Živeti na Novi Zelandiji
1 2
3
4 5
BoomBoom ::
http://mayjertales.com/?lang=si
En zanimiv blog glede življenja na NZ, kako dobiti vizo, ipd. Za vse tiste, ki bodo/bomo neko to potrebovali. (http://mayjertales.com/new-zealand/gett... , http://mayjertales.com/new-zealand/rega... , http://mayjertales.com/new-zealand/how-... , http://mayjertales.com/new-zealand/exte... )
Skratka zanimivo.
  • spremenil: BoomBoom ()
Ramon dekers ::
Ne ustvarjajte si iluzij kako super hitro je dobiti službo, mogoče, če želiš delati pri obiranju kivijev nekje na podeželju z WHV vizo samo permanentnega rezidenstva ne pričakujte, za kakšno resno pozicijo bo potrebno veliko, veliko truda.
Skratka takole gre obrazec za resno službo, ki je v bistvu druga faza od tretje (razgovor), torej če jim je tvoj CV všeč ti pošljejo application form:
SELF ASSESSMENT FORM
? Please complete this form fully.
? Use examples from your job, where possible, to illustrate the criteria or skills outlined.
Situation/Task:
Describe the situation that you were in or the task that you needed to accomplish. You must describe a specific event or situation, not a generalised description of what you have done in the past. Be sure to give enough detail for the interviewer to understand. Think of it as telling a story that has a beginning, middle, and ending.
Actions Taken:
Describe the action you took and keep the focus on what you did, even if it was a team experience.
Results:
What happened? What did you accomplish? What did you learn? Even if you feel you did not handle the situation as well as you could have, telling what you learned and showing how you applied that learning in another situation will work also.
Capability:
SELF
Develops personal attributes and skills to enhance performance.
Key Aspects:
o Self Awareness: Understands own strengths, weaknesses and motivations.
o Lifelong Learning: Seeks to extend knowledge, skills and experience.
o Resilience: Adapts and has the capacity to overcome adversity.
o Personal Courage: Makes decisions, takes risks and accepts accountability.
Situation/Task:
Actions Taken:
Results:
Capability:
INFLUENCE
Establishes Organisational and group goals, directions and processes
Key Aspects:
o Purpose and Direction: Articulates, communicates and drives achievement of defined goals.
o Engagement: Works collaboratively and establishes positive relationships.
o Culture and Change: Understands and capitalises on the dynamics of organisational change to create positive outcomes.
Situation/Task:
Actions Taken:
Results:
Capability:
ETHICS
Models ethical behaviour and practices
Key Aspects:
o Relating to Governance and Compliance: Develops implements and adheres to policy and procedures; understands the relative roles and functions within organisations.
o Ethical Behaviour: Behaviour and actions are open and transparent and is accountable for actions and outcomes.
Situation/Task:
Actions Taken:
Results:
Capability:
RELATIONSHIPS
Builds sustainable internal and external relationships
Key Aspects:
o Community: Represents the organisation positively with relevant communities.
o Networks: Establishes and maintains contacts which benefit individual work and organisational performance.
o Political Acumen: Is sensitive to context and anticipates how people may respond to issues.
o Advocacy: Promotes organisational vision and goals.
Situation/Task:
Actions Taken:
Results:
Capability:
STRATEGY
Constructs a plan including options and priorities for achieving defined goals
Key Aspects:
o Strategic Thinking: Perceives and conceptualises opportunities, possibilities and alternative courses of action.
o Information and Opportunity: Creates and maximises opportunity through communication and information.
o Problem Solving and Judgement: Uses sound judgement and is innovative and creative in approach and thinking.
o Systems Thinking: Maintains a whole of organisation view.
Situation/Task:
Actions Taken:
Results:
Capability:
PEOPLE
Builds individual and team capability and performance
Key Aspects:
o Empowerment: Enables others to develop and improve performance.
o Diversity: Recognises and values individual differences and manages conflict resolution.
o Development: Designs opportunities for the development of individual and team performance.
o Performance: Achieves, maintains and improves individual and team performance.
