Qdi kinetiz 7b + Athlon 1800+
sergejp ::
Kako ti dve stvari greta skupaj?
Bodo kakšne težave, počasnost delovanja?
Si naj še rajši kupim novo plato?
Sem flashal novi bios, ki podpira procesore na 2200+, tu pa še nekaj o plati:
Chipset
north bridge:VIA KT-133
South bridge:VIA VT82C686B
Bus Type 5 PCI slots
1 AMR
1 AGP
1 ISA
CPU Support Socket A AMD Athlon and Duron Processors
AMD Athlon Processors at 750/800/850/900/950MHz ,1GHz, 1.1GHz and future
AMD Duron Processors at 600/650/700/800MHz and future
System Memory Three 168 pin 3.3V PC133 DIMM sockets
Supports up to 1.5G SDRAM
Supports 66/100/133 MHz Synchronous DRAM and VCM SDRAM
And 66MHz EDO DRAM
Power Management ACPI V1.0 and APM compliant
Supports S0, S1, S3, S4, S5 ACPI power status
Auto adjust FAN speed in the different power status
USB 4 USB ports (2 for I/O panel and 2 for front panel)
USB 1.1 specification compliant
Bus Speed 200MHz FSB
Overclock up to 266MHz FSB maximally
BIOS 2 Mbit Flash ROM
Licensed advanced AWARD BIOS
Supports Plug and Play
Supports ACPI and OS directed power management
Storage system Two PCI Master IDE ports support up to 4 IDE devices
Supports ATA 66/100
One floppy port support up to two 3.5Ąą or 5.25Ąą floppy drives
( 360K/720K/1.2M/1.44M/2.88M)
Supports LS-120 floppy disk drive and ZIP drive
I/O Feature 2 High Speed Serial Ports (16550 Fast UART Compatible)
1 Enhanced Parallel Port Support EPP/ECP/SPP
1 PS/2 keyboard port
1 PS/2 mouse port
IrDA port support up to 115.2Kb/s transfer rate
All I/O ports can be enabled/disabled by BIOS setup
Graphics AGP 4X Support
Universal AGP Slot
Transfer rate up to 1 GB/s
Onboard Audio Hardware Sound System(K7B-C)
Creative 5880 PCI Sound Chip
Advanced Feature Wake up on LAN
Wake up on Modem
Trend ChipAwayVirus on Guard
PC-cillin with killing function
Override processor ratio by jumpers (PCB2.0 support overclock function)
QDI Innovative Technology RecoveryEasy, BIOS-ProtectEasy, ManageEasy, LogoEasy
System Health Monitoring CPU temperature, System temperature, CPU fan speed
Chassis fan speed, 5 System Voltages
Board Size ATX: 305X244mm
sergej
mare87 ::
Jaz ti priporočam novo plato! To ti pravim iz lastnih izkušenj! Sicer mam Qdi KuDoz 7a samo veeno ista firma, isto sranje ;( . Naj ti povem mojo štorijo: Kupim novo GeForce 4 ti 4200 od Abita in potem naslednje: Ko računalnik prižgem se mi po nekaj časa (1-2min) naredijo črte čez celi ekran in ne moreš več nč! Resetiram rač. in stvar potem vredu deluje! Sem že probal brez modema=isto, napajalnik ni kriv, edino plata še ostane! Tako, da bom šel probat k enemu vrendu na Elite k7s5a pa bom videl! Prej sn mel GeForce 2 od Mr. Visiona pa ni blo nič narobe!
Ps: Pa tudi na Forumu od Qdi-ja sem zasledl Zelo dosti problem z Kinetiz matičnimi na hitrejših procesorjih!
flipflop ::
Moja qdi zaenkrat še kr dobro dela,ampak jo bo kmalu nadomestila ena z nforce 2 čipovjem.Mi je pa v tem času služila brez vsakih problemov,tako da imam o QDI dobro mnenje,le navijat se ne da,je pa zato bolj stabilna.
Hammer ::
S to plato bo athlon tiktakal na 1288Mhz,ker plata ne podpira FSB višjega od 112Mhz,tko,da kup novo plato
flipflop ::
Glede na to,da imaš KT 133 čipset,torej brez A,tvoja plošča podpira samo do athlon XP 1600+. Plošče s KT 133A pa z novim biosom podpirajo brez težav do 2400+ ali celo do 2600+.
sergejp ::
Hammer: poglej kaj sem prilepil odzgoraj, posebaj še vrstico :
flipflop: zato sem tudi naložil nov bios, ki kakor piše na qdi-jevi strani podpira procesorej na 2200+:
K7B BIOS 4.0 for LogoEasy, RecoveryEasy and BootEasy.
BIOS modified: (checkSum:2FAE(Hex) )
1. Fixed can’t recognize AthlonXP CPU above 2200+
2. Fixed can’t boot whith some vgacard.
Blinder ::
No da obudimo qdi-jevko po 5 letih. Manuala na netu ne uspem dobit. A se da tole reč spravit na 133 mhz fsb? Sem proval en jumper premaknit ki naj bi bil za dvignit iz 100@133 fsb, samo pol ni delalo.
Drugace pa ima luknjo v nastavitvah med 112 in 136 mhz fsb, verjetno zato, da zavaruje pci clock pred previsoko frekvenco.
ATA disk prenos + QDI Excellent 1 plata
61699 (1649) Daedalus
Morebitne težave z matično ploščo.
221841 (1671) D4rkDoG
Plošča QDI KinetiZ-da ali ne?
81934 (1798) Jux
QDI plata
61689 (1614) Koci
Soyo????
52323 (2259) piko
