Alien franšiza [Alien: Covenant ( Prometheus 2)]
Sarkozy ::
yesssssss
padel je rekord
25 strani
torej pri temi Alien: Awakening
se moramo potruditi da bomo to presegli :D
Ils sont fous ces Slovenes!
globoko grlo ::
Priznam, da se mi ne da vsega brat, ampak men je bil alien vs predator II al kolk je že bil, kul zadeva. Zdej tale zadnja 2 skropucala so pa ena navadna skropucala brez repa in glave + bedni igralci + bedna zgodba + idiotske odločitve + posiljeni scenariji oz. pripetljaji + pofl.
Glasujem za Alien vs Predator Vs Inženirci.
Itak Predator potolče vse!
Sarkozy ::
[D]emon je izjavil:
Po Hollywoodski matematiki tako ali tako vsak film pridela izgubo. ;)
vsi ravno ne
na te filme so producenti več kot ponosni :D
The Top 10 Most Profitable Films in Box Office History
a pazi to so vsi filmi, delani za 13 letne mulce
nobeden od njih namreč ni R-Rated
[D]emon ::
Sarkozy je izjavil:
[D]emon je izjavil:
vsi ravno ne
Hollywood accounting @ Wikipedia
Sarkozy ::
 James Cameron
James Cameron
Alien: Covenant is not a film I would have made
I thought that Alien: Covenant was a great ride. It was beautiful. I love Ridley’s films and I love his film making , I love the beauty of the photography, I love the visceral sense that you’re there, that you’re present.
It’s not a film that I would have made. I don’t like films where you invest in a character and they get destroyed at the end. I would not have made that film. I can’t comment on where Ridley is going with it but I think he is obviously trying to create a greater universe around it and more backstory with the Engineers and so on. I’ll show up for the next one, absolutely.
Sarkozy je izjavil:
[D]emon je izjavil:
vsi ravno ne
Top 5 filmov z oznako R box office worldwide
1. Deadpool (2016) $783.1 million
2. The Matrix Reloaded (2003) $742.1 million
3. Logan (2017) $616.2 million
4. The Passion of the Christ (2004) $611.9 million
5. The Hangover Part II (2011) $586.8 million
Sarkozy ::
oo7 je izjavil:
hmm, Deadpool in Logan sta FOXova
dokaz, da tudi R movies lahko profitirajo
kapo dol
p.s.
nekaj profita od teh dveh lahko FOX primakne k franšizi Alien :D
Sarkozy je izjavil:
oo7 je izjavil:
kapo dol
p.s.
Popolnoma zasluženo, ker oba filma Logan in Deadpool sta fenomenalna men osebno sta med top 5 najboljših super herojskih filmov vseh časov pa je teh filmov že več kot 100.
No ja saj minusa niso naredili z Zavezo edino zaslužili niso toliko kot so hoteli tako, da ja FOX naj malo primakne k franšizi Alien :)
Samael ::
globoko grlo je izjavil:
Ne nujno. Močnejši Engineer naj bi v neposrednem boju dominiral. Je pa jasno, da predatorje poznamo bolj in so se nam posledično bolj priljubili :)
In Predator: Fire and Stone, a physical fight between an experienced Predator and an Engineer shows the latter to be far stronger with it dominating the fight, shrugging off a plasma bolt and heavily wounding the predator, causing it to rely on its stealth tactics, equipment and the aid of a human to defeat the Engineer.
http://avp.wikia.com/wiki/Engineer
Sarkozy ::
oo7 je izjavil:
tudi meni :D
Samael je izjavil:
Za Predatoprja vemo, da ima hudo tehnologijo in, da je odličen lovec. Za inžinirje se pa ŠE ne ve točno kakšno tehnologijo uporabljajo v boju.
Če bi se pa spopadla v klasični rokoborbi predator vs inžinir bi znalo biti zanimivo čeprav je inžinir večji kot predator. Predator naj bi bil visok 2 metra 33 cm in inžinir 2 metra 74 cm.
