Forum » Strojna oprema » Enermax 660W
Enermax 660W
kuglvinkl ::
review
Overall, this power supply has been a mixed bag. On the upside, this power supply is a power monster. 680W of maximum power, copper-mesh power cabling, 4 separate and highly stable 12V power lines, and included motherboard adapters leave little to be desired when it comes to a power-hungry system. Toss in the aluminum housing, temperature controlled fans, and plenty of 4-pin Molex connectors and you’ve got a power supply that can take on almost any situation. Active PFC is the icing on the cake, and is added security for situations where there are people who would normally play with the infamous “little red switch”.
There are a few things about the power supply that warrant some looking into. First off, this power supply is long. In smaller cases, there is no question that it would be too long to install. The plethora of Molex and floppy power cables can get in the way easily if not routed right. As new as it is, I’m surprised that no Serial ATA connections or adapters were present (napaka v pošiljki!). Last but not least, the spotty performance of the VCore reading during stress testing may leave some enthusiasts wondering if this is the power supply to take their system to the next level.
- spremenil: kuglvinkl ()
jest10 ::
En napajalnik za dva računalnika hkrati
Ma čisti bul... sestavite mi mašino, ki bo potrebovala tak napajalnik
Samuel ::
frenk ::
zakva pa u majhnih kištah nebi rabu tega...ti gor dam peltierja pa comp gor peklučem pa se bo sesul
...sicer je pa prava pošast
...ko bomo prišli na 1kW bom pa jest menou napajalnik ampak zaenkrat je 420W čist dost
kuglvinkl ::
Zadeva je dobavljiva v Sloveniji. Cena? Slabih 80k SIT.
| » | Izogibajte se nakupom na buyincoins.comOddelek: Loža | 2155 (1891) | quepasa |
| » | nevihta > pc v okvariOddelek: Strojna oprema | 3882 (3135) | majlo |
| » | Nevarna strojna oprema.Oddelek: Strojna oprema | 2417 (1944) | AngelOfDeath |
| » | Napajalnik za pc???Oddelek: Strojna oprema | 1424 (1258) | mbra |
| » | Fanless Heatpipe CPU Cooling SystemOddelek: Hlajenje in modifikacije | 1765 (1467) | ferdo |
