Forum » Programiranje » MySQL problem
MySQL problem
mitja ::
Zdravo!
Tole podatkovno bazo želim naložiti na server:
MySQL je vrnil: Dokumentacija
#1064 - You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'NULL DEFAULT NULL ,
`username` VARCHAR(90) CHARACTER SET 'utf8' COLLATE 'utf8' at line 6
Vendar bolj kot poskušam, gledam, berem, manj mi je jasno.
Kaka ideja?
Za izgradnjo baz uporabljam: MySQL Workbench
Hvala za pomoč!
// Prosim uporabljajte st.koda značke. -- moderator
SET @OLD_UNIQUE_CHECKS=@@UNIQUE_CHECKS, UNIQUE_CHECKS=0;
SET @OLD_FOREIGN_KEY_CHECKS=@@FOREIGN_KEY_CHECKS, FOREIGN_KEY_CHECKS=0;
SET @OLD_SQL_MODE=@@SQL_MODE, SQL_MODE='TRADITIONAL,ALLOW_INVALID_DATES';
CREATE SCHEMA IF NOT EXISTS `mitzen01_veem` DEFAULT CHARACTER SET utf8 COLLATE utf8_slovenian_ci ;
USE `mitzen01_veem` ;
-- Table `mitzen01_veem`.`sc_log`
CREATE TABLE IF NOT EXISTS `mitzen01_veem`.`sc_log` (
`id` INT(8) NOT NULL AUTO_INCREMENT ,
`inserted_date` NULL DEFAULT NULL ,
`username` VARCHAR(90) CHARACTER SET 'utf8' COLLATE 'utf8_slovenian_ci' NOT NULL ,
`application` VARCHAR(200) CHARACTER SET 'utf8' COLLATE 'utf8_slovenian_ci' NOT NULL ,
`creator` VARCHAR(30) CHARACTER SET 'utf8' COLLATE 'utf8_slovenian_ci' NOT NULL ,
`ip_user` VARCHAR(32) CHARACTER SET 'utf8' COLLATE 'utf8_slovenian_ci' NOT NULL ,
`action` VARCHAR(30) CHARACTER SET 'utf8' COLLATE 'utf8_slovenian_ci' NOT NULL ,
`description` TEXT CHARACTER SET 'utf8' COLLATE 'utf8_slovenian_ci' NULL DEFAULT NULL ,
PRIMARY KEY (`id`) )
ENGINE = MyISAM
AUTO_INCREMENT = 346
DEFAULT CHARACTER SET = utf8
COLLATE = utf8_slovenian_ci;
-- Table `mitzen01_veem`.`sec_apps`
CREATE TABLE IF NOT EXISTS `mitzen01_veem`.`sec_apps` (
`app_name` VARCHAR(128) CHARACTER SET 'utf8' COLLATE 'utf8_slovenian_ci' NOT NULL ,
`app_type` VARCHAR(255) CHARACTER SET 'utf8' COLLATE 'utf8_slovenian_ci' NULL DEFAULT NULL ,
`description` VARCHAR(255) CHARACTER SET 'utf8' COLLATE 'utf8_slovenian_ci' NULL DEFAULT NULL ,
PRIMARY KEY (`app_name`) )
ENGINE = MyISAM
-- Table `mitzen01_veem`.`sec_groups`
CREATE TABLE IF NOT EXISTS `mitzen01_veem`.`sec_groups` (
`group_id` INT(11) NOT NULL AUTO_INCREMENT ,
`description` VARCHAR(64) CHARACTER SET 'utf8' COLLATE 'utf8_slovenian_ci' NULL DEFAULT NULL ,
PRIMARY KEY (`group_id`) ,
UNIQUE INDEX `description` (`description` ASC) )
ENGINE = MyISAM
AUTO_INCREMENT = 3
-- Table `mitzen01_veem`.`sec_groups_apps`
CREATE TABLE IF NOT EXISTS `mitzen01_veem`.`sec_groups_apps` (
`group_id` INT(11) NOT NULL ,
`priv_access` VARCHAR(1) CHARACTER SET 'utf8' COLLATE 'utf8_slovenian_ci' NULL DEFAULT NULL ,
`priv_insert` VARCHAR(1) CHARACTER SET 'utf8' COLLATE 'utf8_slovenian_ci' NULL DEFAULT NULL ,
`priv_delete` VARCHAR(1) CHARACTER SET 'utf8' COLLATE 'utf8_slovenian_ci' NULL DEFAULT NULL ,
`priv_update` VARCHAR(1) CHARACTER SET 'utf8' COLLATE 'utf8_slovenian_ci' NULL DEFAULT NULL ,
