Forum » Strojna oprema » QDI plata
QDI plata
UglyKid ::
Zanima me kako se kej QDI plate odnesejo pri navijanju , ker mam eno QDI plato APOLLO 5/133 in me zanima če ta plata podpira navijanje.
hvala za pomoč
hvala za pomoč
Mejte se radi in delajte slovenske otroke.
ABX ::
Zelo omejeno ker ne podpiran menjavo napetosti. Poleg tega chipset smrdi zato bodi vesel da dela lepo na default nastavitvah.
yjj ::
QDI jeve plate so zelo slabe pri navijanju. Poišči si kakšno duugo saj proizvajalcev kar mardoli npr.: Abit, Epox, GA, ASUS, MSI
UglyKid ::
Sej se mi je kr zdel, da so me "nategnil"
s to plato.
Zgleda da si bom mogu omislt novo. Kaj priporočate za mal dnarja?
s to plato.
Koci ::
Sem se potrudu in ti poiskal njene specifikacije:
CPU Support PII, PIII and Celeron CPU.
Multiplier Support x2 up to x8
Bus Speed 66/100MHz
133/144/155MHz
Clock chip IC_Work W196G(28Pin) with IIC Clock Driver
IC_Work W40S11-23G(28Pin) with IIC SDRAM Buffer
Chipset VIA Apollo Pro 133 Chipset
VT82C693A North Bridge can support 66/100/133MHz CPU Front Side Bus
VIA VT82C596B South Bridge supporting:
1.Independent timing of up to 4 drives
2.PIO mode 4 transfers up to 14MB/sec
3.Support ATA 33/66 synchronous DMA mode transfers up to 66MB/Sec
4. Integrated 16x32bit buffer for IDE PCI Burst Transfers
5.Two USB ports
System Memory Three 168pin 3.3V unbuffered 66/100/133MHz DIMM socket
Support 8MB to 768MB SDRAM memory
BIOS Licensed advanced AWARD BIOS, 2MBit flash Rom, Plug and Play ready
Full supports for ACPI specification and OS directed power management
Support SpeedEasy, LogoEasy, ManageEasy, BIOS-ProtectEasy and RecoveryEasy.
I/O Feature Winbond W83977 EF I/O chip
All I/O ports can be Enabled/Disabled by BIOS setup
One floppy port supports up to two 3.5’’ or 5.25’’ floppy drivers
Supports LS-120 floppy disk driver and ZIP drive
Two high speed 16550 fast compatible UARTs(COM1/COM2/COM3/COM4 selectable)
One enabled parallel port(SPP/EPP/ECP)
IrDA port support up to 115.2KB/Sec transfer rate
Support APM&ACPI, P&P 1.0A compatible
Bus Type 4 PCI local bus slots
3 ISA slots
1 AGP slot
Advanced Feature Support ManageEasy (Manufacturing option)
On board LM80 supports system monitoring(monitor system voltage & temperature, 2 FAN speed and Chassis instrusion)
Maxim 1617 monitor cpu temperature (optional)
Supports both internal and external modem ring power-on, support WOL
PS2 keyboard power on (by password)
Trend ChipAway Virus on guard
On board switching voltage regulator with VID function meet VRM8.4 Spec(support 1.3V to 3.5V)
Provides infrared interface
Supports auto fan off when system enters suspend mode
Certificates NSTL Year 2000 Compliant
Board Size ATX 305mmx193mm
Panta rei!!
| » | Qdi kinetiz 7b + Athlon 1800+Oddelek: Strojna oprema | 2326 (2133) | Blinder |
| » | ATA disk prenos + QDI Excellent 1 plataOddelek: Strojna oprema | 1700 (1650) | Daedalus |
| » | Morebitne težave z matično ploščo.Oddelek: Strojna oprema | 1842 (1672) | D4rkDoG |
| » | Je kriva plosca za memtest errorje/nestabilnost?Oddelek: Navijanje | 2282 (2134) | AtaStrumf |
| » | Plošča QDI KinetiZ-da ali ne?Oddelek: Kaj kupiti | 1936 (1800) | Jux |
