Forum » Programiranje » Routed Events WPF [C#]
Ciklamen ::
Čao
Nikakor ne morm pogruntat kako routed eventi delujejo, še posebej na primeru, ko imaš nek stack panel in na njega šopaš user controle z nekimi informacijami in gumbom in ko pritisneš na ta gumb, se bi morale te informacije oziroma ta objekt (recimo) shranit v listo.
Se pravi kontrola:
To je pa še main window
Upam da je kolk tolk jasno kaj bi rad, sem pa pregledal že večino linkov na temo routed eventov, ampak nekako ne morem razvozlat zadeve :)
Se pravi kontrola:
<UserControl x:Class="WpfApplication1.Kontrola"
xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
xmlns:local="clr-namespace:WpfApplication1"
mc:Ignorable="d"
d:DesignHeight="250" d:DesignWidth="150">
<Grid>
<Grid.Background>
<LinearGradientBrush EndPoint="0.5,1" StartPoint="0.5,0">
<GradientStop Color="#FF551717" Offset="0"/>
<GradientStop Color="#FFD66565" Offset="1"/>
</LinearGradientBrush>
</Grid.Background>
<Label x:Name="nameL" Content="Name" HorizontalAlignment="Left" Margin="10,10,0,0" VerticalAlignment="Top"/>
<Label x:Name="surnameL" Content="Surname" HorizontalAlignment="Left" Margin="10,30,0,0" VerticalAlignment="Top"/>
<Label x:Name="ageL" Content="Age" HorizontalAlignment="Left" Margin="10,50,0,0" VerticalAlignment="Top"/>
<Label x:Name="genderL" Content="Gender" HorizontalAlignment="Left" Margin="10,70,0,0" VerticalAlignment="Top"/>
<Label x:Name="addNameL" HorizontalAlignment="Left" Margin="93,10,0,0" VerticalAlignment="Top"/>
<Label x:Name="addSurnameL" HorizontalAlignment="Left" Margin="93,30,0,0" VerticalAlignment="Top"/>
<Label x:Name="addAgeL" HorizontalAlignment="Left" Margin="93,50,0,0" VerticalAlignment="Top"/>
<Label x:Name="addGenderL" HorizontalAlignment="Left" Margin="93,70,0,0" VerticalAlignment="Top"/>
<Image x:Name="faceImage" HorizontalAlignment="Left" Height="100" Margin="25,100,0,0" VerticalAlignment="Top" Width="100" Stretch="Fill"/>
<Button x:Name="addButton" Content="Add" HorizontalAlignment="Left" Margin="37,225,0,0" VerticalAlignment="Top" Width="75" />
</Grid>
</UserControl>
namespace WpfApplication1
/// <summary>
/// Interaction logic for Kontrola.xaml
/// </summary>
public partial class Kontrola : UserControl
public static readonly RoutedEvent clickedButtonEvent =
EventManager.RegisterRoutedEvent("ButtonClickEvent", RoutingStrategy.Bubble, typeof(RoutedEventHandler), typeof(Kontrola));
public Kontrola()
InitializeComponent();
public event RoutedEventHandler Clicked
add { AddHandler(clickedButtonEvent, value); }
remove { RemoveHandler(clickedButtonEvent, value); }
/// <summary>
/// Interaction logic for MainWindow.xaml
/// </summary>
[XmlRoot("PeopleProfiles")]
public class PeopleProfiles
[XmlElement("Person")]
public List<Person> persons { get; set; }
public class Person {
[XmlElement("Name")]
public string Name { get; set; }
[XmlElement("Surname")]
public string Surname { get; set; }
[XmlElement("Age")]
public int Age { get; set; }
[XmlElement("Gender")]
public string Gender { get; set; }
[XmlElement("Image")]
public string Image { get; set; }
public partial class MainWindow : Window
public MainWindow()
LoadAllPersons("All");
public void LoadAllPersons(string info)
personWrap.Children.Clear();
XmlSerializer serializer = new XmlSerializer(typeof(PeopleProfiles));
using (FileStream stream = File.Open("people.xml", FileMode.Open))
PeopleProfiles pp = (PeopleProfiles)serializer.Deserialize(stream);
foreach (Person p in pp.persons)
if(info=="All") {
Kontrola k = new Kontrola();
k.addNameL.Content = p.Name;
k.addSurnameL.Content = p.Surname;
k.addAgeL.Content = p.Age;
k.addGenderL.Content = p.Gender;
k.faceImage.Source = new BitmapImage(new Uri(p.Image, UriKind.Relative));
personWrap.Children.Add(k);
else
if (p.Gender == info) {
public static void DumpException(Exception ex)
Console.WriteLine("--------- Outer Exception Data ---------");
WriteExceptionInfo(ex);
ex = ex.InnerException;
if (null != ex)
Console.WriteLine("--------- Inner Exception Data ---------");
WriteExceptionInfo(ex.InnerException);
public static void WriteExceptionInfo(Exception ex)
Console.WriteLine("Message: {0}", ex.Message);
Console.WriteLine("Exception Type: {0}", ex.GetType().FullName);
Console.WriteLine("Source: {0}", ex.Source);
Console.WriteLine("StrackTrace: {0}", ex.StackTrace);
Console.WriteLine("TargetSite: {0}", ex.TargetSite);
private void comboBoxGender_SelectionChanged(object sender, SelectionChangedEventArgs e)
ComboBoxItem box = (ComboBoxItem)comboBoxGender.SelectedItem;
string item = box.Content.ToString();
LoadAllPersons(item);
private void summaryButton_Click(object sender, RoutedEventArgs e)
summary sum = new summary();
sum.ShowDialog();
private void btn_Click(object sender, RoutedEventArgs e)
RaiseEvent(new RoutedEventArgs(Kontrola.clickedButtonEvent));
- End of the Post ->
| » | Visual C# problemOddelek: Programiranje | 3979 (3151) | mladec |
| » | c# seminarskaOddelek: Programiranje | 3610 (3283) | tuned |
| » | [C#] DeserializacijaOddelek: Programiranje | 2355 (1958) | Cvenemir |
| » | Povezani seznamOddelek: Programiranje | 2585 (2182) | pohano |
| » | C# tabelaOddelek: Programiranje | 1383 (1235) | Mitja Bonča |