Situation/Task:
Actions Taken:
Results:
Capability:
RESULTS
Achieves defined outcomes
Key Aspects:
o Client Focus: Responds to client needs.
o Outcome Focus: Achieves results by maintaining a focus on outcomes.
o Capability and Responsiveness: Ensures that capability is maintained for both current and future needs.
o Expertise: Identifies, acquires and uses knowledge and experience to achieve results.
Situation/Task:
Actions Taken:
Results:
BoomBoom ::
Povej nam več o tvoji izkušnji.
Go-ahead ::
Bravo Ramon. Končno eden, ki je odje*al Jugoslovenijo in pred tem o njej tudi na Slo techu podal svoje mnenje.
Če ti od tu lahko kakorkoli pomagamo kar na dan s problemi.
In lepo da poročaš kako ti gre. Mogoče boš še komu odprl vrata.
Srečno naprej!
Ramon dekers ::
Hvala za podporo.
Drugače pa ni tako enostavna integracija, še posebno če nisi zelo organiziran. Lahko na novicah berete kako enostavna je selitev in potem izpostavijo dva prišleka eden učitelj smučanja, punca pa verjetno brez službe.
Prvi problem, ki nastane v NZ. je dobiti stanovanje. Logično ti ga ne bo nihče dal. Tujec, brez zaposlitve etc. Tu je pač potreben kanček iznajdljivosti, pa veliko vstrajnosti.
Druga težava je naglas tako tvoj kot njihov. Šele po parih mesecih se nekako uravnaš, da jih razumeš in oni tebe.
Vodo imajo zastonj, nekih par dolarjev na koncu leta za vzdrževanje vodovodov.
Hja kar se pa tiče služb je fino, da nisi skoncentriran na en segment in ti pride vedno prav recimo naravoslovna + družboslovna smer. Srednja šola recimo tehniški foh, faks pa družboslovje ali pač obratno. Samo za primer geologe sicer iščejo ampak če te zavrnejo v lokaciji kjer se zasidraš in ti je ok, in ti recimo dajo ponudbo na lokaciji, ki ti ni všeč zna biti težavno. Še večji problem pa je če si prevč ozko usmerjen v en segment in službe na tem področju ne dobiš.
Pravna država pa deluje, če jim citiraš zakon, malce zagroziš najemodajalcu, da je potrebno popravilo hiše, stanovanja, bodo to zrihtali, sicer v roku u 14 dni ampak bo pa:)
GGGGG ::
Podobno kot pri nas, torej?
Ramon dekers ::
Daleč od tega. V bistvu bi prej dobil tu službo kot družboslovec kot naravoslovec. Edino zdravniki imajo podoben problem kot pri nas, da odidejo v tujino.
Evo, takih ne bom nikoli razumel. Gre človek na drug konec sveta službo iskat, potem pa se tam zasidra v enem kraju in mu je težko iti na drug konec otoka. Očitno v takih še vedno živi socialistična misel na eno službo od pripravništva do penzije.>:D Če ti ponudijo službo na koncu, ki ti ni najbolj všeč, stisneš zobe in greš tja, ker z izkušnjami, ki jih boš tam dobil, boš čez leto ali dve veliko lažje našel službo v kraju, ki ti je bolj všeč (ali bolje plačano službo v kraju, ki ti ni všeč).
O.
Ramon dekers ::
Ma dej Okapi ob kaj se ne boš ti vse še spotaknil. Če ti ponudijo službo na drugem otoku bi morala biti zelo dobro plačan in vključenim stanovanjem po možnosti, kar pa dvomim, da se bo zato zares nekdo potrudil.
Sicer pa odvisno na katerem segmentu delaš, če si geolog jasno pričakuješ relokacije.
GGGGG ::
A ni pri nas isto?
