Forum » Pomoč in nasveti » Vdor v računalnik, zaklenjeni diski
jericho ::
Živijo, nekdo mi je vdrl v računalnik in mi zaklenil vse diske, pustil je samo c: disk, da sem lahko prišel v sistem in prebral sporočilo, ki mi ga je pustil, kjer me izsiljuje za 1bitcoin, ki naj bi mu ga nakazal ne nek račun. Ali se da to kako rešiti ali mi ostane samo format in inštalacija.
Kako naj izvem kdo mi je vdrl v sistem?
Sporočilo se glasi:
You can use https://translate.google.com/ from your language to english if you don't know it.
Hello there.
I would like to tell you first I'm sorry about that but really I need some money so I know what I do it's not right. Your documents, files, databased most are in original places or some moved to your local data. If you want to regain access to your local disk, all your files, documents, etc please send 1 BTC (Bitcoin) to this address: 18jAZHhC8uy13n2Ym7YTTmTBfr9r8tivDM as fast as you can and email me at sociopatii@yahoo.com If you dont know what bitcoin is, please ask me for bitcoin website that you can buy it fast or search on google for a local Bitcoin shop or ATM and transfer 1 BTC to this address: 18jAZHhC8uy13n2Ym7YTTmTBfr9r8tivDM
It's not my fault if you are try to format disk and lose all. Here are only one way to get all back and regain access to your local hard disk drive and this way is to send 1 Bitcoin to this address: 18jAZHhC8uy13n2Ym7YTTmTBfr9r8tivDM
It's just business not trying to get your money and then to not give to you the bitlocker password. Waiting for your reply to my email address ( sociopatii@yahoo.com ) if you wanna get the bitlocker password. Thanks
Sporočilo se glasi:
Hello there.
loveJDM ::
Samo daj mu nena,raje namerno formatiram kot pa nekemu majmunu denar dajem...Če pa plačas,kje ti je zagotovilo da ne bo še 1x to naredil ker očitno ni problem
prox ::
Eni pa res nevem kaj delate, da dobite takšne viruse
>>Rajš sn od slo-tech/a odvisn kot pa od Facebooka<<
|Asus K55VJ | Intel i5-3210m | 8Gb ram | nVidia GT635m|
Yacked2 ::
Kontaktiraj SI-CERT, je bilo v teh mapah kaj uporabnega/pomembnega itd...
Korak naprej ni vedno ustrezen...sploh če si na robu prepada!
jericho ::
Hm tud jst ne vem kako je tole pršlo gor
Pa nism lih laik za računalnike in sisteme. Lahko, da je sin kej tazga gor dal.
Ne nimam namena plačevat, sicer mam nekaj slik, ki bi jih pogrešal, drugače nič takega kar se ne bi dalo na novo dobit.
Aja, sistem je win7, antivirus je bil od kingsofta.
- spremenilo: jericho ()
Pr1m3 ::
http://www.pcworld.com/article/2084002/...
To si poglej če ti kaj pomaga , tisti Lock-Screen pa to se da enostavno rešit v tvojem primeru pa maš "The really nasty stuff".
Tr0n ::
Najprej probaj tole.
http://www.pcworld.com/article/243818/h...
Se nekaj nasvetov.
Se nekaj nasvetov.
technolog ::
Ja. Legalna zaprta programska oprema se igra višje igre, kot na primer razna sodelovenja z NSA.
mujek ::
To pa je Cryptowall.
Pred recimo pol leta, ko sem dobil en ključek - ki je imel datoteke tako okužene ni bilo rešitve (za tisto verzijo).
Določene verzije crpytowall (oz kopij/verzij) pa se dajo odklenit.
Vso srečo.
Vso srečo.
Ker uporabljaš preteklik, predpostavljam, da si ga že zamenjal za kaj boljšega.
Če ne, poglej v to temo za predloge: Anti-virus programi
(ne bodo ti odklenili fajlov, ampak zaščitili v prihodnje)
Na kratko: AVAST, Avira, AVG, BitDefender ... so zastonj in čisto OK.
