Forum » Omrežja in internet » internet ne dela
internet ne dela
Ikspe ::
Instaliral sem Cyberghost in naslednjič sem opazil da ne dela več internet. Zadevo sem odinstaliral ampak ni nič boljše. Reboot ni pomagal.
Internetno povezavo mi kaže da je povezana, mozillo normalno odprem, ko pa v google napišem besedo pa napiše Strežnika ni mogoče najti.
Na istem PC imam še en OS na katerem pa internet normalno deluje.
XsenO ::
Hodi v C:\Windows\System32\drivers\etc Odpi z notepadom host file in počisti morebitno nesnago
1 + 1 = 1
Ikspe ::
V etc so tile:
hosts
Imhosts.sam
networks
protocol
services
Misliš hosts? Tega odprem v notepadu, ne vem pa kaj je notri nesnaga?
hosts
Imhosts.sam
networks
protocol
services
XsenO ::
Čisti izgleda tako:
# Copyright (c) 1993-2009 Microsoft Corp. # # This is a sample HOSTS file used by Microsoft TCP/IP for Windows. # # This file contains the mappings of IP addresses to host names. Each # entry should be kept on an individual line. The IP address should # be placed in the first column followed by the corresponding host name. # The IP address and the host name should be separated by at least one # space. # # Additionally, comments (such as these) may be inserted on individual # lines or following the machine name denoted by a '#' symbol. # # For example: # # 102.54.94.97 rhino.acme.com # source server # 38.25.63.10 x.acme.com # x client host # localhost name resolution is handled within DNS itself. # 127.0.0.1 localhost # ::1 localhost
1 + 1 = 1
| » | Zakaj mi ne odpre samo ene določene strani?Oddelek: Omrežja in internet | 8456 (4496) | BorutK-73 |
| » | Shranjevanje v Hosts fileOddelek: Pomoč in nasveti | 2520 (2458) | Mendex |
| » | Iz Googla me preusmeri na neke čudne straniOddelek: Omrežja in internet | 2109 (1325) | logout |
| » | ne dovoli mi namestiti antivirusnega programaOddelek: Pomoč in nasveti | 4781 (4509) | k4vz0024 |
| » | Obstaja program ki onemogoči določeno spletno stran?Oddelek: Programska oprema | 2105 (1982) | #000000 |
