Soundbar ne igra
Soundbar ne igra
eno_ime ::
Philips tv, philips soundbar.
Povezava HDMI.
Soundbar mode na hdmi act.
Tv, zvok , easylink on, auto easylink. Hdmi-1 se prikaze na meniju, in je tudi vklopljen.
Ko prizgem tv, napise, da se povezuje na glasbeni sistem, po nekem casu javi napako, ne morem se povezati, in preklopi na zvočnike od tv-ja.
Kje bi lahko bil problem?
dukedl ::
ker imamo kristalno kroglo, točno vemo kater model soundbara imaš... :)
je pa tle napisano, da ima sb HDMI OUT..in ne IN http://download.p4c.philips.com/files/h...
torej televizijo nanj priklopiš s kakšnim drugim prklopom
lp dukedl
eno_ime ::
Tocno ta linkan bar imam.
Ko sem kupoval v trgovini, je delal z njihovo tv preko HDMI.
dukedl ::
hmmm...pomoje more met tv tudi HDMI ARC
http://www.cnet.com/news/what-is-audio-...
In theory, ARC is supposed to let you have one connection between your TV and whatever you use to create sound: a receiver or a sound bar. You send video to the TV with an HDMI cable, and that same HDMI cable sends audio from the TV back down the same cable.
This is great for smart TVs, where the TV itself is creating the audio (via apps like Netflix and Pandora). Instead of suffering through a TV's terrible speakers, the audio gets sent to the receiver/sound bar for a massive improvement in sound quality.
Another way this is great is if you have multiple sources (Blu-ray, cable box, Roku), but only one input on your sound bar. With ARC, you can connect everything to the TV, and the TV will send audio down an HDMI cable to the sound bar. No extra cables needed (i.e. an optical cable).
lp dukedl
eno_ime ::
Imam Philips series pfl8600
Soundbar pa zanimivo dela na pfl7600 series.
8600 sem tudi ponastavil nastavitve na tovarniske, nadgradil firmware na zadnji, nic ne pomaga.
Sedaj mi se ostane povezava mimo HDMI.
Zadaj imam povezave:
1.Slusalke
2.Digital audio out
3.Vga-dvi-hdmi digital in
Kaksen kabel rabim , da povezem Philips Soundbar HTL3110B, verjetno bo to slo preko 2.Digital audio out?
Bi prosil za nasvet kakšnega, ko se spozna.
dukedl ::
eno_ime je izjavil:
1.Slusalke
2.Digital audio out
čak, kerga maš? a to ni tale http://download.p4c.philips.com/files/h... ?
ker na strani 6, so narisani drugi vhodi
lp dukedl
eno_ime ::
Ja, to si dal , kateri so na soundbarju,
Jz sem napisal, kaj imam zadaj na Philips TV.
Torej kaksen kabel rabim?
dukedl ::
a sorry...torej Digital audio out iz tvja povežeš z sb..zdej al maš koaksialen izhod al pa optični na tvju (sb ima obe vrsti)?
lp dukedl
eno_ime ::
Tv ima koaks digital out(nima optical).
dukedl ::
pol pa lohk probaš z navadnim rca kablom(cinch-cinch) če ga imaš...bo delalo
lp dukedl
eno_ime ::
Nimam. Dej kaksen link do slike kable, da kupim to.
dukedl ::
lp dukedl
eno_ime ::
Najlepsa ti dala.
Kateri soundbar
389611 (795) Kalamarus
Kako povezati tv in soundbar,prosim pomoč
Oddelek: Zvok in slika
277954 (3409) Škorc
Priklop 2.1 zvočnikov (jack) na novejši TV (brez jacka)
267140 (6822) LooK
Zvok iz TV na hišni kino
254657 (3206) billy
Zvok TV-ja skozi receiver
172994 (2939) icurk