Samael ::
No, saj, če si razumel angleški del zgoraj si najbrž videl da je v AvP franšizi, natančneje Predator: Fire and Stone stripu do tega spopada že prišlo, kjer je Inženir dominiral. Fizično moč nam je demonstriral tudi v Prometheusu, kjer Davida dvigne kot dojenčka in mu, kot bi odprl piksno pira, odtrga glavo :) Tko na hitro, mimogrede.
Toliko o fizičnem delu, tega kako bi delovala tehnologija pri Inženirju napram Predatorju pa res še ne vemo, zato bi nas večina najbrž stavila kar na dobro znanega Predatorja z njegovo stealth tehnologijo, se pa od tu dalje pojavi špekuliranje, da če je bil Schwarzenegger zgolj zaradi blata neviden Predatorju, medtem ko ima Inženir oklep, koliko bi stealth tehnologija tu sploh pomagala Predatorju, ampak pustimo to - zgolj fanfiction špekuliranje :)
Whilst further exploring the jungle, Galgo and Ahab eventually, rather accidentally, meet the Engineer face to face. Galgo suddenly flees the scene, much to Ahab's surprise and after a brief battle, the Engineer quickly overpowers him, breaking an arm and a leg. Ahab retreats back into the Perses, the Engineer in hot pursuit. Ahab in a last ditch effort, manages to impale a harpoon into the Engineer's chest. The Engineer, however, is able to tear it out and prepares to finish Ahab off. Just before the Engineer kills the weakened Predator, Galgo returns and shoots him in his chest wound with the Engineer rifle that Galgo had previously found.
Alien Covenant Deleted Scenes Blu-Ray HD
Sarkozy ::
F . . K, zdaj pa nisem več siguren
a je na koncu filma David ali Walter
ali pa David v telesu Walterja 8-O
FTad ::
js bi rekel, da je David. V sceni, ko sta se tepla David in Walter si videl noz. Predvidevam, da je David premagal Walterja in si odrezal dlan, da se je lahko pretvarjal, da je Walter.
Pa frizure imata drugačne8-)
Scaramouche ::
FTad je izjavil:
To resno morate debatirati, očitno je preveč res in meni je bilo smešno kako ga niso stestirali ko je prišel gor...
Samo eno vprašanje in vedeli bi...
Samael ::
Jaz tudi mislim, da je David. Oz. že ko je prisel ven (še predno je karkoli storil) mi je delovalo, da tisti nož tam niso pokazali za brezveze, potem pa odrezali kader in da je to David.
bambam20 ::
Samael je izjavil:
Logično , da je David, ker ni vedel pogovora z uno fračo brze modrca, da ji bo Walter pomagal pri gradnji kolibe.
Sarkozy ::
kaj pa David v telesu Walterja ?
FTad ::
Scaramouche je izjavil:
FTad je izjavil:
Kako tocno bi ga pa testirali? Le kdo je takrat razmisljal o tem, ko so imeli pa Aliena za petami....
bambam20 ::
Vsak predator ima plasma Canon , ki inženirja preluknja kot za šalo.
Scaramouche ::
FTad je izjavil:
FTad je izjavil:
Vedela je da sta se tepla in da je mogoče da bi se lahko to zgodilo...
Saj jo je Walter rešil!
Vendar je ostal za njo...
bambam20 ::
Kot vidimo na posnetku je film pol protislovij. Že to, da sta vizuelno dva modela enaka. Zakaj bi kdo naredil dva vizuelno enaka modela.
Kot drugo pa David ne ve za kode na ladji, tudi ni imel časa, da bi vstopil v Walterjev podatkovni sistem.
FTad ::
bambam20 je izjavil:
To se mi ne zdi sporno..v Terminator fransizi, so tudi vsi T-800 modeli narejeni po isti osebi....
