaradi navajanja dejstev. Očitno se nekdo samo pretvarja, da mu je do rešitve problema, v resnici mu pa status-quo povsem ustreza.
Unilseptij ::
glavni problem je nasilje kot tako... in ce koga zanimajo vzroki za nasilno obnasanje cloveskih bitij in moznih resitvah, je o tem mozno kar precej debatirati. Ampak tebe bolj zanima, da se preneha nasilje nad zenskami, ostalo te pa ne briga prevec, ker ni v dometu radikalne feministicne agende, ki jo tako lepo zagovarjas.
49106 ::
Če se vsi strinjamo, da je glavni problem nasilje
Evo, sem ti popravil.
  • spremenilo: 49106 ()
FormerUser ::
Skratka, rešitve te ne zanimajo, če bi te, bi poimenoval problem s pravim imenom, četudi to spola, ki mu pripadaš, ne kaže v najboljši luči. Problem lahko rešiš šele takrat, ko ga poimenuješ in tudi če rečeš, da je problem nasilje, ga še vedno večino zagrešijo moški. Tega pa očitno ne želiš slišati, zgolj trditi, da so tudi moški žrtve.
Unilseptij ::
Dej no mir.... "moski tepejo zenske" ni poimenovanje problema s pravim imenom, ampak zavajanje, pretirano poenostavljanje in zamegljevanje, ki dejansko preprecuje resen pristop k resevanju problematike. Jaz nikakor nocem trditi (kot nekateri "ogrozeni" moski), da so v resnici moski tisti pravi revezi :D... trdim samo, da tvoja radikalna pozicija ne ustvarja pogojev za dejansko resevanje tezav. Ker si predstavljam, da bi, ce bi bila moznost, resno zagovarjala nadaljnjo locitev moskih in zensk, ustvajanje locenih okolij, itd., da do zlorab ne bi moglo prihajati, pri cemer na vsak nacin zelis ignorirati "naravno" in samoumevno soodvisnost in partnerstvo med moskimi in zenskami, ki je posledica preprostega dejstva, da smo vsi cloveska bitja.
BFVV ::
jype je izjavil:
BFVV je izjavil:
Ja, "naci" države so res groza za ženske :))
Bolj ko ste progresivni več posiljujete in zlorabljate ženske.
SPLC Implodes: President And Legal Director Resign Amid Sexual Misconduct Scandal
FormerUser ::
Seveda je. Name the problem - male violence, tako do žensk kot moških. Ti bi problem očitno reševal z ohranjanjem statusa quo, kjer je vsaka tretja ženska žrtev nasilja, ker da je vse ostalo prekomplicirano. What a guy!
Človek ni samo narava ampak tudi kultura in dejstvo je, da danes spola ne rabita več en drugega za preživetje in glede na to, v kolikšni meri so ženske žrtve moškega nasilja, se mi zdi ena od racionalnih rešitev, da se jim ponudi možnost ločenega bivanja.
Ej hipatija vsaka tretja zenska je zrtev nasilja ok.... Koliko pa je moskih zrtev nasilja?
FormerUser ::
Boš ti povedal in bodi precizen, koliko je moških žrtev ženskega nasilja.
Ne ti si samo napisala da je vsaka tretja zenska zrtev nasilja in nic dalje
Drugace pa vsaka babnca ko ima pms je nasilje psihicno ce je v odnosu takrat nervira tipa zdaj si pa zracunaj kolko jih je bloo zrtev nasilja zensk... Skoraj vsak nad 16 oz 17... Ki je bil v zvezi
  • spremenilo: Mato989 ()
FormerUser ::
Če se nerviranje šteje za nasilje pod popravljam svojo tezo, ki se sedaj glasi: prav vsaka ženska na tem planetu je žrtev moškega nasilja.
In vsak moski od zenskega nerviranja ker to je psihicno nasilje... To je to vsi smo nasilni en do drugega samo ti bi rada obrnila statistiko v svoj prid
FormerUser ::
Except, da nerviranje ni nasilje, torej splava po vodi tudi tvoja relativizatorska teorija.
Seveda je, psihično nasilje... samo tebi ni všeč da je to nasilje... in pol se moški nad nasiljem ženske vsake tretjič ubrani in ti imaš svojo statistiko =)
Tole nasilje nad ženskami in vsako tretjo je v 90% self defense!
GregiB ::
Name the problem -
... violence... and feminism...
