Ubuntu težave pri nameščanju novih programov
i33a ::
Pozdravljeni, uporabljam Ubuntu 16.04 in imam težave pri namestitvi novih programov na računalnik.
Namestiti hočem npr. program Shutter po navodilih: https://www.howtoinstall.co/en/ubuntu/x...
Vendar mi že ukaz sudo apt-get update vrne ogromno warning-ov in errorjev.
Ko poženem ukaz: sudo apt-get install shutter pa mi javi napako: E: Unable to locate package shutter.
Bi mogoče znal kdo pomagati?
Napake ob izvajanju sudo apt-get update
Ign:1 http://ppa.launchpad.net/colingille/freshlight/ubuntu xenial InRelease
Ign:2 http://download.opensuse.org/repositories/home:/Horst3180/xUbuntu_16.04  InRelease
Get:3 http://download.opensuse.org/repositories/home:/Horst3180/xUbuntu_16.04  Release [1007 B]
Hit:4 http://ppa.launchpad.net/kubuntu-ppa/backports/ubuntu xenial InRelease
Ign:5 http://dl.google.com/linux/chrome/deb stable InRelease
Get:6 http://download.opensuse.org/repositories/home:/Horst3180/xUbuntu_16.04  Release.gpg [481 B]
Hit:7 http://ppa.launchpad.net/nilarimogard/webupd8/ubuntu xenial InRelease
Hit:8 https://deb.opera.com/opera-stable stable InRelease
Hit:9 http://ppa.launchpad.net/numix/ppa/ubuntu xenial InRelease
Hit:10 http://dl.google.com/linux/chrome/deb stable Release
Ign:6 http://download.opensuse.org/repositories/home:/Horst3180/xUbuntu_16.04  Release.gpg
Hit:11 http://download.opensuse.org/repositories/home:/Horst3180/xUbuntu_16.04  Packages
Hit:12 http://ppa.launchpad.net/octave/stable/ubuntu xenial InRelease
Hit:13 http://apt.nylas.com/ubuntu vivid InRelease
Hit:14 http://ppa.launchpad.net/otto-kesselgulasch/gimp/ubuntu xenial InRelease
Hit:15 http://ppa.launchpad.net/papirus/papirus/ubuntu xenial InRelease
Ign:16 http://ppa.launchpad.net/skunk/pepper-flash/ubuntu xenial InRelease
Hit:18 http://ppa.launchpad.net/teejee2008/ppa/ubuntu xenial InRelease
Ign:19 http://ppa.launchpad.net/colingille/freshlight/ubuntu xenial Release
Ign:20 http://ppa.launchpad.net/skunk/pepper-flash/ubuntu xenial Release
Ign:21 http://ppa.launchpad.net/colingille/freshlight/ubuntu xenial/main amd64 Packages
Ign:22 http://ppa.launchpad.net/colingille/freshlight/ubuntu xenial/main i386 Packages
Ign:23 http://ppa.launchpad.net/colingille/freshlight/ubuntu xenial/main all Packages
Ign:24 http://ppa.launchpad.net/colingille/freshlight/ubuntu xenial/main Translation-en_US
Ign:25 http://ppa.launchpad.net/colingille/freshlight/ubuntu xenial/main Translation-en
Ign:26 http://ppa.launchpad.net/colingille/freshlight/ubuntu xenial/main amd64 DEP-11 Metadata
Ign:27 http://ppa.launchpad.net/colingille/freshlight/ubuntu xenial/main DEP-11 64x64 Icons
Ign:28 http://ppa.launchpad.net/skunk/pepper-flash/ubuntu xenial/main amd64 Packages
Ign:29 http://ppa.launchpad.net/skunk/pepper-flash/ubuntu xenial/main i386 Packages
Ign:30 http://ppa.launchpad.net/skunk/pepper-flash/ubuntu xenial/main all Packages
Ign:31 http://ppa.launchpad.net/skunk/pepper-flash/ubuntu xenial/main Translation-en_US
Ign:32 http://ppa.launchpad.net/skunk/pepper-flash/ubuntu xenial/main Translation-en
Ign:33 http://ppa.launchpad.net/skunk/pepper-flash/ubuntu xenial/main amd64 DEP-11 Metadata
Ign:34 http://ppa.launchpad.net/skunk/pepper-flash/ubuntu xenial/main DEP-11 64x64 Icons
Err:21 http://ppa.launchpad.net/colingille/freshlight/ubuntu xenial/main amd64 Packages
  404  Not Found
Err:28 http://ppa.launchpad.net/skunk/pepper-flash/ubuntu xenial/main amd64 Packages
  404  Not Found
Fetched 1488 B in 6s (227 B/s)
Reading package lists...
W: GPG error: http://download.opensuse.org/repositories/home:/Horst3180/xUbuntu_16.04  Release: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 5A7D1D38BEB6D886
W: The repository 'http://download.opensuse.org/repositories/home:/Horst3180/xUbuntu_16.04  Release' is not signed.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
W: The repository 'http://ppa.launchpad.net/colingille/freshlight/ubuntu xenial Release' does not have a Release file.
