Forum » Kaj kupiti » Soyo????
Soyo????
piko ::
A se dobi sploh v sloveniji?? Vem da ga je mela ISKRA RAČUNALNIKI, ampak no more
Plate me zanimajo!
Plate me zanimajo!
piko ::
Nobeno slo računalniško podjetje jih nima v ceniku, zato predvidevam, da jih v sloveniji vec ni za dobit!?!
So pa zelo ugodne:
SY-6BA+ 100
DESCRIPTION
66/100/133*MHz FSB Slot 1 Based IntelŽ 440BX ATX Motherboard
PROCESSOR
133MHz FSB PentiumŽ III Processors 600/667/733/800+ MHz
100MHz FSB PentiumŽ III Processors 450/500/550/600 MHz
100MHz FSB PentiumŽ II 350/400/450 MHz
66MHz FSB PentiumŽ II 233/266/300/333 MHz
66MHz FSB CeleronŽ Processors 266~300MHz
66MHz FSB CeleronŽ Processors 300A~433 MHz
with integrated 128KB full speed L2 cache
FRONT SIDE BUS OPTIONS
Available FSB options of 66/ 75/ 81/ 83/ 90/ 95/ 100/ 105/ 110/ 112/ 113/ 115/ 117/ 118/ 120/ 122/ 124/ 126/ 133/ 135/ 137/ 138/ 140/ 142/ 144/ 150/ 155/166MHz
AUTO PCI CLOCK
The PCI bus speed is automatically set between
30MHz and 41MHz regardless of FSB setting.
ADJUSTABLE CPU CORE VOLTAGE
CPU Core voltage may be increased in increments of 2.5%, 5%, 7.5%, and 10%.
CHIPSET
Intel 82440BX two chip AGPset
SYSTEM MEMORY
4 x 168 pin SDRAM DIMM Support up to 1GB (4 x 256MB Modules with 16Mx8/16Mx4 chips only)
PC100 DIMM support
Provides ECC (Error Checking Correction) capability
EXPANSION SLOTS
5 x 32 bit Bus Mastering PCI slots (v2.1 compliant)
2 x 16 bit ISA slots (One PCI/ISA Shared slot)
1 x 32 bit AGP slot (v1.0 compliant) AGP 1x/2x
ON BOARD ULTRA I/O CHIP
ITE 8671F-A chip
2 RS-232 Serial Ports (16550 UART compatible)
1 Parallel Printer Port (SPP/EPP/ECP mode)
1 FDD port (supports LS120, 3 mode, 1.2/1.44/2.88 MB FDD)
Provides IrDA port with optional cable for transceiver
TWO ULTRA DMA-33 & 100 IDE PORTS
Supports four independent channels for 8 IDE devices
Two channels support up to PIO mode 4 & UDMA 33
Two channels support up to ATA-100
4 PCI bus mastering ATA E-IDE ports
HIGHPOINT HPT370 CONTROLLER
Supports IDE RAID 0, 1 & 0+1 function
BOARD DIMENSIONS
4 Layer PCB, 30.5cm x 19cm(12" x 7.5")
ATX form factor
BOOT-BLOCK FLASH BIOS
Award PCI BIOS with green, ACPI, APM, plug and play, DMI functions and Year 2000 compliant
Supports multi-boot from E-IDE/SCSI/CD-ROM/FDD/LS120/ZIP
2 Mbit Flash ROM
DOUBLE STACK BACK-PANEL I/O CONNECTORS
PS/2 Mini-DIN mouse & keyboard ports
2 USB ports
2 D-Sub 9-pin male Serial ports
1 D-sub 25-pin female printer port
Enhanced PC Health Monitoring
On-board voltage monitors for CPU Vcore, VTT, +5v, +12V, 3.3V, 5VSB and battery low
CPU fan four speed control and monitor
FAN speed monitor
Precision CPU temperature monitoring through CPU on-die thermal diode
FCC CLASS B AND CE EMI REGULATION COMPLIANT
Na hrvaškem "samo" 109 USD (brez PDV)
So pa zelo ugodne:
SY-6BA+ 100
DESCRIPTION
PROCESSOR
AUTO PCI CLOCK
CHIPSET
SYSTEM MEMORY
PC100 DIMM support
EXPANSION SLOTS
ITE 8671F-A chip
BOARD DIMENSIONS
ATX form factor
2 Mbit Flash ROM
2 USB ports
FAN speed monitor
| » | Qdi kinetiz 7b + Athlon 1800+Oddelek: Strojna oprema | 2319 (2126) | Blinder |
| » | ATA disk prenos + QDI Excellent 1 plataOddelek: Strojna oprema | 1691 (1641) | Daedalus |
| » | Mnenje o plati EPOX 8KRA2+Oddelek: Kaj kupiti | 1472 (1409) | Zako |
| » | Je kriva plosca za memtest errorje/nestabilnost?Oddelek: Navijanje | 2267 (2119) | AtaStrumf |
| » | Plošča QDI KinetiZ-da ali ne?Oddelek: Kaj kupiti | 1927 (1791) | Jux |