`priv_export` VARCHAR(1) CHARACTER SET 'utf8' COLLATE 'utf8_slovenian_ci' NULL DEFAULT NULL ,
`priv_print` VARCHAR(1) CHARACTER SET 'utf8' COLLATE 'utf8_slovenian_ci' NULL DEFAULT NULL ,
PRIMARY KEY (`group_id`, `app_name`) ,
INDEX `sec_groups_apps_ibfk_2` (`app_name` ASC) )
ENGINE = MyISAM
-- Table `mitzen01_veem`.`sec_logged`
CREATE TABLE IF NOT EXISTS `mitzen01_veem`.`sec_logged` (
`login` VARCHAR(32) CHARACTER SET 'utf8' COLLATE 'utf8_slovenian_ci' NOT NULL ,
`date_login` VARCHAR(128) CHARACTER SET 'utf8' COLLATE 'utf8_slovenian_ci' NULL DEFAULT NULL ,
`sc_session` VARCHAR(32) CHARACTER SET 'utf8' COLLATE 'utf8_slovenian_ci' NULL DEFAULT NULL ,
PRIMARY KEY (`login`) )
ENGINE = MyISAM
-- Table `mitzen01_veem`.`sec_users`
CREATE TABLE IF NOT EXISTS `mitzen01_veem`.`sec_users` (
`pswd` VARCHAR(32) CHARACTER SET 'utf8' COLLATE 'utf8_slovenian_ci' NOT NULL ,
`name` VARCHAR(64) CHARACTER SET 'utf8' COLLATE 'utf8_slovenian_ci' NULL DEFAULT NULL ,
`email` VARCHAR(64) CHARACTER SET 'utf8' COLLATE 'utf8_slovenian_ci' NULL DEFAULT NULL ,
`active` VARCHAR(1) CHARACTER SET 'utf8' COLLATE 'utf8_slovenian_ci' NULL DEFAULT NULL ,
`activation_code` VARCHAR(32) CHARACTER SET 'utf8' COLLATE 'utf8_slovenian_ci' NULL DEFAULT NULL ,
`priv_admin` VARCHAR(1) CHARACTER SET 'utf8' COLLATE 'utf8_slovenian_ci' NULL DEFAULT NULL ,
ENGINE = MyISAM
-- Table `mitzen01_veem`.`sec_users_groups`
CREATE TABLE IF NOT EXISTS `mitzen01_veem`.`sec_users_groups` (
PRIMARY KEY (`login`, `group_id`) ,
INDEX `sec_users_groups_ibfk_2` (`group_id` ASC) )
ENGINE = MyISAM
-- Table `mitzen01_veem`.`skupno_PostneStevilke`
CREATE TABLE IF NOT EXISTS `mitzen01_veem`.`skupno_PostneStevilke` (
`idPosta` INT(11) NOT NULL AUTO_INCREMENT ,
`Posta` VARCHAR(60) CHARACTER SET 'utf8' COLLATE 'utf8_slovenian_ci' NOT NULL ,
`PostnaStevilka` VARCHAR(20) CHARACTER SET 'utf8' COLLATE 'utf8_slovenian_ci' NOT NULL ,
`VelikiUporabnik` VARCHAR(45) CHARACTER SET 'utf8' COLLATE 'utf8_slovenian_ci' NULL DEFAULT NULL ,
`Drzava` VARCHAR(45) CHARACTER SET 'utf8' COLLATE 'utf8_slovenian_ci' NOT NULL ,
PRIMARY KEY (`idPosta`) )
ENGINE = MyISAM
AUTO_INCREMENT = 2
COMMENT = 'Seznam pošt';
-- Table `mitzen01_veem`.`skupno_Partnerji`
CREATE TABLE IF NOT EXISTS `mitzen01_veem`.`skupno_Partnerji` (
`idPartner` INT(11) NOT NULL AUTO_INCREMENT ,
`Naziv` TEXT CHARACTER SET 'utf8' COLLATE 'utf8_slovenian_ci' NOT NULL ,
`Zanesljivost` VARCHAR(45) CHARACTER SET 'utf8' COLLATE 'utf8_slovenian_ci' NULL DEFAULT NULL ,
`Ulica` TEXT CHARACTER SET 'utf8' COLLATE 'utf8_slovenian_ci' NULL DEFAULT NULL ,
`idPosta` INT(11) NOT NULL DEFAULT NULL ,
`Telefon` VARCHAR(45) CHARACTER SET 'utf8' COLLATE 'utf8_slovenian_ci' NULL DEFAULT NULL ,
`Fax` VARCHAR(45) CHARACTER SET 'utf8' COLLATE 'utf8_slovenian_ci' NULL DEFAULT NULL ,