W: The repository 'http://ppa.launchpad.net/skunk/pepper-flash/ubuntu xenial Release' does not have a Release file.
E: Failed to fetch http://ppa.launchpad.net/colingille/freshlight/ubuntu/dists/xenial/main/binary-amd64/Packages  404  Not Found
E: Failed to fetch http://ppa.launchpad.net/skunk/pepper-flash/ubuntu/dists/xenial/main/binary-amd64/Packages  404  Not Found
E: Some index files failed to download. They have been ignored, or old ones used instead.
Najlepša hvala za pomoč.
GupeM ::
Ne vem, od kje imaš te repozitorije. Poglej tole.
Ozric ::
Uff, repo konfuzija. Popucaj malo.
i33a ::
Sem sledil navodilom na linku in uspešno izbrisal star file.
Ob izvajanju naslednjega ukaza pa dobim Segmentation fault.
sudo -i software-properties-gtk
Invalid MIT-MAGIC-COOKIE-1 keyFailed to connect to Mir: Failed to connect to server socket: No such file or directory
Unable to init server: Could not connect: Connection refused
/usr/lib/python3/dist-packages/softwareproperties/gtk/SoftwarePropertiesGtk.py:40: PyGIWarning: Gdk was imported without specifying a version first. Use gi.require_version('Gdk', '3.0') before import to ensure that the right version gets loaded.
  from gi.repository import GObject, Gdk, Gtk, Gio, GLib
/usr/lib/python3/dist-packages/softwareproperties/gtk/SoftwarePropertiesGtk.py:40: PyGIWarning: Gtk was imported without specifying a version first. Use gi.require_version('Gtk', '3.0') before import to ensure that the right version gets loaded.
WARNING:root:could not open file '/etc/apt/sources.list'
(software-properties-gtk:7386): Gtk-CRITICAL **: gtk_settings_get_for_screen: assertion 'GDK_IS_SCREEN (screen)' failed
/usr/lib/python3/dist-packages/softwareproperties/gtk/utils.py:29: Warning: g_object_get_qdata: assertion 'G_IS_OBJECT (object)' failed
  self.builder.add_from_file(path)
Segmentation fault (core dumped)
Kaj lahko naredim v tem primeru?
i33a ::
PS. Ugotovil sem, da se Seg. fault dogaja le, če izvajam kot sudo.
@Ozric: Kako naj popucam? Imaš kak nasvet?
Tudi sam bi rad, da ne bo več take konfuzije in bo vse lepo clean :)
janezvalva ::
instaliraj app grid, bo vse avtomatsko
http://www.appgrid.org/
Apple ::
A ni "seg. fault" signal, da je disk corrupted in s tem tudi fajli?
LP, Apple
Ozric ::
Ales ::
Apple je izjavil:
Ne, ni.
Apple ::
Men se je na RPiju zacela pojavljat ta napaka, ko mu je zmanjkal stroma.
LP, Apple
GupeM ::
Možno, ampak to še ne pomeni, da je disk fuč. Segmentation fault pomeni, da je nek program hotel dostopati do dela pomnilnika, do katerega nima dostopa. Načeloma se to lahko zgodi tudi zaradi pokvarjenega diska, običajno pa to ni razlog.
i33a ::
Disk je precej nov SSD in dvomim, da je v tem težava.
Hvala vsem za pomoč. Sem se zaradi teh in še zaradi nekaterih drugih težav odločil za ponovno namestitev linux-a.
Glede na to, da imam SSD.. mi priporočate, da dodam swap particijo ali bolje da ne zaradi obrabe diska?
(Imam Samsungov SSD 256GB, kupljen letos)
konspirator ::
Pri win zna biti (včasih) težava , če ne nastaviš na vsaj 256 mb (tudi če imaš 8/16/32 gb rama).
Za swap pri linux ne potrebuješ dodatne particije, je lahko kar v "fajl" v /mnt/swap.
Nastavi prvo brez, če dela sistem/aplikacije ok, potem ga ne potrebuješ, drugače eventuelno naknadno vklopiš.
https://www.cyberciti.biz/faq/linux-add...
https://wiki.archlinux.org/index.php/sw...
Pri prvem postu bi si moral sneti certifikate. Vsak repositorxy ima svoj key. In ti si ga moraš naložiti. Poguglaj...
Pri drugi napaki si zgleda preveč zadev zbrisal. manjka ti nekaj filov.
Nauči se brati napake, ki ti jih vrnejo programi in jih skopirati v Google search.
Phishing at its best
213876 (2685) francek1
Kako install-erati programe ?
71033 (794) b3D_950
Ubuntu 10.10 - 10 Out Of 10 (strani: 1 2 3 4 … 19 20 21 22 )
Oddelek: Operacijski sistemi
1093203019 (160612) Icematxyz
Odličen program za backup podatkov
Oddelek: Programska oprema
132288 (1868) poweroff
Na voljo Ubuntu skladišča za Vidalio in Mixminion
Oddelek: Novice / Zasebnost
104941 (4253) poweroff
