Forum » Pomoč in nasveti » Problem microsoft outlook 2010
bostjan6 ::
Imam težavo, ker ne morem odpreti outlook pošte. Vse mi je delalo, sedaj pa ko jo kliknem mi napiše
Cannot open your default e-mail folders. File access is denided. You do not have the permission required to access the file C:........
Prosim za pomoč
Prosim za pomoč
cvalsr ::
Smem še jaz malo pojokat?
Outlook mi noče poslati pošte!
Sprejema brez problemov.
Brskam po internetu za nasveti in sem samo še bolj zmeden - nisem nek velik strokovnjak.
Sprememba porta 25 na 465 nič ne pomaga.
Kak nasvet, prosim?
Hvala
Kak nasvet, prosim?
Hvala
cvalsr ::
Aja - dobim povratno sporočilo:
Sistem administrator: Undeliverable: Naslov sporočila
Vsebina pa je:
Your message did not reach some or all of the intended recipients.
Subject: test
Sent: 15.1.2016 11:55
The following recipient(s) could not be reached:
'naslov prejemnika' on 15.1.2016 11:55
554 5.7.1 'naslov prejemnika': Relay access denied
(To z iksi je moj drugi 'emajl', na katerega skušam poslati testno sporočilo (ne morem pošlati nič nikamor!)
Ponudnik je Siol in oni menijo, da je nekaj z Outlookom ...?
Vsebina pa je:
Subject: test
- spremenil: cvalsr ()
provi dat za outgoing server: www.mojhost.net in 465
cvalsr ::
Siolovo sporočilo napake - eno od več možnih:
Task 'pop.siol.net - Sending and Receiving' reported error (0x800CCC7D) : 'Your outgoing (SMTP) server does not support SSL-secured connections. If SSL-secured connections have worked in the past, contact your server administrator or Internet service provider (ISP).'
Tole sem dobil z "www.mojhost.net":
Task 'pop.siol.net - Sending and Receiving' reported error (0x800CCC92) : 'Your e-mail server rejected your login. Verify your user name and password in your account properties. Under Tools, click E-mail accounts. The server responded: ??????'
cvalsr ::
Sirotka, ne, imam 'odpikano' "use same as incoming ..."
in ne spomnim se, da bi to kaj spreminjal - pa mi je pred začetkom težav vse špilalo.
..., sem probal tvojo varianto - ne pomaga.
sirotka ::
Seveda, sej imas polno strani, lahko tudi na shrani.si nalozis. Ali pa mi Pošlji pm pa ti dam svoj mail in mi posljes tja.
| » | iPhone problem z pop3 strežnikomOddelek: Omrežja in internet | 1751 (1690) | trek@s |
| » | Outlook Express - težave s prejemanjem sporočilOddelek: Omrežja in internet | 1590 (1510) | Flux |
| » | Thunderbird in siol skreganaOddelek: Pomoč in nasveti | 2660 (2357) | Klemenn |
| » | e-mail problemOddelek: Omrežja in internet | 7022 (6911) | zlabo |
| » | Outlook Express Error sending/receiving message - SiOLOddelek: Programska oprema | 4165 (4104) | alf__ |
