Bios update brez CPU-ja?
LJULJIBUC ::
Torej, nabavil sem Ryzen 7 2700X in MSI B350 Gaming Pro Carbon, katera seveda nima updatanih bios-ov in ni (za zdaj) kompatibilna z CPU-jem. Zdaj me pa zanima ali je kakšna možnost, da updatam biose brez CPU-ja?
KAVINSKY ::
Ne. Lahko pa daš oglas tu gor, da iščeš A6-9500 za nadgradnjo, ko odrabiš prodaš naprej.
En ga prodaja:
  • spremenilo: KAVINSKY ()
urbecar ::
Relativno preprosto s tem.
m3k ::
To obtain the boot kit, please carefully follow these instructions:
Go to the AMD online warranty claims page: https://support.amd.com/en-us/warranty/...
Fill in your full contact and product details (2nd Gen Ryzen Processor OPN number and serial number)
In the Problem Description field enter "Boot kit Required" (without quotes)
AMD will send you a "boot kit" for free that includes a cheap APU processor. You are supposed to throw away the included heatsink afterwards (it doesn't fit Ryzen) and send the CPU back so they can refit the kit and send it to the next person.
I live in western Europe and I requested it as well. It will be shipped from Holland and AMD will pay the return as well through DHL. Their reply was prompt and they said that they would communicate as soon as they dispatch it. They said once dispatched, it shoud come in 3-5 days
Mirko tipka na radirko ////
  • spremenilo: m3k ()
Ranljivost v AMD Ryzen procesorjih (strani: 1 2 )
559702 (4796) Mr.B
Iscem: Ryzen gen 1 ali 2
121894 (1501) filip007
AMD-jev kavelj 22 z novimi procesorji Ryzen
Oddelek: Novice / Procesorji
3111152 (7708) Mr.B
nigerijci še vedno harajo po bolhi
2410187 (9112) sarma832
Nov članek: "All your firmware are belong to us" (strani: 1 2 3 )
Oddelek: Novice / Nova vsebina
13820348 (17188) arrigo
