CD-RW nehal pect cd-je
MrX ::
kar na lepem mi ne dela vec cd-rw. WTF!!! pecem z nerotom in mi javi:
(pa z CloneCd tud noce :'( )
Windows XP 5.1
WinAspi: -
ahead WinASPI: File 'C:\Program Files\ahead\Nero\Wnaspi32.dll': Ver=2.0.1.47,
size=184387 bytes, created 5/13/2002 5:33:42 PM
Nero Version: 5.5.8.3
Recorder: Version: ZS0K - HA 1 TA 0 - 5.5.8.3
Adapter driver: <> HA 1
Drive buffer : 1984kB
Bus Type : default (0) -> ATAPI
CD-ROM: Version: YSR7 - HA 0 TA 1 - 5.5.8.3
Adapter driver: HA 0
=== Scsi-Device-Map ===
DiskPeripheral : MAXTOR 6L040J2 A93. nvidesm Port 0 ID 0 DMA: ?
CdRomPeripheral : LITE-ON LTR-40125S ZS0K nvidesm Port 0 ID 0 DMA: ?
CdRomPeripheral : LITEON CD-ROM LTN526D YSR7 nvidesm Port 0 ID 1 DMA: ?
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 61865984 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 511MB (523760kB)
Free physical memory: 256MB (262964kB)
Memory in use : 49 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Wizard: Off
CD-ROM (ISO)
3.4.2003
4:04:11 PM #1 Text 0 File Isodoc.cpp, Line 6004
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
4:04:11 PM #2 Phase 90 File dlgbrnst.cpp, Line 1550
Buffer Underrun Protection activated
4:04:11 PM #3 Text 0 File Reader.cpp, Line 118
Reader running
4:04:11 PM #4 Text 0 File Writer.cpp, Line 129
Writer LITE-ON LTR-40125S running
4:04:11 PM #5 Text 0 File Burncd.cpp, Line 3033
Turn on Disc-At-Once, using CD-R/RW media
4:04:11 PM #6 ISO9660GEN -11 File geniso.cpp, Line 4428
First writeable address = 0 (0x00000000)
4:04:11 PM #7 Text 0 File ThreadedTransferInterface.cpp, Line 684
Setup items (original item values)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original CD pos #0 + 359257 (359257) = #359257/79:50.7
relocatable, CD pos for caching/writing not required/required, no patch infos
4:04:13 PM #8 Text 0 File DlgWaitCD.cpp, Line 199
Last possible write address on media: 359846 (79:59.71)
Last address to be written: 359256 (79:52.06)
4:04:15 PM #9 Text 0 File DlgWaitCD.cpp, Line 1401
Recorder: LITE-ON LTR-40125S;
CDR code: 00 97 32 19; OSJ entry from: Prodisc Technology Inc.
ATIP Data:
Special Info [hex] 1: E0 00 B0, 2: 61 20 13 (LI 97:32.19), 3: 4F 3B 48 (LO 79:59.72)
Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 80 00 (invalid), 3: 00 80 80 (invalid)
4:04:15 PM #10 Text 0 File ThreadedTransferInterface.cpp, Line 834
Prepare recorder LITE-ON LTR-40125S for write in cue-sheet-DAO
DAO infos:
MCN:
TOCTYPE: 0x0 Close CD
Tracks 1 to 1:
TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 736065536
4:04:15 PM #11 Text 0 File ThreadedTransferInterface.cpp, Line 684
Setup items (after recorder preparation)
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 359257 blocks [LITE-ON LTR-40125S ]
4:04:15 PM #12 Phase 24 File dlgbrnst.cpp, Line 1550
Caching of files started
4:04:15 PM #13 Phase 25 File dlgbrnst.cpp, Line 1550
Caching of files completed
4:04:15 PM #14 Phase 36 File dlgbrnst.cpp, Line 1550
Burn process started at 40x (6,000 KB/s)
4:04:15 PM #15 Text 0 File ThreadedTransferInterface.cpp, Line 1961
Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0):
write at #0
4:04:15 PM #16 Text 0 File Mmc.cpp, Line 11605
StartDAO : CD-Text - Off
4:04:15 PM #17 Text 0 File Mmc.cpp, Line 15904
Set BUFE: supported -> ON
4:04:15 PM #18 Text 0 File Mmc.cpp, Line 11848
CueData, Len=32
41 00 00 14 00 00 00 00
41 01 00 10 00 00 00 00
41 01 01 10 00 00 02 00
41 aa 01 14 00 4f 34 07
4:04:23 PM #19 SCSI -500 File Cdrdrv.cpp, Line 1403
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x02BD0000
Status: 0x02 (0x03, SCSI_ABORTED)
HA-Status 0x10 (0x0A, SCSI_HASTAT_REQUEST_SENSE_FAILED)
TA-Status 0x00 (0x00, OK)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x26
Sense Qual: 0x02
CDB Data: 0x2A 0x00 0xFF 0xFF 0xFF 0x6A 0x00 0x00 0x1F 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x05 0x00 0x00 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x26 0x02
4:04:23 PM #20 CDR -500 File Writer.cpp, Line 330
SCSI/IDE Command aborted
4:04:23 PM #21 Text 0 File ThreadedTransfer.cpp, Line 222
all writers idle, stopping conversion
4:04:23 PM #22 Text 0 File ThreadedTransfer.cpp, Line 216
conversion idle, stopping reader
4:04:38 PM #23 Phase 38 File dlgbrnst.cpp, Line 1550
Burn process failed at 40x (6,000 KB/s)
4:04:38 PM #24 Text 0 File Scsicmd.cpp, Line 386
SCSI not using temporary buffers
20 out of 20 temporary buffers allocated
Existing drivers:
Registry Keys:
HKLM\Software\CPUCooL (Power saving: CPUCooL)
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs :
0 (Security Option)
NEC ND-3540A problem...
282784 (2075) dean444
LG GSA-4120B dela probleme pri pečenju DL DVD+Rjev
442195 (2004) mtosev
Plextor writer 24/48/48 problem! (strani: 1 2 )
646229 (5738) Hux
Težave s pekačem
122375 (2315) boštjan
PLEXTOR BurfProof unicuje cdje - prosim pomagajte!
92163 (1917) krho
