Forum » Strojna oprema » Samodejno izklapljanje računalnika
sennheiser ::
Zdravo,
Imam Pentium G3420, asrock H81M, 4gb rama 1600 - 1,65V (ostali iz prejšnega builda).
Računalnik se samodejno ugaša. Časovno čisto različni čas.
Preveril rame - OK
Preveril diske - OK
Preveril napajalnik - OK
Clean setup windows 7 in test 3 dni - OK brez 1 težave.
Potem pa ponovno samodejno ugašanje računalnika.
Temperature komponent so OK.
Nastavitve za varčevanje - vse nastavljeno na nikoli ugasni.
Ne najdem več rešitve. Spodaj so še izvoženi eventi.
Level Date and Time Source Event ID Task Category
Error 27.12.2014 20:20:59 Microsoft-Windows-WMI 10 None "Event filter with query ""SELECT * FROM __InstanceModificationEvent WITHIN 60 WHERE TargetInstance ISA ""Win32_Processor"" AND TargetInstance.LoadPercentage > 99"" could not be reactivated in namespace ""//./root/CIMV2"" because of error 0x80041003. Events cannot be delivered through this filter until the problem is corrected."
Error 27.12.2014 20:18:06 Microsoft-Windows-WMI 10 None "Event filter with query ""SELECT * FROM __InstanceModificationEvent WITHIN 60 WHERE TargetInstance ISA ""Win32_Processor"" AND TargetInstance.LoadPercentage > 99"" could not be reactivated in namespace ""//./root/CIMV2"" because of error 0x80041003. Events cannot be delivered through this filter until the problem is corrected."
Error 27.12.2014 20:08:41 Microsoft-Windows-WindowsUpdateClient 20 Agent Windows Update Napaka pri namestitvi: Windows ni namestil te posodobitve z napako 0x800f020b: Logitech driver update for Logitech QuickCam Communicate STX.
Error 27.12.2014 19:19:46 Microsoft-Windows-WMI 10 None "Event filter with query ""SELECT * FROM __InstanceModificationEvent WITHIN 60 WHERE TargetInstance ISA ""Win32_Processor"" AND TargetInstance.LoadPercentage > 99"" could not be reactivated in namespace ""//./root/CIMV2"" because of error 0x80041003. Events cannot be delivered through this filter until the problem is corrected."
Error 27.12.2014 19:16:11 Microsoft-Windows-WMI 10 None "Event filter with query ""SELECT * FROM __InstanceModificationEvent WITHIN 60 WHERE TargetInstance ISA ""Win32_Processor"" AND TargetInstance.LoadPercentage > 99"" could not be reactivated in namespace ""//./root/CIMV2"" because of error 0x80041003. Events cannot be delivered through this filter until the problem is corrected."
Error 27.12.2014 18:56:41 Microsoft-Windows-WMI 10 None "Event filter with query ""SELECT * FROM __InstanceModificationEvent WITHIN 60 WHERE TargetInstance ISA ""Win32_Processor"" AND TargetInstance.LoadPercentage > 99"" could not be reactivated in namespace ""//./root/CIMV2"" because of error 0x80041003. Events cannot be delivered through this filter until the problem is corrected."
Error 27.12.2014 18:28:30 Microsoft-Windows-WMI 10 None "Event filter with query ""SELECT * FROM __InstanceModificationEvent WITHIN 60 WHERE TargetInstance ISA ""Win32_Processor"" AND TargetInstance.LoadPercentage > 99"" could not be reactivated in namespace ""//./root/CIMV2"" because of error 0x80041003. Events cannot be delivered through this filter until the problem is corrected."
Error 27.12.2014 17:33:34 Microsoft-Windows-WMI 10 None "Event filter with query ""SELECT * FROM __InstanceModificationEvent WITHIN 60 WHERE TargetInstance ISA ""Win32_Processor"" AND TargetInstance.LoadPercentage > 99"" could not be reactivated in namespace ""//./root/CIMV2"" because of error 0x80041003. Events cannot be delivered through this filter until the problem is corrected."
Error 27.12.2014 12:51:53 SideBySide 80 None "Activation context generation failed for ""c:\program files\CCleaner\CCleaner.exe"".Error in manifest or policy file """" on line . A component version required by the application conflicts with another component version already active. Conflicting components are:. Component 1: C:\Windows\WinSxS\manifests\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.17514_none_41e6975e2bd6f2b2.manifest. Component 2: C:\Windows\WinSxS\manifests\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.17514_none_fa396087175ac9ac.manifest."
Error 27.12.2014 12:25:05 Microsoft-Windows-WMI 10 None "Event filter with query ""SELECT * FROM __InstanceModificationEvent WITHIN 60 WHERE TargetInstance ISA ""Win32_Processor"" AND TargetInstance.LoadPercentage > 99"" could not be reactivated in namespace ""//./root/CIMV2"" because of error 0x80041003. Events cannot be delivered through this filter until the problem is corrected."
