Forum » Operacijski sistemi » Win 8/8.1/10 hropeče, Kubuntu blesteče?
slitkx ::
System info:
Problem je v tem, da prenosnika iz večih razlogov ne morem več odpirati, zato je ventilator zaradi tone prahu glaaaseeen.
(Živcežer.)
Bi Kubuntu bolje sfolgal? Nočem se odpovedati možnosti prilagajanja videza in funkcionalnosti. (Zato Unity ni izbira zame.)
Lp.
PS C:\WINDOWS\system32> systeminfo
Host Name: ALIEN
OS Name: Microsoft Windows 10 Pro
OS Version: 10.0.10586 N/A Build 10586
OS Manufacturer: Microsoft Corporation
OS Configuration: Standalone Workstation
OS Build Type: Multiprocessor Free
Registered Owner: Microsoft
Registered Organization: Microsoft
Product ID: 00331-10000-00001-AA113
Original Install Date: 18. 11. 2015, 16:13:58
System Boot Time: 20. 11. 2015, 15:08:59
System Manufacturer: Hewlett-Packard
System Model: HP EliteBook 8730w
System Type: x64-based PC
Processor(s): 1 Processor(s) Installed.
[01]: Intel64 Family 6 Model 23 Stepping 6 GenuineIntel ~2401 Mhz
BIOS Version: Hewlett-Packard 68PAD Ver. F.20, 7. 12. 2011
Windows Directory: C:\WINDOWS
System Directory: C:\WINDOWS\system32
Boot Device: \Device\HarddiskVolume1
System Locale: sl;slovenščina
Input Locale: sl;slovenščina
Time Zone: (UTC+01:00) Beograd, Bratislava, Budimpešta, Ljubljana, Praga
Total Physical Memory: 3.996 MB
Available Physical Memory: 1.562 MB
Virtual Memory: Max Size: 5.404 MB
Virtual Memory: Available: 2.531 MB
Virtual Memory: In Use: 2.873 MB
Page File Location(s): C:\pagefile.sys
Domain: WORKGROUP
Logon Server: \\MicrosoftAccount
Hotfix(s): 3 Hotfix(s) Installed.
[01]: KB3103688
[02]: KB3105211
[03]: KB3118754
Network Card(s): 3 NIC(s) Installed.
[01]: Intel(R) 82567LM Gigabit Network Connection
Connection Name: Ethernet
DHCP Enabled: Yes
DHCP Server: 188.230.128.1
IP address(es)
[01]: 93.103.68.27
[02]: fe80::ace2:a91b:f592:7e89
[02]: TeamViewer VPN Adapter
Connection Name: Ethernet 2
Status: Media disconnected
[03]: Intel(R) WiFi Link 5300 Driver
Connection Name: Wi-Fi
Hyper-V Requirements: VM Monitor Mode Extensions: Yes
Virtualization Enabled In Firmware: No
Second Level Address Translation: No
Data Execution Prevention Available: Yes
PS C:\WINDOWS\system32>Problem je v tem, da prenosnika iz večih razlogov ne morem več odpirati, zato je ventilator zaradi tone prahu glaaaseeen.
(Živcežer.)
Lp.
