NVIDIA Turing - Uvod v RTX
barocco ::
RangerVIII|6700k|Corsair16GB|
Msi1070|pm961|BX5001TB|RM650x|H100iv2|
mahone ::
Še najbolj patetično izpade flagship GTX 780Ti. :)
Definitivno nova 1050Ti, čeprav je 180$ nekoliko preveč.
RX 570 je 120€ za nekatere modele.
Nekam veliko za sub RX 470 performance.
Jarno je izjavil:
Ja 3GB vrama danes ni vec dovolj.
BTW, kje ti vidis $180? Cena je $149, 180 bi 1650TI, ki bo po zmogljivosti tam nekje pri rx570. Le cena bi mogla bit $20 nizja.
mahone ::
Dr_M je izjavil:
Jarno je izjavil:
Conclusion
Pricing
Pricing then, depending on the model you buy you are looking at 149 for a stripped down simple version, running up-to to 179 USD for the more advanced, factory tweaked, designed and better-cooled products, with slightly inflated values for the EU.
mahone ::
Treer ::
Hehe, navita brez težav parira 570-ki >:D
Overclocking of GTX 1650 works very nicely, especially the memory. We achieved a 23% memory overclock, which helps to make up lost ground vs Radeon RX 570, which doesn't overclock nearly as well. Overall performance gained from overclocking the MSI GTX 1650 Gaming X is 16%.
Lol. 570 lahko tudi naviješ.
klinker ::
A beres?
Bolj malo bos navil ze navite AMDje. Imas sreco da nima dodatnega napajanja, ker bi jo verjetno navil na rang 580 4GB >:D
Saj jo že imaš. Imenuje se GTX 1660.
  • spremenil: D3m ()
klinker je izjavil:
A beres?
Seveda, potem ti jo bo pa svizec zavil v celofan.
FlyingBee ::
To je bolj za sestavljalce sistemov Walmarta, kjer kraljujejo cheapo napajalniki.
jb_j ::
gtx1070 je pa šla cena že na samo 265EUR
https://www.amazon.co.uk/dp/B01LLAJ8PU/
  • spremenil: jb_j ()
gddr85 ::
tale 1650ka ima sicer dodatni 6 pin
FlyingBee ::
Navita bo kar ok, čeprav ni toliko za diy, verjetno bo v prebuildih.
Treer ::
Tako je, to bo nova kraljica OEM-ov in tistih, ki hočejo t.i. pisarniške prebuilte spremeniti v entry-level gaming mašine, pa jih omejuje (dostikrat nezamenljiv proprietary) PSU. 1050Ti ni zastonj glede na Steam survey 2. najbolj popularna grafična z več kot 10% deležem...>:D
Lol. Nope. Bo kar iGPU pisarniški PC.
Treer ::
LOL je samo tvoje bralno razumevanje - nič novega sicer ;((
Ne bodi užaljen mali. ;)
Pač crkuje tudi luksuz.
  • spremenil: D3m ()
Treer ::
Daš naslov, da vidimo kdo je mali? >:D
  • spremenil: D3m ()
mahone ::
Treer je izjavil:
Bo navi zgazil cez dva meseca oz. Ze polaris na 7 nm bi bil boljsa izbira.
Treer ::
Zgazil gotovo ne bo, morda bo malenkost boljši v tem razredu, v tem primeru bo pač Nvidia malo spustila cene (imajo dosti lufta), ne vem pa kje ti vidiš kaki Polaris na 7nm? 8-O Tudi če gledamo teoretično in primerjamo Vego na 14 in 7nm, se lepo vidi, da Polaris 7 ne bi bil boljši od Turinga...
GCN je omejen tikitoki.
klinker ::
tikitoki je izjavil:
klinker je izjavil:
A beres?
Sej ne da primerjas low in mid end :)) vsaj dve generaciji so zadaj, pa se lahko na trepalnice postavis.
Jst ::
NE vem, zakaj se kregate glede nivoja kartic. Nvidia ni neumna...
Spet isti problem, kot pred pol leta: ko se računalnik zbudi iz spanja in predvaja video, je opazen "extreme ghosting", ne takšen, za katerega vsi veste pri igrah, ampak takšni, ki "traja par sekund". SPET je problem rdeča barva. CaseKing.de je danes dobil enako sporočilo, kot pred pol leta. MSI 2080 ima neko težavo z video komponento in rdečo barvo. Predstavljajte si, da uleti en tip v rdeči obleki in se potem še 5 sekund vidi obris njegove rdeče obleke. Če dam notri od kolega Asus, ali novo MSI, problema ni.
Napajalnik je "zlat" 850W in z multimetrom pri največji obremenitvi ne pade napetost več kot malenkost na liniji, kjer je grafa.
Prvič sem mislil, da je to one time problem, a sedaj se mi spet dogaja isto. Rdeča barva.....
