Forum » Kaj kupiti » Nadgradnja!
Nadgradnja!
element ::
No takole, taka je ta reč. Imam plato DFI P2XBL za slot1 in na njej p2 400. Mene zanima, kok dobim, če to dvoje prodam, pa na kaj nej nadgradim? Ciljam na DURONA in PLATO zanj. Nočem dat za to velik keša, ker tako al tako dobim novga TB 1.2ghz
, rabm še en delujoč dost zmogljiv računalnik za ne preveliko ceno. GeForce 2mx je mal predobra za p2 400, zato iz nje ne morem stisnt vsega. Ta dva računalnika bom nato povezal, za direktno nabijanje iger z mojimi frendi. Doma mam še P2 350, ki mi bo služu kot server (pa ta p2 350 zdej ni tema zato mi ne o tem). Mene samo zanima, kera plata, da bo dobra za navijat durončka, pa ne predraga, kot kaka abit kt7a, ki stane 45000, pa kerga durona kupit?
element ::
Aja pa še tole, podatki od moje zdejšne plate:
Chipset
Intel 440BX AGPset
CPU Socket
Slot 1
CPU Supported
Pentium(R) III 500E-700E*/100MHz
Pentium(R) III 450-600MHz/100MHz
Pentium(R) II 350-450MHz/100MHz
Pentium(R) II 233-333MHz/ 66MHz
SEPP Celeron™ 266-433MHz/66MHz
Memory
3 DIMM sockets
max. 384MB (unbuffered)
max. 768MB (registered)
Supports PC133 and ECC
PCI IDE
Dual PIO mode 3/4 EIDE channels up to 4 IDE devices
UltraDMA/33 transfer rate up to 33MB/sec
Super I/O
2 x NS16C550A compatible UARTs
1 x SPP/ECP/EPP parallel port
External Connectors
2 x USB, 2 x DB-9, 1 x DB-25, 1 x PS/2 Mouse, 1x PS/2 Keyboard
Internal Connectors
1x IrDA, 2x IDE, 1x Floppy, 1x ATX Power, 3 x Fan, 1 x SB-Link, 1 x WOL
Power Management
ACPI and OS direct power management
Wake-on events : RTC/Modem/LAN/KB/Mouse
Hardware Monitor
System, Processor Temperature, Voltage and Fan speed
Expansion Slots
1 AGP slot
3 PCI slots
2 ISA slots
1 PCI/ISA slot
BIOS
Award / 2Mbit
Form Factors
ATX, 4 layers
30.48cm x 17 cm
12.0 inch. x 6.7 inch.
Chipset
Intel 440BX AGPset
CPU Socket
Slot 1
CPU Supported
Memory
3 DIMM sockets
PCI IDE
Super I/O
External Connectors
Internal Connectors
Power Management
Hardware Monitor
Expansion Slots
1 AGP slot
3 PCI slots
2 ISA slots
1 PCI/ISA slot
BIOS
Award / 2Mbit
Form Factors
ATX, 4 layers
30.48cm x 17 cm
Pretorijanec ::
Zdej ce hocs Durona pa lepo plato zanj nabau EPOX 8KTA3 ATA100 ATX za ene 38000 SIT. Ce pa bos obdrzu proc pa nabau BE6-II. Nove naus najdu, ti jo bo pa kdo prodau rabljeno.
element ::
Procesorja ne misli obdržat, ker ga bom prodal skupaj s plato. Kok bi dubu za plato + proc. Nabavit mislim rableno. Procesor rabim pa mal močnejši od 400mhz!
38000sit je pa kr dost, pol pa še en duron 700 je 17000sit, pa je to oboje skup 56000sit - ene 27000sit za P2+plata = 28.000sit stroška. Tok bom pa že skup naprasku, razen, če mate kakšno boljšo rešitev?
VASkO ::
jaz prodajam Epox 8kta+ (navijanje z mnozilnikom, voltaza), vec specifikacij si poglej na njihovi domaci strani!
Plata dela, prodam za 27 jurjev, stara je 4 mesce.
element ::
Ej VASkO, ok bom nabavu, sam to mi povej, če se da na njej dobr navijat, in voltažo spreminjat in FSB navijat?
VASkO ::
cip je kt133, zato FSB gre "samo" do 107mhz stabilno (vse kt133 plate), ma poglej si uradno stran, da bos vedo, kaj prodajam sploh. Drugace pa navijati gre lepo fajn, BIOS je zrel, plata je stabilna (niti enkrat vsipala).
| » | 133 or 133aOddelek: Pomoč in nasveti | 1917 (1587) | Dalmatinc |
| » | Kaj kupt (proc., plata, ram)?Oddelek: Kaj kupiti | 3005 (2349) | Enzo77 |
| » | Priporočam: barvanje L7 mostičkovOddelek: Navijanje | 2046 (1680) | Zucko |
| » | Kaj se bol izplača Epox ali SoltekOddelek: Kaj kupiti | 2276 (2033) | Kaiser |
| » | Soyo????Oddelek: Kaj kupiti | 2323 (2259) | piko |