Kdaj je dobil Valter tisto veliko brazgotino na licu? Če jo je takrat, ko sra se pretepala Valter in David potem ne vidim smisla zakaj bi si David naredil to brazgotino če jo pa nobeden ni videl na Valterju?
bambam20 ::
FTad je izjavil:
To pa ne bo držalo, da bi vsi modeli T-800 bili vizuelno podobni Šwarciju.
oo7 je izjavil:
Čakaj, da vidiš director s cut verzijo ;). Brez veze si jo že ni naredil.
  • spremenilo: bambam20 ()
Brez heca, glejte frizuro pri obema; čeprav sta na koncu obe kratki, ima Walter (vedno) lepše pošlihtato, David pa čisto malo skuštrano. In slednji je šel na koncu na plovilo (sicer si je odrezal roko itd.) ;)
Kar se pa ustvarjanja Alienov tiče pa moramo očitno res povsem odmisliti ostale zgodbe (Alien vs Predator itd.), ker sicer nima smisla, da so se predatorji igrali z aieni pred nekaj tisočletji na našem planetu; ali to ali pa si lahko vsak E.T. mulc ustvari alieana v garaži (kar bi bilo dokaj žalostno za Davida, ki misli, da je zaradi njegove "ustvarjalnosti" nekaj več od ostalih).
  • spremenil: Gregor P ()
FTad ::
FTad je izjavil:
Kakor se jaz spomnim se iz Terminator: Salvation filma, so bili vsi modeli na production line-u in tudi CGI narejeni po Svarciju ;)
bambam20 ::
FTad je izjavil:
FTad je izjavil:
Bistvo, da so določeni dobili kožno preobleko je bilo, da so se lahko vtihotapili med uporniško vojsko. DOkler niso ti ugotovili, da jih psi zaznavajo. Potem je vse skupaj izgubilo smisel.
Klasičen terminator ni imel kože,pač pa zgolj enoskelet, ker ni bilo potrebe.
Sarkozy ::
oo7 je izjavil:
Valter je dobil brazgotino šele v pretepu z Davidom (100%)
plus Daniels je takrat zapičila žebelj v brado Davida
plus Walter je zaštihal Davida najmanj 3x v trebuh
vse skupaj mi je sumljivo :D
Sarkozy je izjavil:
oo7 je izjavil:
Potem ni smisla, da bi si šel David delat brazgotino >:D
Za androida ne vem koliko je usodno, da ga je trikrat zaštihal v trebuh.
Ja je sumljivo :)
Res preveč komplicirate -> frizura!
Samael ::
In vsak inženir v boju ima v roki kuhalnico in ponev ;-)
The two are soon cornered by a group of Xenomorphs, as the two prepare for death, the Engineer suddenly emerges within the chamber holding a rifle-like weapon. The Xenomorphs attack him but are quickly incinerated by the superior being's weaponry. After the battle, Clara expresses her gratitude towards the Engineer and thanks him for saving them. The Engineer replies by pointing his gun at them and incinerating them like the Xenomorphs he had just fought.
http://avp.wikia.com/wiki/Engineer_(Fir...
Da, predator gre lahko v lov in se zajebava proti tehnološko inferiornim rasam, ki se niti zavedajo ne njegovega obstoja, kot smo ga videvali do sedaj (pa še tu jih faše v džungli od neoboroženega Arnija), se pa lahko zadeva hitro spremeni, ko ima na drugi strani bitje, ki se zaveda njegovega obstoja, ki je tehnološko enakovredno, ali pa ga celo prekaša.
Samael ::
V osnovi meni predator deluje dokaj primitivna rasa, ker veljajo pravila plemenske skupnosti in kjer je lov poveličevan kot vodilo v družbi. Znani so jim tudi rituali, kot je iniciacija, kjer deček odraste v moškega, tako da si prisluži trofejo aliena.