Warning 27.12.2014 12:22:42 Microsoft-Windows-RPC-Events 11 None Possible Memory Leak. Application (C:\Windows\System32\svchost.exe -k LocalServiceNetworkRestricted) (PID: 808) has passed a non-NULL pointer to RPC for an [out] parameter marked [allocate(all_nodes)]. [allocate(all_nodes)] parameters are always reallocated; if the original pointer contained the address of valid memory, that memory will be leaked. The call originated on the interface with UUID ({3F31C91E-2545-4B7B-9311-9529E8BFFEF6}), Method number (20). User Action: Contact your application vendor for an updated version of the application.
Error 27.12.2014 12:22:06 Microsoft-Windows-Dhcp-Client 1002 Address Configuration State Event The IP address lease 192.168.1.126 for the Network Card with network address 0xD050991EAE57 has been denied by the DHCP server 89.212.0.1 (The DHCP Server sent a DHCPNACK message).
Preveril rame - OK
Preveril diske - OK
Duhec ::
Se res ugaša ?
Če se ugaša imaš nekaj narobe z napajalnikom, kondenzatorji, plata...
Če pa se resetira (ponovno zažene) pa so lahko kaki muhasti gonilniki za neko napravo, nekompatibilni spomini, stara verzija biosa, temp., +1000 stvari.
Imaš 64-bitno verzjo in vse popravke (windowsupdate)?
Če imaš več palčk spomina testiraj najprej samo z eno in jo menjaj z drugo, tretjo...
Kako si stestiral spomin, hdd in napajalnik?
Daj, razpiši se, da ne vlečem(o) iz tebe.
http://normio.si/
sennheiser ::
Rami, napajalc, hdd stestirani na drugem PC-ju, so delujoči. PC se ugasne komplet. Ampak ne tako da ga zmanjka naenkrat, ampak identično postopku kot če mu daš sam ukaz da se ugasne.
Windowsi so 64 bitni, z vsemi updati.
sennheiser ::
Rami so mi ostali od prejšnjega builda. Taka odločitev je bila na podlagi prebranega da bi stvar morala delati. Čakam sicer že rame za test z manjšo voltažo.
Napajalc je LC 550W star 4 leta, ampak je poganjal 1x bolj požrešne komponente bp. Pomoje je glavni problem nekje v SW, ker se računalnik ugasne enako kot da bi mu dal tak ukaz. In ni da bi sam sesipalo ali pa kak blue screen.
Zanimivo mi pa je da recimo ko dam prime ali pa kak špil PC dela brez 1 težave. Ko pa se samo brska po youtube ali 24 ur... pa se ugasne.
Windows 8.1 še nisem probal.
sennheiser ::
Napajalnik je OK. Na tem sistemu preizkusil nov napajalnik, star 1 mesec. Situacija identična, testi delajo bp po 1 uro in več, navadno surfanje po internetu pa ugasne računalnik po različnem časovnem obdobju.
Danes testiram še ram in pogledam ON/OFF stikalo če je slučajno tam težava.
Dodatno bom pač še namesto 7ke nasnel 8.1
Duhec ::
A se mi zdi, da se ti dogaja, ko si na netu? Kaj, če te heca mrežna kartica in dobi ali pa sama zgenerira shutdown paketek in sistem gre v zaustavitev ?
Imaš kak oddaljen dostop za to mašino?
http://normio.si/
sennheiser ::
Nobenega oddaljenega dostopa. Je pa res da se to v 95% dogaja na brskanju po netu. Rami so preverjeni in so tudi OK. Stikalo ON/OFF tudi OK. Zaenkrat mi ostane samo še oba diska ssd in navaden hdd da še enkrat ponovno preverim. Windows 8.1 sicer zaenkrat še ne kaže težav.
GTX970 ::
Bootaj v ubuntu live linux in začni surfati.
Če dela brez ugašanja potem je Duhec uganil diagnozo https://slo-tech.com/forum/t631276/p465....
sennheiser ::
Izkazalo se je zaenkrat da je bila potrebna posodobitev firmware na ssd disku. Ampak se je pa pojavila nova težava zaslon po novemu zagonu vsakič obrne za 180°
sennheiser ::
SSD je Kingston ssdnow V+200. FW ni pomagal v celoti tako da sem sistem preselil na navaden hdd in ni teh težav več. SSD gre pa na garancijo.
Sliko obrača v windowsih na VGA ali pa DVI kablu. Sicer zaenkrat zgleda da se je vse skupaj umirilo z starejšimi driverji.
Garancija ti nič nebo pomagal. To je lepo sandforce pogon, katerih podobni problemi so znana hiba (pa tudi če ti ga menjajo za v300, imaš lahko iste probleme, ker ima isti kontroler). Sicer se komp praviloma ne ugaša samodejno pri teh ssdjih, ampak vrže ven F7 bsod...