Namreč, s tem, ko k nasilju prilepiš moškega in to zaviješ v neo-feministično solatiziranje, namerno "problem" preimenuješ iz "violence" v "male". S tem ko potem mahaš z Rape culture statistiko rineš v smer "vsi moški so potencialni posiljevalci" filozofijo. In zaradi zelo preprostega dejstva, da je velika večina moških nenasilnih do svojih žensk, se tem seveda upremo, saj enostavno ne pije vode...
FormerUser ::
Mato989 je izjavil:
Pri samoobrambi ne smeš uporabiti prekomerne ampak sorazmerno silo, torej, če te oseba nervira jo lahko kvečjemu nerviraš nazaj, nikakor pa se je ne smeš fizično lotiti. Torej, še en BS iz tvojih ust.
GregiB je izjavil:
Name the problem -
Feminizem je problem samo za tiste, ki želijo ohraniti status quo in s tem nasilje. Glede na to, da je vsaka tretja ženska žrtev nasilja boš pač malo težje trdil, da je velika večina moških nenasilnih, ker sicer ne vem kdo to nasilje izvaja, marsovci?
poweroff ::
zaradi česar naj bi bili prvi direktorji, druge pa tajnice
Tega seveda nihče ne trdi, razen tebe.
sudo poweroff
FormerUser ::
Seveda trdite. Majhen delež žensk na vodilnih položajih pojasnjujete z različnimi preferencami moških in žensk, ki naj bi bile biološko determinirane.
GregiB ::
To trdim mirne vesti... Namreč, govoriš o statistiki tretjine žensk, predvidevam, da povzemaš po WHO, ki to statistiko objavlja... pa pravi:
30% žensk je doživelo fizično in/ali spolno nasilje s strani svojega partnerja V SVOJEM ŽIVLJENJU. V Evropi 25%.
Povprečen evropejec in evropejka ima v svojem življenju 7 intimnih partnerjev. Torej imao povprečne 4 evropejke v svojem življenju povprečno 28 intimnih partnerjev. Od teh 4 žensk je ena v svojem življenju doživela fizično nasilje. ostale 3 pri svojih 21 dedcih ne. no, pa tudi pri tej eni so lahko bili nasilni vsi partnerji ali zgolj eden. Torej je po tej logiki delež nasilnih dedcov med 3 in 25%. Ker pa so nasilneži praviloma nasilni do vsakogar (vseh svojih 7-ih partnerk), se zadeva bolj upogiba k 3% kot 25%, se ti ne zdi?
Tudi jaz sem enkrat fasal focn od takratne punce... kaj bi naj odgovoril na takšnem vprašalniku. Sem bil deležen fizičnega nasilja "at some point in my life" ali ne?
GregiB ::
Hipatija... jutri si lahko direktor... odpri firmo, postavi si "all-women" management team, and off you go. V čem je problem? Vzemi življenje v svoje roke! Razvij dobro poslovno idejo, vsaka banka ti jo bo financirala, zastavi hišo, prihranke, imovino, zberi ekipo in ne bo ovir...
poweroff ::
Ne. Mi pravimo, naj si ženske izberejo tak poklic, ki jih veseli. Ne pa da se jih sili v poklicno pot zaradi nekakšne politične korektnosti.
Tako da jaz sem mnenja, da nasilje nad ženskami izvajaš ti.
sudo poweroff
poweroff je izjavil:
Včasih so, potem ste jih pa začeli silit v "poklice, ki jih veselijo", pa so izginile:
https://twitter.com/mit_csail/status/11...
Mato989 je izjavil:
Za moškega je to sorazmerna sila... in kaj zdaj? Te bedarije o sorazmerni sili so kr nekaj še ena pogruntavščina pomehkužencev in babnic...ti lahko z besedami nekoga pripraviš do umora, en šamar proti temu je pač sorazmerna sila =)
Mato989 je izjavil:
Ne, za kretena je, ampak k sreči to ni pomembno, ker sorazmernost ugotavlja sodišče.
Mato989 je izjavil:
Mhm, tako kot so standardi varstva pri delu, letalske varnosti in čelade vseh vrst.
