Forum » Programska oprema » Monitor na dotik gonilniki
listje123 ::
Pozdravljeni,
kupil sem rabljen monitor, ki pa žal nima gonilnikov.
Podatki o monitorju:
http://cueb.de/product_info.php?info=p3...
Njihova spletna stran:
https://www2.lauer-fischer.de/
Nikjer ne najdem driverjev. Lepo bi vas prosil za pomoč.
Hvala
Hvala
AC_DC ::
Za kateri os ?
Poglej kaj najdi https://www.piriform.com/speccy , HWiNFO (32/64) in SiSoftware Sandra.
- spremenilo: AC_DC ()
listje123 ::
General information
Monitor Name: Unknown
Monitor Name (Manuf): 15LCD(ANA)
Date Of Manufacture: Week: 48, Year: 2005
Monitor Hardware ID: Monitor\GVT0560
Max. Vertical Size: 23 cm
Max. Horizontal Size: 30 cm
Horizontal Frequency: 31 - 64 kHz
Vertical Frequency: 60 - 60 Hz
Maximum Pixel Clock: 70 MHz
Advanced parameters
Input Signal: Analog: 0.700 V / 0.000 V (0.700 V p-p)
Display Type: RGB color
Gamma Factor: 2.20
DPMS Modes
Standby: Supported
Suspend: Supported
Active Off: Supported
Standard Colour Space: Not Supported
Preferred Timing Mode: Supported
Default GTF Supported: Not Supported
DPMS Input Signal
Serration VSync: Not Supported
Sync On Green: Not Supported
Composite Sync: Not Supported
Separate Syncs: Supported
Blank-to-black Setup: Not Supported
Supported Video Modes
1024 x 768 304 x 228 mm, Pixel Clock 65.00 MHz
Advanced parameters
Gamma Factor: 2.20
DPMS Modes
Standby: Supported
Suspend: Supported
DPMS Input Signal
- spremenil: listje123 ()
AC_DC ::
Najdi na ebay.de podoben model in prijazno vprašaj prodajalca za driverje.
Tvoj prodajalcec tudi nima driverjev na voljo ?
listje123 ::
Moj prodajalec jih je izgubil. Bom povprašal prodajalce na ebay.
Hvala Vam za pomoč.
Lep pozdrav
Hvala Vam za pomoč.
Lep pozdrav
| » | Rabm grafično karto, kiOddelek: Kaj kupiti | 4472 (3803) | kuglvinkl |
| » | [Java] Urejanje baze z JTableOddelek: Programiranje | 1452 (1236) | vonNeumann |
| » | DLNA mreža za TV (PROGRAM)Oddelek: Programska oprema | 4358 (3504) | radmannsdorf |
| » | Pomoč pri sambi, hitrost prenosa je prenizka.Oddelek: Omrežja in internet | 1526 (1389) | gfighter |
| » | Uporabnikov test DetonatorjevOddelek: Novice / Grafične kartice | 3111 (3111) | tejo |
