Nov prenosnik - kontrast/grafika besedila ni ok
2
miha188 ::
Zdravo,
kupil sem nov prenosnik https://www.enaa.com/oddelki/racunalnis...
Sedaj imam težavo pri kakovosti grafike besedila in tudi nekje ikon. V windowsih in recimo google mi izpiše lepo besedilo, ostro. Ko odprem npr. Utorrent ali kakšni bannerji, tekst pod slikam - črke niso ostre, ampak malo razpacane. Kaj bi bil lahko vzrok oz. kaj moram nastaviti?
Hvala.
scaling nastavi na 100%, pa bo ok
Han ::
Ali pa menjaj program za takšnega, ki ima ikone, slike in tekst v višji ločljivosti, da se pri povečavi ohranita kvaliteta in ostrina...
miha188 ::
iloveboobz je izjavil:
Hvala, to je res pomagalo. Samo sedaj je pa besedilo tako majhno, hmmm, že prej na 125% je bilo ravno še sprejemljivo. Sedaj je pa res "cuci" :)
miha188 je izjavil:
Rabiš moderni program, potem lahko uporabljaš povečan prikaz besedila/elementov.
Npr. Office 2013 oz. starejši sploh ne podpira scaling.
http://www.thewindowsclub.com/blurry-fo...
Odlično branje na to temo:
High DPI Scaling Improvements for Desktop Applications and “Mixed Mode” DPI Scaling in the Windows 10 Anniversary Update
ST-777 ::
@miha188, v Windows 10, si lahko pomagaš z Windows10 DPI Fix
"Windows 10 is using another scaling method for DPI as in Windows Vista, 7, 8 and 8.1. At some point we can understand Windows why they changed the DPI scaling in Windows 10. It is probably ment to support mobile devices more easy. But if you like to use your Desktop as a Desktop, and you demand high quality only. Then you can use this fix until Microsoft has addressed this issue.
This fix simple tells Windows 10 to use the original DPI scaling as it was in Windows Vista, 7, 8 and 8.1. Why this is a small software program, and not some 'Registry Tweak' is because when you manually adjust the DPI settings at your 'Windows Registry'. Windows will reset your dpi settings every 2 reboots." http://windows10_dpi_blurry_fix.xpexplo...
V Windows10 DPI Fix sem izbral Use Win 8.1 DPI Scaling in nastavil DPI Scale na 150%, kar je za moj 14" prenosnik ravno prav.
miha188 ::
Hvala za tole, ko pridem domov bom prečital.
miha188 ::
ST-777 je izjavil:
Evo sem tole metodo uporabil in težave so izginile, sem dal na 125% in je super - če prav razumem, na vsako drugo prižiganje bo potrebno vsakič na novo nastaviti? Pa še ta zanimivost, če dam nad 125%, se zopet pojavijo vse težave z "razpacanim" teksti...
  • spremenil: miha188 ()
miha188 ::
Je mogoče lažje, če dam gor raje windows 7 in stvar rešena..
ST-777 ::
miha188 je izjavil:
... če prav razumem, na vsako drugo prižiganje bo potrebno vsakič na novo nastaviti?...
Ne, ker imaš Windows10 DPI Fix, ti ne bo treba na novo nastavljati.
ST-777 ::
miha188 je izjavil:
Sedaj imam Windows 10, prej sem imel Windows 7 in ne nameravam iti nazaj, Windows 10 so mi bolj všeč.
miha188 je izjavil:
Samo za opozorilo: na novih prenosnikih znajo bit problemi s starimi Windows sistemi.
miha188 ::
Ja razumem, bom poizkusil še kaj, so tudi meni Windows 10 zelo všeč, samo če bo pa to dnevno matranje, bom pa raje šel na kaj starejšega... Samo mi še vedno ni jasno, zakaj DPI Fix pri povečanju na 150% naredi zopet razpacane besede?
miha188 ::
Še tole vprašam ali je glede na specifikacije takšna slika kamerce OK?
če je to res 720p kamera, pol je tole zanič
blackbfm ::
miha188 je izjavil:
vgrajene webkamere so na splosno zanic, posebej v slabi sobni svetlobi postane slika speglana/vodenkasta..
ST-777 ::
miha188 je izjavil:
Za moj 14" prenosnik, ki ima zaslon 1920 x 1080 sem nastavil DPI Scale na 150 % in je ravno prav. Če ima tvoj prenosnik zaslon 1366 x 768 je bolje nastaviti nižji DPI.
miha188 ::
Moj računalnik je 1920x1080 in je na 150% zelo pacasto :(
miha188 je izjavil:
A to velja za cel sistem ali pa samo za določene programe?
miha188 ::
Samo za določene programe in recimo na spletnih novicah kakšne slike pri naslovih (kjer klikneš na novico).
miha188 ::
Edino, če je to problem, ker je avtomatsko na 175% nastavljeno v sistemu, v programu DPI fix imam na 125%.
miha188 je izjavil:
Aha, to je zato, ker so programi ali stari ali pa niso prilagojeni HiDPI, isto velja za spletne/strani slike, ki niso narejene tako. Na jabolčnih računalnikih so to rešili z uporabo Retina prikaza.
bambam20 ::
miha188 je izjavil:
S tvojim računalnikom neki ni ok, ker na tej resoluciji na laptopu je slika ostra ;)
miha188 ::
bambam20 je izjavil:
miha188 je izjavil:
Bom kar upal, da je težava na relaciji Windows in aplikacije, kot pa moj par dni star računalnik :)
ST-777 ::
miha188 je izjavil:
Imam nastavljeno v sistemu na 150% in v programu DPI fix na 150%, slika je v redu. Si poskusil preklapljati med ločeno in integrirano grafično kartico?
miha188 ::
ST-777 je izjavil:
miha188 je izjavil:
Teh 175% je moralo meni samo nastaviti, ker sem prej imel na 125%, preden sem pognal DPI fix.