GregiB je izjavil:
Tega ne bo nardila ker ni pol tako sposobna kot Bezos, Gates, Jobs ipd... ona hoče zdaj samo stolčke v upravnih odborih kjer bi kimala za visoko plačo... podjetja so morali tipi gor spravit jasno =) Klasična dvoličnost!
jype je izjavil:
Mato989 je izjavil:
Mato989 je izjavil:
Če te nekdo z besedami skoraj pripravi do samomora potem je pač sorazmerna sila tudi oboj te osebe, to je dejstvo =)
Mato989 je izjavil:
Ona je sposobnejša kot vsi trije skupaj, pa zaradi patriarhalne družbe ne dobi enakih priložnosti, da bi se sploh lahko izkazala.
Mato989 je izjavil:
Oboj? Pri tebi nobena sila ne bo pomagala, ker se inteligence ne da vtepst v glavo.
Če je sposobnejša, bo NAVKLJUB patriarhalni družbi pokazala vsaj enako =)
WoW, res si pro, ko nekdo tipka s telefona in ga loviš na semantiko =) Bravo penzič =)
Čigave pravice bi se zmanjšale, če bi lahko imel "shit" napisan pod "spol" na potnem listu?
Mato989 je izjavil:
Tako kot boš ti zlahka dokazal, da si boljši voznik od čevljarja, čeprav si niti skiroja ne moreš privoščiti?
Mato989 je izjavil:
Ti lahko tipkaš tudi z vesoljske postaje, pa boš še vedno enako teslo.
Za dobro idejo ne rabiš denarja... imaš polno primerov =) Talking Tom in Bitstamp noben ni bil ogromen bogataš začeli so za 1 serverjem ki si ga lahko privošči vsak, samo spet so bili sposobni moški kakšen čudež? Skratka če je sposobna bo naredila novo firmo in pokazala z crowdfundingom lahko tudi izda ICO in da vidimo kako bo šlo, koliko žensk bo vstopilo v podjetje in lastništvo in naj skupaj nardijo nekaj pametnega kar Svet rabi
Ji ploskam v prvi vrsti če ji rata, samo vem da ji ne bo =)
https://www.24ur.com/novice/slovenija/m...
Seveda se veselimo z njima.
Jarno je izjavil:
Vidim kako sta feministično zavrnili nošnjo rut pred moškimi v arabskem Svetu kar najbolj degradira babnce... HAHAHAHAHAHHAHA Epsko
FormerUser ::
Jarno je izjavil:
Vsi ne, Mato jima je očitno fovš. Bi rad bil milijonar, pa ni dovolj sposoben.
poweroff ::
Imaš tam trenutno aktualen primer feministične aktivistke iz Roga, ki je s kolegi zaskvotala Rog in šla potem v tožbo proti Ljubljankoviču... na koncu je padla sodba, da se morajo izseliti in pokriti sodne stroške v višino nekaj deset k.
In zdaj letijo naokrog začudeni maili z ugotovitvijo, da je pa lastninska pravica nad posestno pravico (kot da tega niso vedeli že prej), pa razočaranje nad Jankovičem (prej je bil pa "naš"), pa pozablja se na to, da je Rog v bistvu ekološka katastrofa, ki bi jo morali sanirati že včeraj.
In se zbira denar za poplačilo sodnih stroškov.
Namesto da bi se denar zbral prej, se najelo ali odkupilo prostore in se potem šlo dejavnosti, bo šel denar sedaj dobesedno v nič. Je to modus operandi feminističnih aktivistk?
sudo poweroff
FormerUser ::
Kako pa naj izvedo kaj jih v resnici veseli, če jim že od malega govorite, da nekatere stvari pač niso zanje.
s1m0n ::
Hudobne, hudobne mamice, da otroke učijo svojih veščin...
ZaphodBB ::
@Unilseptij
Kako zelo... Katoliška pozicija...
FormerUser ::
Ne poznam primera, ampak glede na to kako prikladno si zvalil krivdo na feministke močno dvomim, da je tale tvoja varianta povsem točna.
s1m0n je izjavil:
Seveda so vsega krive mamice, kdo pa drug.
FormerUser ::
Mato989 je izjavil:
Hočeš reči, da ste moški emocionalno nestabilna bitjeca, ki jih lahko z besedami pripraviš do vsakršne neumnosti?
Well....
23 / 27
Na FDV odstranili pisoarje (strani: 1 2 3 4 … 10 11 12 13 )
640144929 (135918) vostok_1
Velika Britanija: žrtve posilstev bodo morale policiji predati mobilne telefone (strani: 1 2 3 4 5 6 )
26673767 (69317) vostok_1