Sicer sem ciljal na mobilnost. Če si se v Sloveniji pripravljen peljati 1 uro precej lažje dobiš službo. Če si se pripravljen preseliti pa sploh ni problema.
V obljubljeni deželi je očitno podobno. Če hočeš službo moraš biti mobilen.
Ramon dekers ::
kaj torej predlagaš, da se vsi, ki so brez služb bodisi preselijo ali vozijo v Lj? Avstrijsko ne znam, tako da ta opcija ni realna. Res nevem kam ciljaš? Ker situacija je daleč od podobne.
Se ti ne zdi, da če bi bila zadeva takšna kot jo ti opisujše meni ne bi bilo treba gazit 18.000km stra od doma? Nevem, mogoče pa ti živiš v drugi deželi, meni je (kar se ekonomskega stanja tiče) ok. Doma pa, hja žalost. Razen Lj. je Slovenija bolj boga pa še tam gre navzdol.
GGGGG ::
Ciljam na dvojna merila, ki so očitno prisotna. Po eni strani se ni problem preseliti v tujo državo 18000km stran od doma, je pa očitno problem najti stanovanje na drugem koncu Slovenije.
Če imaš tako izobrazbo in si se pri nas pripravljen preseliti (ali voziti) tudi v Sloveniji dobiš službo včeraj. Po teh in podobnih izjavah sem sklepal, da stanje pri nas ni bistveno drugačno kot v NZ.
Ramon dekers ::
Kakšno vezo ima stanovanje če pa večina populacije dela za minimalno plačo in je vesela, če dobi službo. Thnx but no thnx.
Kakšen kader pa v Sloveniji iščejo? Stanje je bistveno drugačno, ker kot rečeno tu lahko privarčuješ določen znesek pa čeprav delaš za minimalca.
Smurf ::
Ramon dekers je izjavil:
Kdo te je pa to nalagal? Na minimalni placi je okoli 50k ljudi, kar definitivno ni vecina, ampak precej manj kot 10%.
  • spremenil: Smurf ()
GGGGG ::
Če je manj kot 2,4% zate "večina populacije" potem imaš prav ja.
https://slo-tech.com/forum/t403815/p411...
Vem, da je pri nas na precej področjih pomanjkanje kadra. Predvsem sposobnega. Kot rečeno, človek, ki ni zaplankan in uspešno kombinira naravoslovje in družboslovje je lahko tudi pri nas izbirčen. Po drugi strani praviš, da tudi v NZ ni lahko dobiti službe, če si brez izobrazbe in posebnega znanja.
Je pa res, da na minimalcu pri nas težko daš kaj na stran.
Malajlo ::
Če si količkaj sposoben in prilagodljiv, je (lahko!) življenje v SLO prekrasno. Mene bi tujino spravile samo žabe, kuga, kobilice, toča... Pa še tema, ki se je sicer leta 2008 napovedovala, pa je na srečo ni bilo ;) (takrat sem bil še najbližje tujini).
Vsem, ki odidejo na drug konec sveta želim srečo, ampak do sedaj se še noben ni pohvalil, da dela manj in več dobi. Prej obratno. Očitno je nakaj s podnebjem, klimo, da v teh koncih to ni sprejemljivo.
  • spremenil: Malajlo ()
Ramon dekers ::
Očitno se vam je ekonomija popravila odkar je Bratuškova na oblasti. Eh well, meni ni hudega vam pa tudi očitno ne.
Ramon dekers ::
Ps. V NZ. je za 4 miljone prebivalcev 16.600 delovnih mest v Sloveniji za 2 miljona 600. Poleg tega je toliko fiktivnih da glava peče, aroganca delodajalcev, kjer niti ne podaja feedback-a.
Da ne omenjamo slovenskih davkov, ki jih lahko primerjamo s kobilicami ki žrejo pridelek. Pravo in sodstvo pa tako v riti...