Za preklapljanje med ločeno in int. grafično sem pa že preveč teleban, kako se to naredi?
ST-777 ::
miha188 je izjavil:
Nastavi v sistemu na enak % kot je v programu DPI fix.
V mojem prenosniku je samo integrirana grafična kartica. Če bi imel ločeno in bi želel preklapljati, bi mi bil tale članek v pomoč: https://support.serato.com/hc/en-us/art...
miha188 ::
Hvala, bom še malo preizkušal in sporočim.
miha188 ::
Sem še poizkušal nekaj stvari in ne gre. Sedaj se računalnik že pripravlja na prehod na windows 7 :)
bambam20 ::
miha188 je izjavil:
Ti tle raje reklamiraj. Več kot očitno, da je nekaj narobe z grafično, saj bi pri resoluciji 1920* 1080 moralo biti ostro vse ;).
miha188 je izjavil:
ne bluzi, če ne poznaš windows scalinga.
Končno en, ki je spoznal kako zanič so Windows 10 v resnici.
hitro nazaj na win98 potem
Egidij88 ::
Očala.
LeQuack je izjavil:
Ali pa bi bilo potrebno uporabljat moderne programe in ne starih piratskih office-ov ;)
miha188 ::
Torej Windows 10 piratski in Windows 10 originalni je razlika v kvaliteti delovanja?
miha188 je izjavil:
Ne. Razen, da se ti zna zaklenit oz. preklopi v 30-dnevno preizkusno stanje, če "fix" ne deluje.
  • spremenil: opeter ()
miha188 ::
Sem prehitro prebral tvoje mnenje o officih in ne Windowsih... Offici so pri meni čisto v redu.
Ja, ampak katero verzijo imaš? Komaj MS Office 2016 kolikor toliko pravilno prikaže DPI scaling (pa še tu so lahko problemi). Starejše verzije ne.
miha188 ::
Professional plus 2016
bambam20 ::
miha188 je izjavil:
še nisem videl laptopa z resolucijo 1920*1080 in win 10 na njemu in bi bila kakšna ikono apasana in zamegljen tekst.
  • spremenilo: bambam20 ()
V osnovi je napaka v znamki cheap-shit HP ;).
Pa ja ne misliš da bo imel laptop za manj kot 500 EUR kvaliteten FullHD zaslon ?!?!?!
  • spremenil: Invictus ()
buneech ::
FullHD na 14" ali manj privzeto preklopi na 125% ali 150% scaling. Določeni programi ne znajo tega upoštevat, in imajo zamegljen tekst. Js mam težave z Office 2016, Outlook je zamegljen, če nastavim scaling.
Če je vse na 100% je ok, ampak potem je tekst majhen na displayu notebooka.
Aja, pa tisti Win10 DPI Fix je ok, dokler ne uporabljaš dveh zaslonov. Ker tisti nastavi scaling za vse zaslone enak, in imaš na 14" ok, na 24" je pa vse preveliko.
ST-777 ::
Invictus je izjavil:
V osnovi je napaka v znamki cheap-shit HP ;). Pa ja ne misliš da bo imel laptop za manj kot 500 EUR kvaliteten FullHD zaslon ?!?!?!
Prenosnik Medion, ki sem ga kupil lansko leto za 279 € ima odličen 1920 x 1080 IPS zaslon 14" in licenčne win 10. Je pa ta akcijska cena veljala takrat le dva dni.
tudi display za 10k bo mel craptastic kvaliteto z windows scalingom.
Še en, ki mu bralno razumevanje dela hude težave
ST-777 je izjavil:
Samo Medion znamko dela Lenovo, HP pa pač HP ;).
Modri dirkač ::
ST-777 je izjavil:
Nima to neke veze, tudi lenovo ti bo za 800 € prodal crap zaslon.
Everybody lies!
djabi ::
Vseeno je, kakšen zaslon je ...
Kaj DPI scaling je in kako je mišljena "napaka" v primeru blura oz. zamegljenega prikaza zelo nazorno prikaze spodnja slika (kliknite gor, da se odpre v 100% velikosti):
Poglejte npr. besedilo, kjer piše QucikSFV has been uninstalled in primerjajte z ostalim.
miha188 ::
Potem je stvar v temu, da moraš za določene dele programov in windowsov to pač sprejeti, kot dejstvo. Sedaj me samo zanima, če bi šel na sedaj že zgodovinske Windows 7 ali ima kdo izkušnje, da tam je pa vse OK?
ST-777 ::
miha188 je izjavil:
... me samo zanima, če bi šel na sedaj že zgodovinske Windows 7 ali ima kdo izkušnje, da tam je pa vse OK?
Moje izkušnje so, da ni problemov v zvezi s prikazom slike na 23" zaslonu (1920x1080) v Windows 7 in tudi ni problemov v zvezi s prikazom slike na 14" zaslonu (1920x1080) v Windows 10.
Če domnevaš, da je tvoj problem v zvezi z Windowsi, poglej sliko v drugem OS, ki ni Windows. Na primer Linux, ki ga zaženeš iz CD/DVD: KNOPPIX.
The Five Best Linux Live CDs: https://www.linux.com/learn/five-best-l...
2
Velik monitor - slabosti? (strani: 1 2 )
5710761 (8827) Han
4K zaslon na prenosnikih
71758 (1350) sandmat
gtx 1070 + 4x monitor
294205 (3604) Modri dirkač
4k monitor (strani: 1 2 )
8422845 (19735) Voluharr
Novi Macbook Pro 15 (strani: 1 2 )
8615297 (13264) JayKay