- spremenil: iloveboobz ()
sennheiser ::
Zakaj pa nebi pomagala garancija? Če še windowsa ni mogoče več nasneti na ta disk? Domnevam da bi dobil vsaj v tej smeri delujoči disk, pa tudi če bo za skoraj 2 leti kot je bil ta.
sennheiser ::
Brez lan-a težava ostaja oz. dodatno je začelo rotirati sliko za 90 ali 180°.
Do sedaj narejeno:
Bios update
Windows na ssd - ne dela
Windows na hdd - dela dlje ampak težava ostaja
Test na 3eh ramih 2 komada 1,65V en na 1,5V, nobene razlike.
Menjan napajalc z novim za test, nobene razlike.
Menjan DVI in VGA kabel - še vedno obrača sliko.
Verzija Windowsa ni problematična, ker mi na drugih PC-jih deluje brez 1 težave.
Dodatna informacija, na PC je priklopljena samo miška in tipkovnica. PC nima nobenih dodatnih naprav vgrajenih.
Do sedaj narejeno:
Bios update
Duhec ::
Glede vrtenja ekrana izklopi "Upravljaj bližnjice" v nastavitvah za Intel grafiko. (desni klik na namizju, lastnosti grafike, (odpre se Intel vmesnik), Možnosti in podpora, Upravljaj bližnjice----->Onemogoči)
Shrani, restart in test.
http://normio.si/
sennheiser ::
Probano na 3eh različnih ramih, vsak ločeno 2 kom 1,65 en komad pa na 1,5V. In katerkoli ram je bil je delal.
@Duhec obračanje zaenkrat je tako rešeno, ampak samodejno zaustavljanje pa nažalost še ne.
sennheiser ::
Računalnik sem prenesel na drugo lokacijo, zaradi suma da se mogoče pojavljajo dodatne motnje ob steni, kjer so se komponente nahajale. Stena je večinoma prepletena z električnimi vodi.
Rezultat je da se je v zadnjih 24ih urah samo 1x samodejno ugasnil. Ampak še vedno to ni rešitev.
Ali je mogoče možno da enostavno GPU v tem Pentium G3420 ne zmore navadnega youtube predvajanja ali animacij na pasjansi? Če furam furmark da je cpu in gpu na full loadu pridejo temperature do max 62°C po 2eh urah delovanja. Ampak PC med testi deluje vedno stabilno.
BorutK-73 ::
A je že bilo omenjeno da probaj drugo vtičnico?
Ps
Jaz sem imel na računalniku v mojem podpisu probleme z 1.65V rami. Sistem je zmrzoval ali bsod, ampak to se je dogajalo 1x na mesec. Odkar so 1.5V niti enega problema z računalnikom.
Ps
- spremenil: BorutK-73 ()
sennheiser ::
Računalnik je trenutno popolnoma na drugi lokaciji (70 km stran). In že drugi dan dela, tako da mislim da bo edina rešitev umik računalnika od problematične stene. Ker je v steni vod za vsa nadstropja + na drugi strani je priklopljen hladilnik, napa, pečica, kuhalna plošča, tako da je prepleteno z elektriko. Upam da bo to rešitev.
sennheiser ::
Ponovno se mi pojavla identična težava. Računalnik se iz popolnoma neznanih razlogov ugaša.
Do sedaj narejeno:
Nov napajalc
Nov disk
Windows 7, 8 v večih verzijah.
Prenapetostna zaščita, zamenjava lokacije računalnika.
Enostavno ne vidim več nobene pametne rešitve. Preostane mi samo še procesor in plata. Ampak ti naši servisi so tako hitri in učinkoviti da dvomim da so sposobni odkriti napako.
Do sedaj narejeno:
Nov napajalc
Nov disk
crniangeo ::
preveri, če imaš kakšno bedarijo nastavljeno v power managerju..
http://support2.microsoft.com/kb/2545227
Glede na to kakšne errorje imaš, bi reku da imaš nek driver k ti povzroča hud memory leak , sam ne vem če bi le ta povzročal ugašanje sistema.
Convictions are more dangerous foes of truth than lies.
sennheiser ::
Zaenkrat zgleda da napaka ni v programih ampak kar v opremi. Napajalnik je OK, ram je OK. Možnost je da je nekaj narobe z osnovno ploščo ali procesorjem. PC je bil predviden za uporabo z integrirano grafično na procesorju. Trenutno sicer nimam opcije da bi preveril ali je grafična krivec ali ne.
| » | Random freeze računalnikaOddelek: Pomoč in nasveti | 2050 (1789) | Venoox |
| » | HP Pavilion dv7 reboot problemOddelek: Pomoč in nasveti | 2654 (2587) | Yacked2 |
| » | windows 7 appcrash problemiOddelek: Pomoč in nasveti | 2967 (2881) | blazkox |
| » | En majhen trik za vseOddelek: Programiranje | 1997 (1593) | Trubar |
| » | Win2k keyboardOddelek: Programska oprema | 1920 (1748) | JLP |