slitkx ::
Computer: Hewlett-Packard HP EliteBook 8730w
CPU: Intel Core 2 Duo P8600 (Penryn-3M POP, M0)
2400 MHz (9.00x266.7) @ 2393 MHz (9.00x266.0)
Motherboard: Hewlett-Packard 30EC
Chipset: Intel PM45 (Cantiga-PM) + ICH9M (Enh)
Memory: 4096 MBytes @ 398 MHz, 6.0-6-6-18
- 2048 MB PC6400 DDR2-SDRAM - Qimonda 64T256020EDL2.5C2
Graphics: ATI/AMD Mobility Radeon HD 3670 (M86-XT) [Hewlett-Packard]
ATI/AMD Mobility Radeon HD 3670, 256 MB GDDR3 SDRAM
Drive: INTENSO SSD 128GB, 125.0 GB, Serial ATA 6Gb/s @ 3Gb/s
Drive: HL-DT-ST DVDRAM GSA-T50L, DVD+R DL
Drive: ST1000LM024 HN-M101MBB, 976.8 GB, Serial ATA 3Gb/s @ 3Gb/s <-> USB
Sound: Intel 82801IB ICH9 - High Definition Audio [A3]
Sound: ATI/AMD RV635 - High Definition Audio Controller
Network: Intel 82567LM ICH9M(E+) Gigabit Ethernet Controller
Network: Intel 5300 AGN 3x3 MC Wireless WiFi Adapter (Lenovo - MOW2)
OS: Microsoft Windows 10 Professional Build 10586
slitkx ::
Do ventilatorja ne morem več priti, preveč rizično odstranjevanje drobovja.
Pomislil sem, da Kubuntu zaradi zasnove (grafična obremenjenost) ne bi tako obremenjeval mašine.
zee ::
Ni treba nic razstavljat. Sesalec v roke in cev nastimaj na reze od prenosnika.
Kubuntu bo brzkone deloval slabse, saj je upravljanja z elektriko slabse kot na Windowsih.
zee
- spremenilo: zee ()
solatko ::
zee - Slab predlog, zadeve je potrebno spihat, sesanje ne naredi nič pametnega, samo na režah se dekca še bolj stisne in prepušča še manj pretoka. Prenosnik je potrebno za kvalitetno čiščenje, ki se bo na performancah poznalo, razstavit toliko, da dobiš ven hladilno telo in ventilator. Potem zamenjaš še termalno pasto in termalne trakove (na starejših prenosnikih) in imaš potem nekaj časa mir.
Delo krepa človeka
ta model ma afaik pod tipkovnico že kar hladilnik, tako da samo s kompresorjem spihaš, dvigneš heatsink nanov namažeš pasto in je to to.
Mogoče za eno malco dela.
- spremenil: iloveboobz ()
solatko ::
Je sicer za 8530w, vendar je enak, kot 8730w. Za očistit celoten sistem, je potrebno odstranit samo tipkovnico.
Delo krepa človeka
- spremenil: solatko ()
slitkx ::
Če nisi sposoben normalnega odgovora, ne odgovarjaj. Leti na AndrejS in pviran3.
Imam konkreten razlog, zakaj je razstavljanje tokrat zelo rizično.
AC_DC ::
Če imaš zapacan hladilni sistem, potem je samo vprašanje časa, kdaj ga boš lahko uporabljal samo pri -10C
- spremenilo: AC_DC ()
Enkrat bo sam boom, pa se nebo več prižgal. Tu nebo lahek linux nič pomagal.
Torej, reši problem, ne pa da iščeš obliže za rane.
In to je ?
In to je ?
slitkx ::
hojnikb, razlog je, da je bil že večkrat demontiran, tudi z menjavo sestavnih delov. V njem skorajda ni več originalne zadeve.
Vijaki in navoji so popolnoma uničeni. Ne želim, da ponovno pride do pretrganja konektorja, ki tipkovnico povezuje s plato.
Razstavljanje in sestavljanje tega prenosnika je pain in the ass, potrdil je tudi profi serviser, ko je bilo potrebno resnejše popravilo.
Skratka, zastavil sem preprosto vprašanje. Kdor ne more odgovoriti direktno na vprašanje (to pomeni NE vse ostalo, da izpade "jaki"), potlej naj ne odgovarja. Če temu ne bo tako, bom pač prosil za zaklep teme.
Hvala.
Hvala.
- spremenil: slitkx ()
darkolord ::
V bistvu si že v prvem odgovoru dobil odgovor na tvoje vprašanje: "Sprememba OS-ja ne bo rešila težave."
