Morebitne težave z matično ploščo.
D4rkDoG ::
Imam ploščo QDI Advance 9, z njo pa imam neke probleme.:| Zdi se mi da mi skozi AGP (2x) prepusca premalo podatkov ali kako se naj izrazim. :D Potem pa mi graficna mece zelo malo FPSjev (GeForce 2 Mx400), nekatere igre laufajo super nekatere pa nikakor. :\ Zanima me če bi bilo kaj bolje če bil naložil no ve BIOSE. Hvala DarkDog [em]:D
kuglvinkl ::
tkole se zmenva: prtgen gor podatke o plati + proc, ... skrata konfiguracija. Pa povej kolk pik dobiš v 3DMarku 2001.
D4rkDoG ::
Okej bom samo najprej me je zanimalo ce bo sploh to kdo odgovoril :D
D4rkDoG ::
Evo ti podatke in pol ::D
:::::::::::::::: MATIČNA PLOŠČA :::::::::::::::
Chipset
VIA Apollo Pro 133
VIA VT82C693A North Bridge
VIA VT82C596B South Bridge
Bus Type 5 PCI slots
2 ISA slots
1 AGP 2X slot
CPU Support Socket 370 processors
Intel Pentium III FC-PGA processors at 500E/533EB/550E/600E/600EB/650/667/700/733/ 750/800MHz
Support Intel Celeron CPU at 300A/333/366/400/433/466/500/533/566/700/800MHz
On-board 1.5V,2.5Vregulators
A9 PCB3.0 mainboard Support 1.1GHz CPU
System Memory Three 168-pin 3.3V PC133 DIMM sockets
Support up to 768MB SDRAM
Support 66/100/133MHz Synchronous DRAM and 66MHz EDO
QDI Innovations RecoveryEasy,SpeedEasy,LogoEasy,
BIOS-ProtectEasy,ManageEasy
BIOS Licensed advanced AWARD BIOS
2Mb DIP Flash ROM
Support Plug and Play
Support ACPI and OS Directed Power Management
Graphics Support AGP 2X
Transfer rate up to 512MB/s
I/O Feature All I/O ports can be enabled/disabled by BIOS setup
2 USB prots support USB 1.1
1 PS/2 keyboard prot
1 PS/2 mouse port
2 high speed Serial Ports(16550 fast UART compatible)
1Enhanced parallel Port (SPP, EPP, ECP)
IrDA port supports up to 115.2KB/sec transfer rate
Advanced Feature Supports wakeup on Lan/Modem
power-on by keyboard password
Trend ChipAway Virus on Guard
PC/PCI(SB-Link)
PC-cillin with killing
Bus Speed 66/100/133MHz FSB
Over clock up to 155MHz
Selectable by both Jumper setting and SpeedEasy
Board Size 305 x 193mm (ATX)
PROCESOR :::: Celeron 733
RAMI:::: 256: 133
GRAFIČNA:::: GeForce 2 Mx400
Točke v 3dMarku še sledijo:D :D
kuglvinkl ::
Če imaš v rangu od 2200-2600 pi, pri nastavitvah v igrah preveč ceniš svojo kišto.
D4rkDoG ::
Ja v 3DMarku sem dobil 1100 točk. To se mi zdi nekam malo ali ni ? :\
kuglvinkl ::
Ja, malo je. Vrzi gor VIA 4in1 pack, recimo zadnje uradne Detonatorje, pred vsem tem pa poglej, če nimaš vklopljenega AA ali AF.
Lahko pa da je kakšen specifičen keč s plato. Skratka, najprej pošlihtaj driverje za plato.
boštjan ::
kere so te,ki laufajo super in kere ne. Pa upam da ne boš napiso,da ti stare igre laufajo super, nove pa ne.