Torej če me še kdo vpraša zakaj NZ. in ne Slo.Smeh
nekikr ::
No, ampak koliko bi dejansko lahko prihranil tam na mesec, če ne bi tam delal na sistem bosanskih delavcev v Sloveniji (se pravi, da ne gledaš na vse stroške in ne daješ čisto vsega na stran ali "pošiljaš domov")? Ne razumi narobe, super, da si probal, ampak iz tvojega pisanja nisem zasledil, da bi bilo kaj bolje kot pri nas. Razen subjektivnih ocen, ki pa so napačne iz razlogov napisanih v postih nad mano.
zee ::
@Ramon Dekers:
Cestitke za pogum in vse dobro na drugem, no, tem koncu sveta! Sporoci, ce bos kaj hodil po JV Aziji. :D
@ostali:
Iz sporocil nekaterih zaznavam fowsijo. Zakaj le? Lahko bi ostal v Sloveniji in *zdil na stanjem v drzavi/EU, vendar je zbral pogum in sel s trebuhom za kruhom.
Ja, takle mate.
zee
Vice ::
To da je pri nas par % prebivalstva na minimalcu ni noben podatek. Večina ki je nad minimalcem si ne more privočiti niti pol toliko kot nekdo, ki je na minimalcu v NZ.
nekikr ::
Nisem tako prepričan.
Sosofina Masoe came to New Zealand from Samoa 11 years ago with her husband, four children and hopes of a better life.
Despite more than a decade of working hard here, she is still struggling to make ends meet.
She will be speaking at the Wellington launch of the Living Wage Campaign today to urge employers to pay rates higher than minimum wage.
in
The Service & Food Workers Union says the latest increase to the minimum wage is still not enough for people to live on.
The Government on Wednesday announced the minimum wage would go up by 50 cents per hour to $13.50 on 1 April.
But the union says that is not a living wage and wants something radical done to boost wages.
Tega je precej na internetih. Ni ravno pametno trditi nekaj, kar ni res.
  • spremenil: nekikr ()
Ramon dekers ::
Definitivno se slišiva, no vidiva. Takoj ko uredim celotno papirologijo in dobim dopust:)
Ja sedaj če preračunava sobo v najeti hiši dobiš $123 na mesec. Delaš 8 ur na dan x $12 = $96/dan. 96x5 = $480 na teden. Torej? Dodaš še hrano in avtobus pa prideš nekje na $250 na teden v grobem.
So dobre službe ampak moraš do tja priti. Prvo moraŠ nekaj pokazati v življenjepisu, drugo moraš razumeti angleščino tako da oni razumejo tebe in ne ti njih, osvojiti njihovo mentalito. Da prideš na točko ko to obvladaš lahko traja tudi 3 mesece pri nekaterih nikoli. Ampak roko na srce kdo bi pa zaposlil azijca s polomljeno angleščino pri delu s strankami? Tudi če delaš na IT področju in si v tem segmentu prekleto dober pa ti angleščina ne gre boš na razgovoru odletel.
Kako pa je v Sloveniji? Dajo razpis službo pa dobi sinček od določen osebe v višjih krogih. Za gospodarski krimanal bo v Sloveniji prišel samo nekdo iz notranjih krogov preko vez, tu dajejo externi razpis za skoraj vse zadeve. Če si dober prideš na razgovor.
Slovenija je lepa, ampak sistem v njej pa gnil.
Vice ::
Jest upam trditi kar velja v večini in iz izkušenj. Veliko je tudi v tem koliko je posameznik odločen za uresničitev svojih ciljev. Se pa vedno najdejo izjeme tudi v "nebesih". Lahko se obešaš na izjeme in se tolažiš, ker nimaš jajc za spremembe ali pa greš v tujino in poizkusiš. Če prebereš par postov višje bi si človek mislil, da so pri nas nebesa, pa vsak dan bereš na internetu in TVju kako "propadajo" ljudje.
