Debian Stretch / minimum gnome desktop install
HotBurek ::
Pozdravljeni.
Namestil sem Debian 9.3, iz CDja, z minimum konfiguracijo. Po namestitivi in ponovnem zagonu pride računalnik v terminal.
Od tu naprej pa nimam več navodil, kako namestiti osnovni gnome-core paket. Kolikor se spomnim (Debian 8), sem prvo namestil startx (ter nek .rc ukaz, da gre avtomastko v grafični vmesnik), potem pa še install grafičnega vmesnika.
Prav tako sem v soruces.list dodal seznam (sources.list), pa ukaz apt-cache search gnome-core ni našel tega paketa. Poizskusil sem tudi z tasksel, pa je namestilo xfce desktop, kar ne želim.
Ali kdo pozna terminalske ukaze, za namestitev zgolj core gnome desktopa?
root@debian:/# iptraf-ng
Please resize your window
konspirator ::
sudo
apt-get update // ko si spremenil sources.list
apt-get install -f gnome-core //paket https://packages.debian.org/search?keyw...
HotBurek ::
Sem naredil nov install in potem:
apt-get install xserver-xorg xserver-xorg-core xfonts-base xinit --no-install-recommends
apt-get install gnome-session gnome-shell gnome-themes gnome-terminal gnome-control-center --no-install-recommends
apt-get install gdm3 --no-install-recommends
Po ponovnem zagonu se zažene gui, kjer dobim sporočilo "Oh no! Something has gone wrong" in Log Out button. What to try next?
konspirator ::
log od desktopa bo potrebno pogledati
https://unix.stackexchange.com/question...
how to install gui for debian
https://superuser.com/questions/507241/...
X Windows server je nameščen ?
Minimal GNOME 3 Install on Debian (jessie)
https://mike632t.wordpress.com/2016/05/...
If you want a typical yet basic desktop based on the very popular GNOME, install gnome-core
https://github.com/neurite/debian-setup...
startx vržeš v /etc/rc.local , predzadnjo vrstico pred exit.
HotBurek ::
startx se ne požene, ampak ga prekine.
V log fajlu (/var/log/Xorg.x.log) imam nekaj (EE) vrstic. Med drugim:
(II) AIGLX: Screen 0 is not DRI2 compatible
(EE) GLX: could not load software renderer
(II) GLX: no usable GL providers found on screen 0
Je to grafična pa driverji? Ker na istem PCju mi dela Debian8 b.p.
konspirator ::
Kaj pravi "glxinfo ?
HotBurek ::
glxinfo mi je vrnil nek error. Sem naredil še en reinstall...
Kar sem ugotovil je, da mi je med recommended dalo tudi paket libgl1-mesa-dri. File, katerega startx ni našel, se je nahajal v folderju /usr/lib64/dri, dri folder pa sploh ni obstajal.
Tako da sem namestil gnome in pakete, ki so bili pod recommended. Pa sedaj dela grafični vmesnik :) Hvala za pomoč.
Ozric ::
Mal pozno sicer, pa vendar... sam precejkrat inštaliram minimal gnome s sledečimi paketi: gnome-shell nautilus gnome-terminal guake gnome-tweak-tool gnome-control-center xdg-user-dirs gdm
Vprašanja ob Debian inštalaciji
Oddelek: Operacijski sistemi
412239 (1867) Icematxyz
Debian Gnu/Linux kot workstation (strani: 1 2 3 4 … 37 38 39 40 )
1960128027 (43701) RedDrake
Ubuntu compiz
162319 (1996) Loaded
X window na Debianu mi ne dela
91838 (1757) roscha
Ubuntu - par vprašanj
252818 (2236) 64202