Ker je od prvega servisa do danes minmilo ravno pol leta, ne vem, če bodo sprejeli garancijo... :(
D3m je izjavil:
Treee ne dojame, da 7 nm nudi 50% nizjo porabo pri istem performancu. Bomo videli kaj prinese navi, ni tko, k da bi nvidia ponudila velik napredek v zadnji generaciji. Gtx 1650 je meh in zeh.
klinker je izjavil:
klinker je izjavil:
A beres?
Sem vedel, da si nepismen, ker sam delas tocno to
  • spremenilo: tikitoki ()
Seveda ne dojame, ker to ni res. 7nm EUV bi mogoce ze, to kar pa trenutno ponuja (7nm DUV) je pa delec od tega. Kar se vidi pri vegi vii. Ali pa AMD neki hudo narobe dela.
Sicer pa AMDju niti 3nm nebi pomagal.
klinker ::
D3m je izjavil:
Wow. Na teh 7nm so dohiteli od konkurence kolko let star cip, ki je na kakih nm?
1650 je low end karta bimbo, kaj bo drugo kot meh in zeh >:D
Dr_M je izjavil:
Del o izbiri med porabo in zmogljivostjo si ocitno zgresil. Radeon vii ocitno ni zasnovan z nizjo porabo v mislih, temvec so se odlocili za max zmogljivost. Primerjava je zato nesmiselna.
klinker je izjavil:
D3m je izjavil:
Recenzije so jasne. Skip this turd. Sam ti si pac fanboy.
FlyingBee ::
Tiki, to je za sestavljene sisteme, nadomestilo za 1050 in 1050ti.
GenZNPC ::
Kako dolgo pa bo navi aktualen po izidu, preden crkne? Zaenkrat zadnje tri high-end kartice od AMDja visoko letajo pa cez nekaj mescev nizko padejo.
skibidi
Navi je mid-end in bo tako tudi ostalo.
GenZNPC je izjavil:
Polaris je aktualen se po 3 letih.
FlyingBee je izjavil:
Vem. Sam cena je bozjastna
klinker ::
Dr_M je izjavil:
klinker je izjavil:
D3m je izjavil:
Kako max zmogljivost :))
Pa prvo pometi svoj prag, fanbojcek ;)
Wrop ::
Ima prav. Manjši proizvodni proces lahko izkoristiš v nižjo porabo ali večjo zmogljivost. Odločili so se da poraba ostane skoraj ista in vse vložijo v povečanje zmogljivosti.
Treer ::
And what a splendid performance it is!
Spock83 ::
Dr_M je izjavil:
Jarno je izjavil:
A so to maloprodajne cene s stroski?
klinker je izjavil:
Dr_M je izjavil:
klinker je izjavil:
D3m je izjavil:
Si pac funkcionalno nepismen.
FlyingBee ::
Max zmogljivost, tako kot od 7970 ghz ed. naprej, pa smo tam kjer smo.
Sicer pa max. zmogljivost na 300w na 7nm pa le na nivoju gp102 iz 2016?
GenZNPC ::
Kak za boga jim ne uspe prit nad 1080Ti z 7nm...
skibidi
Treer ::
S custom vodnim, powermodom in božjastno porabo celo jim...dokler tudi 1080Ti ni navita :));((
GenZNPC ::
Torej si kupis najdrazjo AMD grafo, pol pa se en kup dnarja zmeces v predelavo, da dobis nekaj kar ima konkurenca out of the box in hkrati tvegas, da jo unicis v roku nekaj mescev pa se pozvizgas se na garancijo... dvignes porabo do onemoglosti in ce imas sreco bo celo stabilno xD
Nice !
skibidi
Treer ::
GenZNPC je izjavil:
Nice !
More like...nekaj tednov:
https://www.techpowerup.com/forums/thre...
Post 1 in potem (fittingly) post 13 :))
Wrop ::
To grafo kupiš za 64FP računske potrebe.
Potlej je pa še odvisno od igre.
Treer ::
Še highlighti tistega linka zgoraj:
skline00
Mar 26, 2019
Just received the Bykski waterblock today and installed it on my Radeon VII.
Here is the data from the Render test built into the latest version of GPU-Z
Here is the data at stock settings (Wattman at manual)
I have been running the Render test for @15 minutes.
These are max readings
GPU clock 1803 Mhz
Mem Clock 1015 Mhz
To say I'm thrilled is an understatement.
skline00
Mar 31, 2019
YOU bet. I switch to my MO-RA3 420 pro rad and I w2as able to run Firestrike at 2100 core
skline00
Apr 22 at 9:31 PM
Had to RMA my gpu:(
Are you an idiot?
AMD najavil Radeona RX 5700 XT (strani: 1 2 3 4 5 6 7 )
33986131 (77568) Mr.B
nakup grafične v letu 2019 (strani: 1 2 3 4 5 6 )
26768649 (61883) Glugy
AMD Navi in EPYC 2 prispeta v tretjem četrtletju (strani: 1 2 3 )
Oddelek: Novice / Rezultati
10226407 (23861) Mr.B
Nvidia prinaša podporo DXR raytracingu na kartice GTX (strani: 1 2 3 )
12238358 (34787) Cange
