Forum » Omrežja in internet » Linksys wrt160nl
Linksys wrt160nl
tilenmpower ::
Pozdravljeni, imam namreč problem z naslednjim routerjem. Do sedaj normalno deloval original software, sedaj pa utripa samo power led. Probal hard reset 30/30/30 nič, probal preko cmdja pingat nič, probal z tftpjam nič, probal sem tudi drugi polnilec isto. Je svoje oddelal ali kaj? :)
tilenmpower ::
Ne to pa še nisem. Sicer mi ni jasno zakaj je kar na enkrat nehal delovati. Se je kar sam sesil software?
Spajky ::
Probaj zamenjat napajalc z drugim enakim preverjenim ...
tilenmpower ::
Ja z drugim sem preveril vendar ne prav za ta ruter, original software kot sem napisal :)
- spremenil: tilenmpower ()
lali12 ::
Sem imel podoben primer z WRT 120N in sem ga rešil po teh navodilih:
1. power on the router while holding the reset button. (the router boots but just the power LED is on)
now, when i connect the cable to port #1 the LED for port #4 is on
2. connect the cable to port #4 (the LED for port #1 in on)
3. open a browser window and go to the default IP adress of the router (http://192.168.1.1 if you haven't changed it)
a window that asks you to upload a firmware opens up. navigate to the location of the lates firmware you downloaded
4. restart the router using the restart button present on the same page
5. now the reset button on the back of the router works.
6. proceed to reset the router and enjoy...
INTEL C2DUO 6750 - ASUS P5K - 8600GTS
500GB - 4GB RAM - MAG 22"
tilenmpower ::
Hja pri meni to nedeluje samo otripa power led, ko vklopim kabel v porte ni nubene druge lučke.
lali12 ::
Potem je pa potrebno probati samo še JTAG kot je predlagal MaterVola.
| » | Linksys WRT54G težavaOddelek: Strojna oprema | 1766 (1560) | d4vid |
| » | Kako popraviti router Linksys WRT160N po neuspešni nadgrandji firwara! NUJNO!Oddelek: Pomoč in nasveti | 3943 (3770) | Padly88 |
| » | nastavitve ali downgrade router-ja WRT54GLOddelek: Omrežja in internet | 2989 (2414) | nx6325 |
| » | Naložil DD-WRT sedaj pa ne morem na orig. firmwareOddelek: Omrežja in internet | 2274 (1729) | zzitop |
| » | Problem pri flashanju Buffalo WHR-HP-G54 - zaflashan routerOddelek: Pomoč in nasveti | 3382 (2754) | Pyr0Beast |