MIHAc27 ::
Cryptowall ima en bug... namreč ne zakodira obstoječe datoteke temveč ustvari novo, original pa zbriše. Tako razni recovery programi lahko rešijo datoteke (Ontrack Easy recovery, kaka Recurva). Če bi dejansko prepisal originalno datoteko bi bilo kakršnokoli reševanje dosti težje...
dronyx ::
Ali se temu sploh reče "vdor"? Po moje si tu zagnal kakšen program, ki si ga dobil iz interneta, po pošti, ali prenesel iz kakšnih torrent strani.
jericho ::
Pomoje bo res kaj takega ja, ma dobr probal bom počistit nesnago z uporabo prejšnjih nasvetov, če ne bo šlo pa hebat ga, pa fresh install. Za bitdefenderja sploh nism vedu, da je free, bom sprobal.
bambam20 ::
s1l3 ::
Stranka je fasal verzijo tega virusa, kjer datoteke niso bile pobrisane ampak samo skopirane drugam. Poskusi search ce najde se kje te iste datoteke. Je pa tista verzija zaklenila samo dolocene tipe datotek kot npr. jpeg, png, doc, xls, pdf. Dokumente naceloma. Ni nic sistemskega oz. pomembnega
jericho ::
Hm, ne ni to, ker mi je oba HDD-ja zaklenil. SSD oz. c: disk je pa pustil tako, da sistem laufa.
Zaklenil? Kaj to pomeni? Da niso vidne črke pogonov? Daj disk v drugi PC in poglej kaj je vidno. Lahko, da se samo igra z neukim uporabnikom in v resnici nič ni zakriptirano.
BorutK-73 ::
Ali pa samo zbrisal črke particij.
Desni klik na moj računalnik/upravljaj/upravitelj diskov.
jericho ::
Upravitelj diskov mi pokaže diska in napisano šifrirano z funkcijo bitlocker.
Bom probal še na drug comp dat pa bom videl, če tam ne bo šifrirano.
Če je šifrirano z BitLocker, bo težka. Bi bilo dobro vprašati nekoga, ki se pozna na bitlocker.
Ne, ni. Imajo samo "zastonj" 30 dni poskusno dobo.
(imajo pa zastonj "online" skener, za pregled sistema na zahtevo, kar je nekaj čisto drugega)
NOD32 oz. ESET je tudi brezplačen.
- spremenil: MrStein ()
konspirator ::
Zadnja verzija naredi secure erase.
Phantomeye ::
slikaj se z iztegnjenim sredincem, poleg monitorja, na katerem izvajaš format in mu jo pošlji. Assert dominance.
Vdor je vdor, razlika je le v tem na kak način je bil napad izveden.
- spremenilo: Phantomeye ()
StarMafijec ::
Kako bi to izgledalo, če imaš folderje sinhronizirane z Dropboxom? Na Dropboxu se najde še ne enkriptirane datoteke in to je to?
bambam20 ::
No, a ni to zastonj. Potem si pa preko drugega maila ponovno aktiviraš 30 dnevno verzijo :). Jaz mam na ta način ESET smart securty zasonj že celo leto :).
- spremenilo: bambam20 ()
shadeX ::
12 mailov že?
Koliko jih boš še naredil?
Se ti pa da..
bambam20 ::
StarMafijec je izjavil:
@rupsi31: Isto velja za avast?
To pa ne vem.
Za ESET ta postopek velja in ga uporabljam :).
Si pač naredim enkrat na mesec novi račun na gmailu in podaljšam za en mesec :).
bambam20 ::
frke ::
Odvisno od paketa, ki ga imaš na dropboxu. Osnovni paket in pro paket hrani zbrisane datoteke 30 dni, pro paket z opcijo history 1 leto, poslovni paket pa trajno hrani izbrisane datoteke.
SloBiscuit ::
Ma daj disk v drug računalnik pa prekopiri tist kar rabiš pol pa formatni.
neznanec555
jericho ::
Phantomeye je izjavil:
Heh, to bi moral narest ja, pa sm se pozabu slikat. Se nism nč zafrkavu, sam format in je to to. Kdo bo to nesnago pucal in bil zihr da si spucal vse.
V mislih imam da je java verjetno kej kriva, ker je mulc mel minecraft in rab javo, je pa bla posodobljena.
Kok pa sploh je vreden 1 bitcoin?
Okoli 250 USD.
Tu je tečaj v živo: http://bitcoinity.org/markets/bitstamp/...
| » | Kripto virus kako reševati če sploh, umrem sicer ne če ne restavriram (strani: 1 2 3 4 5 6 )Oddelek: Pomoč in nasveti | 85261 (62117) | SeMiNeSanja |
| » | Passwordi me ubijajo! (strani: 1 2 3 4 )Oddelek: Informacijska varnost | 64076 (50495) | Pero_SLO |
| » | CCleaner mesec dni stregel malware (strani: 1 2 )Oddelek: Novice / Varnost | 21869 (16956) | Truga |
| » | Cryptowall 3.0 virusOddelek: Pomoč in nasveti | 9367 (7421) | bambam20 |
| » | heknili http://truecrypt.sourceforge.net, ki zdaj svari pred uporabo truecrypaOddelek: Informacijska varnost | 10100 (7919) | root987 |
