Shranjevanje v Hosts file
Mendex ::
Lep pozdrav!
Imam en problem in sicer ko želim spreminjat Hosts datoteko (odprem v beležnici) kliknem shrani in ko to kliknem mi napiše da nimam dovoljenja za shranjevanja na to (C:\Windows\System32\drivers\etc) mesto, in da lahko shranim v moje dokumente, in da naj se obrnem na skrbnika.
Bral sem da moram datoteko odpreti kot administrator, pa mi ni povsem jasno kako in če je to to.
Če kdo ve kako bi lahko to shranil bi bil zelo hvaležen.
Hvala!
če maš windows 8 ti windows ščiti datoteko pred posegi, ampak nisi napisal kateri windows maš tak da ne vemo točno
ja datoteko rabiš odpreti kot admin (win vista, 7)
  • spremenil: mtosev ()
Mendex ::
Win7. Kako pa odprem kot administrator?
luli ::
Beležnico odpri kot administrator.
Mendex ::
Še enkrat.
Pridem do datoteke hosts po tej poti: C:\Windows\System32\drivers\etc.
dvakrat kliknem na hosts datoteko, izberem program za odpiranje (beležnica).
ko mi v beležnici odpre hosts datoteko izgleda takole:
# Copyright (c) 1993-2009 Microsoft Corp.
# This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
# This file contains the mappings of IP addresses to host names. Each
# entry should be kept on an individual line. The IP address should
# be placed in the first column followed by the corresponding host name.
# The IP address and the host name should be separated by at least one
# space.
# Additionally, comments (such as these) may be inserted on individual
# lines or following the machine name denoted by a '#' symbol.
# For example:
# 102.54.94.97 rhino.acme.com # source server
# 38.25.63.10 x.acme.com # x client host
# localhost name resolution is handled within DNS itself.
# 127.0.0.1 localhost
# ::1 localhost
No in potem spodaj dopišem tole:
127.0.0.1 activate.adobe.com
127.0.0.1 practivate.adobe.com
127.0.0.1 ereg.adobe.com
127.0.0.1 activate.wip3.adobe.com
127.0.0.1 wip3.adobe.com
127.0.0.1 3dns-3.adobe.com
127.0.0.1 3dns-2.adobe.com
127.0.0.1 adobe-dns.adobe.com
127.0.0.1 adobe-dns-2.adobe.com
127.0.0.1 adobe-dns-3.adobe.com
127.0.0.1 ereg.wip3.adobe.com
127.0.0.1 activate-sea.adobe.com
127.0.0.1 wwis-dubc1-vip60.adobe.com
127.0.0.1 activate-sjc0.adobe.com
in vse skupaj izgleda takole:
# space.
# For example:
# ::1 localhost
In sedaj kliknem shrani
Ponudi da shranim v mapo etc.
Ime datoteke: Hosts
vrsta datoteke: besedilni dokumenti txt.
Kodiranje: ANSI.
Nato kliknem shrani in mi napiše: Nimate dovoljenja za shranjevanje na to mesto. Za shranjevanje se obrnite na skrbnika. Ali želite namesto tega shraniti v mapo Moji dokumenti?
Prosil bi če mi kdo bolj natančno pove kako bi datoteko hosts odprl v beležnici ko skrbnik/admin? oz postopek da shranim tako, da bo delalo.
Hvala, in se opravičujem za tako dolg post. :)
Wox ::
Commodore 64
usoban ::
najdi ikono beleznice, desni klik -> run as administrator/zazeni kot skrbnik
b00mer ::
Tole je res anoying ja :)
Mors met pravice administratorja, js sem si sicer pomagov z notepad++ (se mi zdi da ni bilo tezenja). Drugace pa run as administrator
Mendex ::
Hvala vam vsem! Sem zrihtal zdaj :D
Upam da bo še komu pomagala ta tema :)
  • spremenil: Mendex ()
Zakaj mi ne odpre samo ene določene strani?
Oddelek: Omrežja in internet
288453 (4493) BorutK-73
Kako zaklenem spletno stran?
171705 (1582) [D]emon
Blokiranje naslovov strani
205397 (3440) clancy
Mac-ov OS in Adobe CS4 Master Collection
71123 (1036) gerrno
hosts file
95717 (5580) Loki