Če je profi serviser mel težave s tem (kater dejanski niti ni tako pain in the ass kot nekateri novejši modeli) potem pač ni kaj prida serviser. SPloh če je vmes še kej uniču.
crniangeo ::
prej bi reku da je nekdo drug unicil (salabajski) in je nato serviser se mattru tiste sravfke dobit dol :D
Convictions are more dangerous foes of truth than lies.
echo ::
Pa dej ne pametuj človeku no, dal je jasno opisan problem in iz tle izhajamo.
Pazljivo spihaj s pištolo kompresorja in pazi na ventilatorje (jaz jih s kakim zobotrebcem zataknem, da se ne vrtijo med čiščenjem).
crniangeo ::
se boljse je zatakniti z odvito zicko od sponke :)
V glavnem ne rabiš niti tega.
Greš na avto pumpo. Vzameš kompresor in laptop temeljito spihaš. Če bi ga razstavil, bi imel še 7-8% boljši rezultat (povsem brezprašen PC), ampak že to pihanje v glavnem kosme umazanije odpiha.
Paziti je edino treba, da se PC ne prižge 2-3 ure po pihanju.
Namreč, pri kompresorjih se pogosto nabere kondenz na dnu rezervoarja, pa zna kompresor malo izpihavati drobne kapljice vode.
Ni to problem, to se pojavlja pri vseh kompresorjih. PC pri miru pusti 2-3 ure, da ta mikro vlaga izpari in je to to.
To se naredi in je PC good to go.
Ne, ni. Glavni problem je posušena pasta, ne samo svinerija v ventu.
iloveboobz je izjavil:
sam z spihanjem neboš spravu vsega dol + imaš še vedno problem zasušene paste.
V življenju sem sigurno spihal vsaj 100 pcjev, pa verjetno več. Vsakega tudi 5-6 krat v življenski dobi.
Jamčim ti, da če samo spihaš, malo od izhodnih rež proti vhodnim in obratno, se znebiš 93-97% umazanije.
Jasno, če PC razdreš, še lahko izpihaš detaljno.
Ventilatorja (ventilatorjev) pa NIKAR NE USTAVLJAJTE. Naj se vrti, z večimi curki poskrbite za izpihanje.
Če fejst pritisneš in ventilator zadržuješ, ga lahko tudi zlomi. Jaz sem zamenjal takih zlomljenih eno 4-5.
Kar se pa paste tiče, vsaka pasta otrdi. Ene kot kamen, ene ko žvečilni. Ene pa nikoli ne otrdijo.
Če spihan PC daje temperaturo procesorja previsoko (50-60), temperatura okolice je pa recimo 28 v notranjosti, potem bi se loteval hladilnika.
Drugače pa si samo delo delaš.
Siddh ::
Če ne ustaviš ventilatorja in s kompresorjem skozi pihneš, boš potem poslušal kako lepo pojejo ležaji ventilatorja.
echo ::
solatko ::
Za detailno čiščenje tvojega računalnika rabiš odvit dva vijaka, ki držita tipkovnico, nič drugega. Potem pa imaš še ventilator pritrjen s tremi malimi vijaki. Brez tega lahko počneš karkoli, nabrane svinjarije pri ventilatorju, na režah za odvajanje vročega zraka, ne boš očistil.
Če imaš polomljene matice za privijanje delov ohišja in matične, si na eBay ali bolhi poglej za ceno celotnega ohišja. To kar bi pa rad ti, ohladitev sistema brez čiščenja pa je misija nemogoče, zato tudi ne dobiš odgovora, po svoji želji, saj se ti že ob boot-u, pri preverjanju komponent, segreje preveč in se pozneje, navkljub zavijanju ventilatorja ne ohladi več. Malenkost bi pomagal podstavek z ventilatorji.
Delo krepa človeka
technolog ::
Definitivno lahko linux naredi, da je sistem bolj tih. Enkrat sem imel testno nameščen windows, ventilator je bil tih, vendar se nikoli ni čisto ugasnil. Temperature okrog 46C.
