Okno
Okno
RED_line ::
Pozdravljeni
mene zanima kako se nastavi, da se ti pojavi okno izbire, ko vklopiš kakšno napravo v PC. to je tisto ukno ki te vpraša ali bi rad odpru mapo, zagnal kak program,.. Imam win7.
hvala za pomoč
  • spremenilo: RED_line ()
duff ::
Verjetno misliš na autorun, ko vstaviš CD ali USB ključek? Če je to to, potem:
When you turn AutoPlay on, you can choose what should happen when you insert different types of digital media into your computer. For example, you can choose which digital media player is used to play CDs. When AutoPlay is turned off, you are prompted to choose what you want to do when you insert digital media into your computer.
Open AutoPlay by clicking the Start button , and then clicking Control Panel. In the search box, type autoplay, and then click AutoPlay.
Do one of the following:
To turn AutoPlay on, select the Use AutoPlay for all media and devices check box.
To turn AutoPlay off, clear the Use AutoPlay for all media and devices check box.
Click Save.
RED_line ::
Ok, res nisem imel obkljukano. Samo tudi zdaj ko sem obljkal in celo reštartal pc, mi še vedno ne dela :/
nihšče nima ideje kaj bi bilo narobe?
Dropbox ponuja do 4,5 GB prostora brezplačno (strani: 1 2 3 )
11332157 (24036) Ajrina
Po letu dni Conficker živahnejši kot kdajkoli (strani: 1 2 )
Oddelek: Novice / Varnost
629821 (7812) ABX
ne morem odpreti diska
134173 (3555) rockrose
XP-ji in hudičev CD Autorun
Oddelek: Programska oprema
72170 (1893) Paramedic
autorun.inf --> KAKO ?
61924 (1841) tejo