Lov na ljudi ali aliena je kot safari, lov na trofejo, leva. In kdaj se seveda tudi zalomi.
Da gre za, v primerjavi z ljudmi, zelo staro raso ni dvoma (glede na to da so prve piramide na zemlji njihovo delo) in posledično tudi razviti ladijski pogoni, možnost potovanja med planeti, zavedanje da obstajajo v vesolju tudi druge rase, v primerjavi z zemljani razvito orožje, to je pa tudi vse. V osnovi še vedno funkcionirajo kot primitivna plemenska skupnost.
K0l1br1 ::
Če bi bil predator neprimitivna rasa (torej decko s tablico, iphonom, malo ozek v ramenih, bled, nesposoben dvigniti več kot 5 kg, s tankim in nežnim glaskom, cele dneve v fotelju ali na kavču, edini smisel igrce ter zabava, s kultutrnim čutom, ki mu ga določa youtube), potem res ne vidim smisla, da bi tak film gledal, niti si ne predstavljam, kako bi lahko kdorkoli gledal to mehkužno osladnost.
  • spremenilo: K0l1br1 ()
Samael ::
Seveda, to je jasno :) Saj sem omenil zgoraj, da imamo radi predatorja :)
Zgolj debatiramo.
Predators vs Engineers - Explained
Video razloži zgodbo z stripa. Zmagovalec je ampak ne na ravno pošten način ):
T-Majo ::
Tukaj naj bi bila obrazložena vsa bitja v Alien franšizah.
http://screenrant.com/complete-guide-cr...
  • spremenil: T-Majo ()
Jutri izide uradno DVD Alien Covenant
Han ::
vostok_1 že kampira pred trgovino. :))>:D:P
nurse013 ::
Haha
you gotta be kidding me...
Najboljši film ever.
Nism ga sicer pogledu, ampak važn da je vostok živčn.
  • predlagalo izbris: [D]emon ()
yoco ::
Končno sem tudi sam uspel pogledat film! :)
Mene je film razočaral. Ne bom rekel, da je slab, ampak ko jaz slišim Alien se vedno vrnem v čas, ko sem prvič gledal Aliens in kako prestrašen sem bil ob gledanju. To največ pogrešam. A ne bi bilo bolje, če bi pristali na planetu, našli Davida, ga vzeli nazaj na ladjo, on pa bi tam začel s svojimi eksperimenti in bi se morija kmalu začela? :P
David je bil na tistem planetu veliko let tako, da je že tam začel z eksperimenti. Saj če bo nadaljevanje bo imel 2000 ljudi na katerih bo lahko eksperimentiral.
bambam20 ::
yoco je izjavil:
Zakaj si bil prestrašen on glednaju d(v)ojke? Meni se ni zdela nič grozljiva, saj smo vendar spremljali do zob oborožene vojake.
Strašljivi sta enka in dvojka, kjer dejansko nimajo strelnega orožja.
oo7 je izjavil:
Upam, da se bodo v naslednjem delu streljali na polno, tako kot v Aliensih :). Gora alienov + David proti 20-im marincem. Nekaj v stilu Starship troopers bi bilo zakon.
Vazelin ::
Meni osebno Prometheus > Convenant.
Morda dočakamo Engineers vs predators vs aliens:D
Vazelin je izjavil:
To bi bila klavnica
Ali pa ne :P
Danes je izšel DVD Alien Covenant ;)
globoko grlo ::
Za kolk se ga pa dobi?
25 / 73
Prometheus (strani: 1 2 3 4 … 22 23 24 25 )
Oddelek: Sedem umetnosti
1221291623 (79241) EwokPredator
Alien (Tv serija)
256102 (3531) oo7
Alien 5 (strani: 1 2 )
6621353 (11689) oo7
Alien: Awakening (strani: 1 2 )
9222671 (16287) oo7
Alien: Covenant vs. Passengers
399146 (8511) vostok_1
