RA2 preko dveh modemov?!
bastadu ::
Kako zašpilat RA2 preko modem povezave? Raćunalnik mi je že uspelo povezat z modemom, sam v samo igri, kako bi zrihtal, da bi videl drugega? thx za odg.
Dalmatinc ::
Men to tud ni ratal z ISDN jem na drug ISDN Grrrrrrr Westowd>:D>:D
Dax ::
Dva ISDN-ja ti čisto nič ne koristita... ne da se povezat... rezervirano za analogne modeme... sux, kwa češ...
BustA ::
kuko pa spilas prek analogne povezave ?
Devide Et Impera
BustA ::
mau me trga dons pa kr klikam !>:D>:D
Devide Et Impera
BugiMen ::
Zakaj pa bi se hotel povezati direkt preko modemov. Ce ni to pogoj raje igrajta prek neta kjer dela preizskuseno tudi ce nimata original. Vse kar potrebujata je en programcek ki ga najdeta na tej strani in deluje preko ipx sistema :D
Born to be wild and wild to be born
bastadu ::
Sem že zrihtu zadevo, sicer je mal počas, ampak važno da gre ...:D
kockish ::
Ce imas analogni modem, je direktna povezava hitrejsa in cenejsa (placuje pac samo tisti, ki klice) od interneta. Torej se splaca. Pa tudi nastavitve so enostavne.
servo ::
A slucajno kdo tuki igra preko neta?
Binji ::
Ni od mene ampak jebes:
>Is there any patch for Red Alert2 which lets you play modem to modem?
No patch, but I found this:
"1. In order to play Modem-to-Modem both computers must have the IPX
protocol installed.
2. You can check if you have the IPX protocol by right clicking on the
Network Neighborhood icon on your Desktop and selecting Properties.
Look to see if you have IPX/SPX compatible Protocol.
If you do not have IPX, click on the Add button then double click on
Protocol. In the window Select Network Protocol, under Manufacturers
select Microsoft and in the right under Network protocols select
IPX/SPX-compatible Protocol then click on OK and follow the
instructions.
(NOTE: If IPX is installed for any other adapter, these instructions
will not work. IPX must only be added for the "Dialup Adapter")
3. In the Networking Properties click on the "Access Control" tab.
User level access must be set to "Share Level Access Control".
4. Once both computers have the IPX protocol, one of the computers has
to install the Dial-up Server. Go to Start->Settings->Control Panel,
then select the icon Add/Remove Programs. Select the tab labeled
Windows Setup, and double click on the Communications icon. Do not
check the check box. Check the option Dial-Up Server and click on OK.
Follow the on screen instructions.
5. Now that you have the Dial-Up Server installed you need to
configure it. Double click on My Computer and then double click on the
icon Dial-Up Networking. (WinME must click "Start" - "Settings" -
"Dialup Networking") Go to the menu Connections and then to the option
Dial-Up Server. A new window will appear where you can setup the
Dial-Up Server options. Check the box Allow caller option and then
click OK.
6. Now you are ready to receive the call from your friend. Your friend
should setup a Dial Up connection to your phone number and call you.
Your friend should follow the instructions below:
Click on the My Computer icon on the desktop, then in Dial Up
Networking and use the Make New Connection Wizard. Follow the on
screen instructions. Now your friend can call using the new connection
created by Add Connection Wizard. If everything is right the computer
with the Dial-Up server will answer the call and establish the
connection.
7. Now both of you can load the game and play 2 player Network games
as if you were in a local area network. Do not try to use Internet in
this mode since you are not playing over Westwood Online."
Kdor ne navija ni Slovenc, hej, hej, hej!
bastadu ::
Ja sej, ta stvar deluje, sam zloooo počas:D
Wireless kartica ne deluje na win 7
Oddelek: Omrežja in internet
152349 (2191) kratos
Dober Singleplayer campain FPS špil?
Oddelek: Igre
355777 (4951) Bor H
Logitech MouseWare bug (?)
272600 (2196) Swiwer
Iščem alternativo vuduju
122440 (2204) Arthur
115 k
141609 (1390) Boky
