Forum » Omrežja in internet » Zakaj mi ne odpre samo ene določene strani?
Gregoriuss ::
No jaz mam tak problem, da mi niti firefox niti Explorer nočeta odpret strani battle.net. Na drugmu računalniku, ki je prav tako povezan brezžično prek routerja brez problema dostopam do te strani. Kaj je narobe in kako lahko to popravim?
Lp, Gregor
Lp, Gregor
CitroX ::
Ali je težava samo na tvojem računalniku ali mogoče iz tvoje lokacije?
Če je lokacija, je mogoče ponudnik interneta blokiral.
Poglej tudi, kaj je napisano v datoteki C:\Windows\System32\Drivers\Etc\hosts.***
Ta lahko kam preusmerja.
Mogoče kaj od tega?
Mogoče kaj od tega?
Gregoriuss ::
# Copyright (c) 1993-2009 Microsoft Corp.
# This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
# This file contains the mappings of IP addresses to host names. Each
# entry should be kept on an individual line. The IP address should
# be placed in the first column followed by the corresponding host name.
# The IP address and the host name should be separated by at least one
# space.
# Additionally, comments (such as these) may be inserted on individual
# lines or following the machine name denoted by a '#' symbol.
# For example:
# 102.54.94.97 rhino.acme.com # source server
# 38.25.63.10 x.acme.com # x client host
# localhost name resolution is handled within DNS itself.
# 127.0.0.1 localhost
127.0.0.1 localhost
127.0.0.1 mpa.one.microsoft.com
127.0.0.1 sls.microsoft.com
127.0.0.1 genuine.microsoft.com
127.0.0.1 wat.microsoft.com
127.0.0.1 mpa.microsoft.com
127.0.0.1 activate.adobe.com
127.0.0.1 practivate.adobe.com
127.0.0.1 ereg.adobe.com
127.0.0.1 activate.wip3.adobe.com
127.0.0.1 wip3.adobe.com
127.0.0.1 3dns-3.adobe.com
127.0.0.1 3dns-2.adobe.com
127.0.0.1 adobe-dns.adobe.com
127.0.0.1 adobe-dns-2.adobe.com
127.0.0.1 adobe-dns-3.adobe.com
127.0.0.1 ereg.wip3.adobe.com
127.0.0.1 activate-sea.adobe.com
127.0.0.1 wwis-dubc1-vip60.adobe.com
127.0.0.1 activate-sjc0.adobe.com
127.0.0.1 adobeereg.com
# ::1 localhost
To mi piše v hosts. Z mojim znanjem nisem odkril nobene napake. A moram kej dopisat?
Lokacija ne more bit ker z drugim računalnikom z iste dostopne točke lahko odprem stran.
# space.
# For example:
127.0.0.1 localhost
# ::1 localhost
- spremenil: Gregoriuss ()
detroit ::
:D loopback na loopback pogača pravijo, mogoče pa za bajto štedi
ampak ne jst ne vidim nič z blizzardom tuki
Skero
klemenSLO ::
Pri kolegu se je zanč ruter od siola napol obesil, tako da je nekatere strani odpiralo, nekatere pa ne.
Navadn reset ni pomagal , je bilo treba dat na tovarniške nastavitve.
KaRkY ::
Jaz sn mel predčasom podoben problem pa je bla omrežna maska kriva ker je bila nastavljena preširoko(255.0.0.0 namesto 255.255.255.0) in si bile določene cifre mojega IP-ja in od strani enake.
Gregoriuss ::
Sam mel tut js omrežno masko na 255.0.0.0 pa sm jo spremenu na 255.255.255.0 in zdej dela. Hvala za pomoč. Lp
bosmla ::
Eno vprasanje na podobno temo: lahko s hosts datoteko (vpisom v njo - kako) neko spletno stran preusmerim na drugo stran - torej ne blokiram pac pa preusmerim?
Potreboval bi le za dve domeni, da se preusmerita na poddomeno - otroci pac...
agerksic ::
Pozdravljeni.
Meni se dogaja, da mi IE in FF nista odpirala www.avg.com in www.bitdefender.com. Po urah branja forumov sem v "hosts" vpisal IPje teh strani in potem mi je avg normalno začelo odpirat, bitdefender pa samo na pol. Vendar se mi to vpisovanje v hoste ne zdi ravno posrečena rešitev saj je problem verjetno nekje drugje. Na isti wireless imam povezan še en prenosnik, ki te strani odpira OK. AVG se mi kljub temu, da sedaj odpira spletno stran, ko hočem namestiti antivirus ne poveže s strežnikom in namestitev ni možna.
Se komu kaj sanja?
Se komu kaj sanja?
agerksic ::
" Strežnika ni mogoče najti
Strani www.malwarebytes.org ni mogoče najti.
* Morda ste se zmotili pri črkovanju naslova
(npr. ww.mozilla.org namesto www.mozilla.org).
* Če prihaja do tega problema z več stranmi, imate morda napačne nastavitve povezave in DNS.
* Če uporabljate posrednik ali požarni zid, se prepričajte, da so vaše nastavitve pravilne. "
Fak. Izgleda, da mi ne odpira strani, ki spo povezane z varnostnimi rešitvami. Tudi Symantec je out. ??
Panda in F-secure tudi...
- spremenilo: agerksic ()
agerksic ::
En tisočkrat hvala.
Nekega hudiča je MalwareBytes našel in pobrisal.
Zdaj dela BP. Sam ni mi jasno od kje je to priletelo, ker praktično je sveža namestitev XP. Morda okuženi Winsi?
Hvala še enkrat.
Hvala še enkrat.
Lea_Lea ::
Zdravo!