GGGGG ::
Jaz hvalabogu nimam razloga za fowsijo. Samo realno stanje me zanima, ker vem da Ramon Dekers pogosto pretirava. V enem postu benti čez določene stvari v Sloveniji, potem pa napiše, da je v NZ pravzaprav isto.
Možno, boste povedali tisti, ki ste dol.
Sicer pa. Minimalc dol je $13,75 kar znese cca. 8€ na uro oz. slabih 1300€ na mesec. Za začetnike in pripravnike je očitno minimalna plača še nižja, $11 oz. 6,5€ na uro, kar znese 1040€.
Minimalna plača pri nas znaša 760€ bruto + 780€ regresa. Ne vem kako je z dodatki, ampak domnevam, da v NZ ni plačane malice in kilometrine, ki pri nas nanesejo še kakšnih 100€ na mesec v povprečju.
http://www.dol.govt.nz/er/pay/minimumwa...
nekikr ::
Prišteješ še precej višje stroške življenja (če ne živiš kot bosanski delavec) in vidiš, da se vseeno ne cedita ravno med in mleko...
Še bolje, primerjava z nami, kar precej točna.
Ramon dekers ::
Ironija je, da meni razlagate kako se živi na Novi Zelandiji. Če si butast je itak tako ali tako vseeno kje si.
p.s. minimalna plača je takšna kot je razen če ne delaš v gostinstvu kjer si plačan na sobo (čiščenje).
Kaj pa je pravzaprav isto? Res je ni nič posebnega kar se okolice tiče pa same narave, hiše tudi ne. Ampak sistem deluje. Pravo se dosledno upošteva.
nekkir pa si ti prebral to kar si napopal? Ker:
Consumer Prices in Wellington are 31.66% higher than in Ljubljana
Consumer Prices Including Rent in Wellington are 41.82% higher than in Ljubljana
Rent Prices in Wellington are 73.39% higher than in Ljubljana
Restaurant Prices in Wellington are 28.52% higher than in Ljubljana
Groceries Prices in Wellington are 54.38% higher than in Ljubljana
Local Purchasing Power in Wellington is 55.59% higher than in Ljubljana
Vice ::
Med in mleko se nikjer ne cedita. Res moraš bit trot da tako misliš. Če že govorimo o minimalcih je pri nas povprečje toliko kot tam minimalec.
In če greš v tujino a greš tja zato, da boš na minimalcu? Je kdo od vas zadovoljen z minimalcem? Jest osebno ne odprem več firme v SLO. Tukaj rabim minimalno 15 let za isti izplen kot ga sproduciram v tujini v 5 letih. Pa mi marsikdo reče kaj delam tukaj... Home Sweet Home, pa da se čudim tistim ki vstrajajo :)
GGGGG ::
Tole, recimo in druge podobne izjave:
Ja, kupna moč je višja ravno toliko, kot so višje cene. Oz. tam tam.
Ja kako, če je minimalc za začetnika pri nas cca. 100 eur nižji kot tam.
V kakšnem smislu? Mislim, pri podjetništvu je zadeva res še bolj enostavna, ker precej enostavno posluješ s tujino.
nekikr ::
Sem. Če gledaš minimalca potem je stanje drugačno. In o minimalcu smo zgoraj govorili. Povprečna plača je nekaj drugega.
Veliko ljudi gre v tujino točno za to. Še Ramon, se mi zdi, ni prišel kaj dlje od tega trenutno, pa je bolj kvalificiran kot Bosanci pri nas.
furion ::
nekikr je izjavil:
Jah clovek je komaj zacel life tam. Se bo verjetno lahko samo 'smejal' vsem slovenceljem cez par let, ko si uredi decent life and watch slo burn. Kdor v tej drzavi vidi prihodnost je bedak (ali pretkan lopov).
