Forum » Programska oprema » XP-ji in hudičev CD Autorun
Mercier ::
1. Go to Start->Run->gpedit.msc
2. Computer Config -> Administrative Template -> System
3. Double clik Turn off Autoplay
4. Enable it/disejbl it (sm kr skopiru, nism velik gledu)
- spremenil: Mercier ()
Paramedic ::
Kako pa samo za eno CD-ROM enoto na rač.
Js npr. imam 2 CDja in ImageDrive, pa bi rad sam slednjemu disablal autorun.
End transmission.
ToniT ::
Z desno miško klikneš na CD in izbereš Properties, zavihek AutoPlay in tam določiš akcije.
Druga možnost je poseg v register:
There is no option to enable or disable automatically running CD-ROMs in the user interface. To enable or disable automatically running CD-ROMs, you must edit the registry:
Click Start , click Run , type regedit in the Open box, and then press ENTER.
Locate and click the following registry key:
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\CDRom
To disable automatically running CD-ROMs, change the Autorun value to 0 (zero). To enable automatically running CD-ROMs, change the Autorun value to 1.
Restart your computer.
| » | Windows 10 z reklamami tudi v Raziskovalcu (strani: 1 2 3 )Oddelek: Novice / Operacijski sistemi | 57826 (51390) | D3m |
| » | Linux / netOddelek: Pomoč in nasveti | 2045 (1718) | roscha |
| » | Autorun ne delaOddelek: Pomoč in nasveti | 1740 (1698) | Pro2Type |
| » | Zapis stvari, ki so se pocele na racunalniku?Oddelek: Programska oprema | 1445 (1152) | darkolord |
| » | kako v win XP izklopi CD autoplay?Oddelek: Pomoč in nasveti | 1444 (1322) | freejack |