Ko sem bootal v linux, so bile temperature 39C, ventilator pa se je prižgal na vsaki dve minuti.
Odgovor: Definitivno je mogoče, samo pozabi KDE (Kubuntu). Kaj lažjega boš moral gor dat.
Pojejo, a?
Ko boš razdrl svoj prvi ventilator, boš ugotovil, da ni notri nobenih ležajev.
Preprosta os, na pušo. Ter malo masti zraven.
Zadnji ventilator, ki pa je res imel res ležaje je bil na UPSu. Take kovinske.
Rezervni pa je stal čez 70 €.
AC_DC ::
Če veš kakšen mora biti, se splača vprašati na lokalni skf/fag/ostali_proizvajalci prodajalni , kajti 99% sem prepričan da jih ups proizvajalec ne dela sam.
Mogoče veš , kakšen tip ležaja je v ups-u (pomoje so navadni kroglični) ?
Enako je pri rolerjih.
Težava je samo v tem, da je imel ventilator tri žice, ter nestandardno krmiljenje. Ventilator se je sprožil samo, kadar je hladil 2,2 KVA UPS.
Saj je delal, samo je grozno rožljal.
Težavo sem rešil tako, da sem ga snel, sprepihal, počil vodoravno na povsem ravno površino, da je ostala krožna sled prahu na plošči, potem prešprical z WD-40 (ležaji).
Poskusil sem ga namazati (dodati mast), pa mi ni uspelo.
Gre za ta UPS:
http://www.sys2u.com/download/20091216-...
To je še danes eden najboljših UPSov stare šole.
Nameravam kupiti še enega ali dva - rabljena in zamenjati baterije.
Ventilator pa dela znova tiho.
Tako da problema z ventilatorjem nisem rešil.
Pa morda bi sedaj našel originalni ventilator ceneje.
S temi ventilatorji se ni za zajebavati.
Ko se tale UPS vklopi, piha toplo ko fen zadaj. Ne bi si upal dati nek đank. Ker če ventilator frizne, je ogenj naslednja stopnja.
- spremenilo: bbbbbb2015 ()
slitkx ::
Podstavek z ventilatorjem imam. Glede na meritve se comp ne segreva, postane pa glasen, ko se matrat s Flashem. Za meritve uporabljam http://www.hwinfo.com/.
fosil ::
Še ena možnost, ki pa je na žalost samo začasna.
Prenosnik uporabljaš na balkonu
Če se ne pregreva in je samo glasen ob obremenitvi potem to ni nič posebnega in ni zaprašen.
Tako je!
izklopiš flash -- problem rešen
slitkx ::
Comp crknu. Kaže na grafično.
Še deluje, HP Diagnostics ni našel problema.
d4vid ::
In to zato, ker bi rad hardwersko težavo reševal s softwerom.
Če bi vsaj pihnil s kompresorjem noter, bi imel delujoč prenosnik.
Sej konec koncev je pa to HP. Nisi prvi da mu crkne. Meni je zaradi pregrevanja crknila matična. Hlajenje vedno urejeno kot je treba.
Siddh ::
Pojejo, a?
Raje ti razdri svoj drugi ventilator. Nimajo vsi puš.
| » | Ventilator za laptopOddelek: Strojna oprema | 2410 (1800) | solatko |
| » | Pregrevanje laptopaOddelek: Pomoč in nasveti | 5669 (4438) | solatko |
| » | čiščenje računalnika z zrakom (strani: 1 2 )Oddelek: Pomoč in nasveti | 14230 (12816) | Napajalc |
| » | Kam nesti računalnik za čiščenjeOddelek: Pomoč in nasveti | 4321 (3657) | cegu |
| » | PC neprijetno ružiOddelek: Hlajenje in modifikacije | 6019 (5462) | nofaith |