D4rkDoG ::
LOL. Ja recimo GTA 3 ali pa Vice City se kar dobro recimo tam 20 fraimov recimo Fifa 2002 pa full slabo moj sosed ma iste konfiguracije pa mu vse boljse dela tako da ne vem ne. :D
boštjan ::
ne glede kere detonatore maš naložene isto špila?
D4rkDoG ::
Ja za graficno mam zadnje detonatorje. Ja pa za vse je isto mogoce je malo razlike. Kaj pa si ti milsil z AA , AF :D
boštjan ::
mislo je,če maš te efekte vklopljene
novi ::
Najprej si tole naloži Gelj pod naslovom "Memory interleave enabler for VIA chipsets" (pa prej preberi read.me). Ta zadevica je men prinesla kar 1000 točk.
Pol pa še mal proc navi, pa boš mogoče še kej višje prišel. Mam plato z istim chip set-om samo je ABIT pa Gforce 2 ultra pa 900@1200MHz in imam tam do 3000 tock.:D
  • spremenil: novi ()
D4rkDoG ::
alo novi to naložim skozi winse ali v dosu prosum da mi poveš hvala :D
novi ::
Kar startaj v windowsih pol pa restart in to je to. Men dela z občasnimi blue screen-i! Enkrat mesečno... Če tege program nimam gor blue screen-ov ni samo dela opazno pošasneje tudi z običajnem delu; acad,...
Baje se ti lohk full zalomi in sploh ne bo štartov w win, samo tega še niem slišal iz prve roke. Tako,dfa kar nainštaliraj in poročaj o uspehu,...
D4rkDoG ::
To bi se naj poznali v igrah tudi pri FPSjih in pri Winsih v navadnem delu ??
:D
D4rkDoG ::
Ja zdaj dobim v 3DMArku 2001 1500 točk. Tako da je verjetno kaj pomagalo tisto ko si mi povedal. Hvala ti !!! :D
novi ::
Če imam tega enabler-ja naloženega mi v ACAD-u veliko hitreje obrača zahteven 3D objekte. PhotoShop mi prej retrusira sliko,... Zmerjeno z stoparico v PhotoShop-u.
Se mi pa recimo 1x mesecno pojavi blue screen, kar se mi prej ni dogajalo ;(( .
D4rkDoG ::
Misliš da bi bilo veliko bolje ce bi flashal BIOSE? Ali še veš morda kako finto da bi delalo bolje?? :D
novi ::
Misliš da bi bilo veliko bolje ce bi flashal BIOSE!
Ti kar nadgradi bios nimaš kej zgubit.
Ostane ti samo še navijanje procesorja ali pa nabava novega računalnika :D .
Lohk si pa še pprebereš tole prigodo!
D4rkDoG ::
Alo meni se dogajajo približno iste stvari kot tebi. Neglede na kaki resuluciji mam enako šteka. Tako da sma na bribližno istem. Edno Counter strike mi gre 60 fpsjev na srečo ker to je moja najboljsa igra. :D
D4rkDoG ::
Stari ce meni to rata ko je tebi si car ne. Tako da bom probal naredit kar si ti kolko pik maš ti zdaj v 3dmarku 2001???? :D
D4rkDoG ::
Hmmm... V igra bistveni napredek tako da zdaj lahko vecino iger spilam brez problema. V 3dMarkeru pa 1700 tock 600 tock napretka bolje kot nic samo mislim da sem nekaj zgresil. Voltaže nisem spreminjal samo grafikuljo sen navil jedro iz 200 na 225. Samo da lahko igre spilam. :D Drugace se pa ti zahvaljujem za tvoj trud in delo, še se priporačam. :D Ce ga rabis se ti na voljo. HVALA AjDe DarkDog` >:D
Qdi kinetiz 7b + Athlon 1800+
62326 (2133) Blinder
Max velikost HDD
71480 (1336) micron1
Ali je to vse kar zmore moj Računalnik?
152530 (2184) novi
Plošča QDI KinetiZ-da ali ne?
81936 (1800) Jux
QDI plata
61691 (1616) Koci