  • spremenil: furion ()
GGGGG ::
Tako je pri nas. Če si na minimalcu si bedak, če si ustvariš dostojno življenje z normalnimi dohodki pa lopov :)
Smurf ::
Jaz cisto verjamem Ramon Dekersu, da ima tam boljso kvaliteto zivljenja in zato je bila tudi njegova odlocitev o selitvi v NZ verjetno pravilna. Po drugi strani pa se v NZ ne cedite med in mleko, in sploh ni nujno, da ti bo tam bolje. Skratka treba se je zavedati vseh plusov in minusov v obeh primerih, za ene je bolje ena stvar za druge pa druga.
Bom jaz raje malce drugacno vprasanje. @Ramon Dekers Za kaksno placo pa bi se preselil nazaj v Slovenijo?
tumare ::
Allegory of the Cave @ Wikipedia
V NZ ni nič dobrega, je doma vse v redu.
Srečno Ramon
Tr0n ::
Zanimivo branje.
To bi bil zame deal breaker. Sploh verjetno ne bi razmisljal o selitvi, ce si ne bi poprej zrihtal tako sluzbe, kot tudi stanovanja samo zame, brez sostanovalcev. To dvoje je predpogoj za beg iz Slovenije. :)
bluefish ::
Če je to le prehodna situacija, potem že nekako potrpiš. Da bi pa par let živel v eni sobici, pa vsekakor ni nek napredek v življenjskem slogu.
Ramon dekers ::
Definitvno. Izobrazba ljudi je na bistvenem nižjem nivoju kot doma. Sicer pa odgovor na tvoje vprašanje 3000EUR neto. Sicer pa ja ok. denar igra vlogo, ampak izkušnje ti pa dajo to, da dobiš vstopnico v ZDA, Kanado, Veliko Britanijo in celo drugam. Štempl (priznanega) delodajalca vreden toliko kot doktorat.
Jah če nimaš takšnega znanja (in ogromno sreče) kot jo je imel zee in bi/boš pošiljal prošnje iz Slovenije boš obravnavan kot Bosanec. Še stanovanja ne boš dobil od doma, kaj šele dela. Sicer pa ni problema, nas je 5 v bajti, nikoli nikakršnega hrupa, problemov, kuhinja čista, tako da tudi, če bi imel nevem kakšno plačo ne vidim poante v selitvi izjemomam, če imaš družino. Toda, če imaš družino, gre najprej eden tja, da se prebije led, nato pa ostali ko se uredi papirje in delo.
Dobro si zadel tole:)
GGGGG ::
Mislim, da nihče ne trdi tega.
Je pa dobro postaviti zadeve v kontekt. Mogoče je tole poklicna deformacija, ampak jaz na večino stvari gledam skozi ROI (return on investment). Recimo, da za selitev, iskanje stanovanja in spodobne službe v NZ porabiš 3 leta (z nabiranjem izkušenj po minimum wage službah). Kaj lahko z istim vložkom časa in denarja narediš v Sloveniji?
Mavrik ::
bluefish je izjavil:
Kakor hitro začneš potovati po "razvitih" mestih po svetu hitro pogruntaš da stanovanja niso praktično nikjer v civilizaciji napredek. To je področje, kjer Slovenija zaradi zgodovinskih razlogov in majhnosti močno pozitivno izstopa glede na precej drugih držav.
Selitev v kako večje tuje mesto tako praktično gotovo pomeni ali dolgi (in dragi commute) ali življenje v zelo dragi luknji.
Ramon dekers ::
Mislim kakšna butasta logika. Saj se ne prijavljaš na pozicije z minimalno plačo pač pa ciljaš na najboljše. Če imaš kvalifikacije in nekaj izkušnje nevem zakaj ne. Če pa greš sem da delaš v gostinstvu, skladišču pol pa veliko sreče, ker neizšolanega kadra je veliko in je tu konkurenca še večja.
Se da. Brez skrbi.
thramos ::
Hm no, evropska velemesta imajo po mojih izkušnjah s potovanj v primerjavi z našimi mesteci zelo hiter in poceni javni promet.
