Disk in osveževanje podatkov
ST-777 ::
Na http://www.fact-reviews.com/info/diskfr... , kjer je predstavljen free program DiskFresh, so pisali v zvezi z osveževanje podatkov na HDD, SSD in USB ključu:
HDD:
"... computers do not typically read all the files on your hard drive, only the ones you ask them to read. Some files can stay there for years without ever being read. In the case of these files the signal could fade away completely without the drive controller ever having a chance to detect it. In order to keep the data signal from fading, you need to re-write the data. This is often known as “hard disk maintenance”, and should be done 3 or 4 times a year."
SSD, USB ključ:
"DiskFresh has a “read-only” mode that should always be used when dealing with flash drives and SSDs. ... regular “read-only” refresh is advisable, because the drive controller is programmed to look for bad signals and take action to fix the problem in much the same way as hard drive controllers do. Reading the data on a flash drive does not shorten the lifespan of the drive, and can certainly help to detect and avoid total drive failure."
Ima kdo izkušnje z osveževanjem podatkov na HDD, SSD in USB ključu?
ja, na kakšnih usb kjučih al pa poceni ssdjih to dejansko pomaga, ker flash zgublja charge in more posledično ecc bolj švicat.
Strestirate nov HDD pred uporabo?
303155 (2325) MrStein
Diski: najbolj zanesljivi HGST, najmanj WDC
Oddelek: Novice / Diski
4616723 (13875) MrStein
pomoč pri izbiri diska
354176 (3881) lovro535
sata problem .....!!!
81802 (1667) jan01
USB ključ error => disk is not formatted
194760 (4317) muzičar