V glavnem problem imam, da se ne morem prijaviti v Gmail. Ko v Googlu kliknem gmail oznako se mi stran ne naloži.
Izpiše pa se mi tole:
* Stran je morda začasno nedosegljiva ali preobremenjena.
Poskusite znova nekoliko pozneje.
* Če ne uspete naložiti nobene strani, preverite povezavo
svojega računalnika do interneta.
da ima Firefox dovoljenja za dostop do spleta.
Sem pregledala že nekaj tem in pridobila naslednje podatke:
1 5 ms 13 ms 2 ms rsd13s-v5.uni-mb.si [164.8.205.1]
2 druga in četrta vrstica nista celi, ker mi je skoz izpisovalo, da sem HTML oznako pozabla zaključit ( je pa bilo direkt skopirano, tak, da se nisem zmotla)
3 2 ms 1 ms 1 ms rrcum8-t0-1.uni-mb.si [164.8.102.6]
4 lizum2-V600.arnes.si [193.2.125.97]
5 3 ms 3 ms 3 ms larnes6-V420.arnes.si [88.200.2.64]
6 3 ms 3 ms 4 ms rarnes1-X0-0-0x498.arnes.si [88.200.7.252]
7 10 ms 9 ms 9 ms arnes.rt1.vie.at.geant2.net [62.40.124.5]
8 16 ms 16 ms 16 ms so-1-2-0.rt1.pra.cz.geant2.net [62.40.112.6]
9 24 ms 23 ms 23 ms so-6-3-0.rt1.fra.de.geant2.net [62.40.112.38]
10 24 ms 24 ms 23 ms google-gw.rt1.fra.de.geant2.net [62.40.125.202]
11 24 ms 25 ms 24 ms 209.85.241.110
12 24 ms 24 ms 24 ms 209.85.254.116
13 25 ms 32 ms * 209.85.249.166
14 25 ms 26 ms 24 ms fx-in-f18.1e100.net [74.125.39.18]
# space.
# For example:
# ::1 localhost
67.205.118.179 www.google.com
67.205.118.180 search.yahoo.com
67.205.118.180 www.bing.com
Kaj vam ti podatki povejo?
Kaj lahko naredim, da stvar popravim?
Dodano:
dejansko ne morem pridit v nobeno Google aplikacijo, ne gmail, ne google i page, moj youtube account, tut na google chrome spletno stran ne ( sem si ga hotla downloadad), pri vseh mi enako napiše:
# space.
# For example:
# ::1 localhost
Dodano:
- spremenila: Lea_Lea ()
amigo_no1 ::
Zbriši
67.205.118.179 www.google.com 67.205.118.180 search.yahoo.com 67.205.118.180 www.bing.com
fosil ::
Očitno imaš okužen računalnik.
Poleg tega kar je rekel amigo naredi tudi scan s kakšnim AV.
Tako je!
Lea_Lea ::
Hvala pomoč!
Zdej je samo še stvar kak to zbrisat? Odprem z wordpad-om in zbrišem ter dam save, a ko spet odprem, vidim, da se sploh ni zbrisalo.
amigo_no1 ::
Lea_Lea ::
Ja, očitno res.
Tvoj predlog bom upoštevala, na žalost pa je izvedljiv šele jutri. Sem mislila, če je kakšna začasna rešitev, delna ( pri brisanju hosts), da bi lahko do blokiranih stvari prišla že danes.
ok, potem pa poročam kak sem zrihtala jutri.
Hvala.
Hvala.
fosil ::
Če gre za win7 moraš wordpad zagnat z administratorskimi pravicami.
To boš itak morala ročno narest, ker av ti tega ne bo brisal.
Tako je!
vozu43 ::
Živjo,
Jaz imam podobno težavo. Na nobenem kompu v hiši, ki so povezani z domačim wi-fi mi ne odpira določenih strani(dailymotion, booking, armorgames..) . Odpreti mi noče v nobenem brskalniku. Na računalniku sem sprobal izklopiti vse zaščite in ni nič pomagalo.
Teh strani mi prav tako noče odpreti na mobilnem telefonu, ko se povežen na domači wi-fi.
Tako da mora biti težava z wi-fi. Ima kdo kakšno rešitev?
Najlepša hvala
Najlepša hvala
Bakunin ::
kaj pravi MTU test > http://www.letmecheck.it/mtu-test.php ?
- spremenil: Bakunin ()
vozu43 ::
From the tests we did, we can assume that 1472 bytes is the largest unfragmented packet
size. The MTU size would be 1500, made up from 1472 payload and 28 ICMP/IP Headers
and payload information.
The maximum MTU size for 217.72.90.101 is: 1500
NB: The Internet Protocol requires that hosts must be able to process IP datagrams of at least
576 bytes (for IPv4) or 1280 bytes (for IPv6)
MTU imam nastavljen na 1500. Ali moram spremeniti?
BorutK-73 ::
vozu43 - probaj spremenit DNS-e na roterju.
Googlovi dns-i:
Primary DNS:
8.8.8.8
Secondary DNS:
8.8.4.4
Shrani si svoje DNS-e v tekst file.
Googlovi dns-i:
Primary DNS:
8.8.8.8
Secondary DNS:
8.8.4.4
| » | Kako zaklenem spletno stran?Oddelek: Pomoč in nasveti | 1706 (1583) | [D]emon |
| » | Blokiranje naslovov straniOddelek: Omrežja in internet | 5398 (3441) | clancy |
| » | Shranjevanje v Hosts fileOddelek: Pomoč in nasveti | 2520 (2458) | Mendex |
| » | google analyticsOddelek: Slo-Tech | 3611 (3081) | roli |
| » | hosts fileOddelek: Omrežja in internet | 5720 (5583) | Loki |