Smurf ::
Jaz sm v Londonu s tubom porabil manj casa za daily commute kot v Ljubljani z LPPjem. Zalostno a resnicno :P.
edit: cena je pa bila, ce me spomin ne vara, precej primerljiva.
Roadkill ::
Mene samo zmoti, da se govori o nekem (višjem) standardu življenja, hkrati pa se računa najemnina za SOBO v hiši.
Ta zadeva je očitno popularna v NZ, ker sem že od večih ki so šli slišal podobno.
Vse je super, flat si delim še s tremi tujci, sem trenutno brez službe, ampak standard življenja je pa veliko višji kot v Sloveniji. :)
Ü
Tr0n ::
Smurf je izjavil:
Heh ja, v Londonu je skoraj vse drago, edino tube ja pa prav prijetno poceni. Sem bil pred kratkim tam na dopustu in sem v 10 dneh prepotoval cel London za 30 funtov.
marvin42 ::
Roadkill: to, da mora vsak sezidati zase in za naslednje tri generacije en grad, je slovenska posebnost. Najem sobe v hiši se pri nas sliši bogokletno, v tujini ni pa to nič posebnega. Dokler nimaš družine, je to po moje logiki tudi najbolj pravilna odločitev.
Mostly Harmless
Seveda je prav, da greš v najeto sobo, ampak tudi v Sloveniji lahko to narediš, za 100 evrov na mesec dobiš cel štuk in ga rentaš še dalje.
Ampak dokler ne preračunaš koliko stane pošteno stanovanje ali hiša, za nakup ali najem ko imaš družino, koliko stane kakšna operacija oz. zavarovanje, avto in vsi stroški z njim, otroci in vsi njihovi stroški, pa tudi to da ne moreš s kolegi na pivo, ker so na drugem koncu sveta, se ne moremo pogovarjat o strašnem standardu.
GGGGG ::
Po tvojih besedah traja kar nekaj časa, da dobiš tisto "najboljše". Recimo, da je to vsaj 3 leta in vsaj enih 20, 30k eur investicije?
Za tak denar in s 3 leti intenzivnega dela se da tudi pri nas pridelati spodobne dohodke.
Ramon dekers ::
Šolstvo je plačljivo, zdravstvo imajo pokrito. Šolnina enegal letnika stane $5.000 (študij psihologije). Varuška v 1 letu zasluži za celotno šolnino, torej 3 leta. Toliko o tem kaj se da in kaj ne. Avtomobili so tudi dražje tu, pa zaradi tega ravno ne mislim v Slovenijo ker so tam cenejši.
Od kje 3 leta? 3 mesece traja da osvojiš jezik in navade. Po tem obdobju si pripravljen za razgovore kot se spodobi. Lahko je to 4, 5, 6 mesecev ne pa 3 leta.
Me veseli, da še kdo vstraja. Mimogrede baje da prihajajo novi davki?
GGGGG ::
Koliko časa si raziskoval področje, koliko časa si se intenzivno pripravljal na selitev, urejal papirje, koliko denarja je šlo za to (poračunaj vse skrite stroške), koliko časa boš delal na slabše plačanih službah, da prideš do recimo 50k EUR letnega dohodka?
Don't know, don't care. Nimam časa in volje, da bi se ukvarjal s 3% razlike.
  • spremenilo: GGGGG ()
Glede na članek na wikipediji, Health care in New Zealand @ Wikipedia , je zdravstveni sistem približno podoben našemu. Plačaj ali čakaj.
1 2
3
4 5
Apple na Novi Zelandiji desetletje ni plačal nič davka na dobiček (strani: 1 2 )
9326816 (24072) AndrejO
Magisterij: DA / NE (strani: 1 2 )
Oddelek: Šola
6519652 (15724) Invictus
Koliko stane računalniški inženir v ZDA (strani: 1 2 3 4 5 )
21780012 (66575) AndrejO
Delo v Avstraliji (tujini) (strani: 1 2 )
7520914 (12649) Pegaz