`GSM` VARCHAR(45) CHARACTER SET 'utf8' COLLATE 'utf8_slovenian_ci' NULL DEFAULT NULL ,
`Email` VARCHAR(45) CHARACTER SET 'utf8' COLLATE 'utf8_slovenian_ci' NULL DEFAULT NULL ,
`KontaktnaOseba` TEXT CHARACTER SET 'utf8' COLLATE 'utf8_slovenian_ci' NULL DEFAULT NULL ,
`DavcnaStevilka` VARCHAR(8) CHARACTER SET 'utf8' COLLATE 'utf8_slovenian_ci' NULL DEFAULT NULL ,
`ZavezanecDDV` CHAR(1) CHARACTER SET 'utf8' COLLATE 'utf8_slovenian_ci' NULL DEFAULT NULL ,
`MaticnaStevilka` INT(10) NULL DEFAULT NULL ,
`SpletnaStran` VARCHAR(45) CHARACTER SET 'utf8' COLLATE 'utf8_slovenian_ci' NULL DEFAULT NULL ,
`Opombe` LONGTEXT CHARACTER SET 'utf8' COLLATE 'utf8_slovenian_ci' NOT NULL ,
`group_id` INT(11) NULL DEFAULT NULL ,
PRIMARY KEY (`idPartner`, `idPosta`) ,
INDEX `fk_skupno_Partnerji_skupno_PostneStevilke_idx` (`idPosta` ASC) )
ENGINE = MyISAM
COMMENT = 'Seznam partnerjev';
-- Table `mitzen01_veem`.`test`
CREATE TABLE IF NOT EXISTS `mitzen01_veem`.`test` (
`id` INT(11) NOT NULL AUTO_INCREMENT ,
`kontrolniPodatek` TEXT CHARACTER SET 'utf8' COLLATE 'utf8_slovenian_ci' NOT NULL ,
ENGINE = MyISAM
AUTO_INCREMENT = 10
-- Table `mitzen01_veem`.`ZZasV_Spisi`
CREATE TABLE IF NOT EXISTS `mitzen01_veem`.`ZZasV_Spisi` (
`idZZasV_Spisi` INT NOT NULL AUTO_INCREMENT ,
`StopnjaTajnosti` VARCHAR(45) NULL ,
`ImePriimekNaziv` VARCHAR(45) NULL ,
`Opis` TEXT NULL ,
`OcenaStopnjeTajnosti` VARCHAR(45) NULL ,
`MinimalnaDobaHrambePodatkov` VARCHAR(45) NULL ,
`group_id` INT NULL ,
PRIMARY KEY (`idZZasV_Spisi`) )
ENGINE = InnoDB;
-- Table `mitzen01_veem`.`ZZasV_Zaposleni`
CREATE TABLE IF NOT EXISTS `mitzen01_veem`.`ZZasV_Zaposleni` (
`idZZasV_Zaposleni` INT NOT NULL AUTO_INCREMENT ,
`idZZasV_Spisi` INT NULL ,
`Ime` VARCHAR(45) NULL ,
`Priimek` VARCHAR(45) NULL ,
`StalnoPrebivalisce` TEXT NULL ,
`idPosta_StalnoPrebivalisce` INT NULL ,
`ZacasnoPrebivalisce` TEXT NULL ,
`idPosta_ZacasnoPrebivalisce` INT NULL ,
`DatumRojstva` DATETIME NULL ,
`KrajInDrzavaRojstva` VARCHAR(45) NULL ,
`EMSO` VARCHAR(45) NULL ,
`DavcnaStevilkal` VARCHAR(45) NULL ,
`Drzavljanstvo` VARCHAR(45) NULL ,
`Telefon` VARCHAR(45) NULL ,
`Email` VARCHAR(45) NULL ,
`Opombe` LONGTEXT NULL ,
`Aktiven` CHAR(1) NULL ,
PRIMARY KEY (`idZZasV_Zaposleni`) ,
INDEX `fk_ZZasV_Zaposleni_ZZasV_Spisi1_idx` (`idZZasV_Spisi` ASC) ,
INDEX `fk_ZZasV_Zaposleni_skupno_PostneStevilke1_idx` (`idPosta_StalnoPrebivalisce` ASC) ,
INDEX `fk_ZZasV_Zaposleni_skupno_PostneStevilke2_idx` (`idPosta_ZacasnoPrebivalisce` ASC) ,
CONSTRAINT `fk_ZZasV_Zaposleni_ZZasV_Spisi1`
FOREIGN KEY (`idZZasV_Spisi` )
REFERENCES `mitzen01_veem`.`ZZasV_Spisi` (`idZZasV_Spisi` )
ON DELETE NO ACTION
ON UPDATE NO ACTION,
CONSTRAINT `fk_ZZasV_Zaposleni_skupno_PostneStevilke1`
FOREIGN KEY (`idPosta_StalnoPrebivalisce` )
REFERENCES `mitzen01_veem`.`skupno_PostneStevilke` (`idPosta` )
ON DELETE NO ACTION
CONSTRAINT `fk_ZZasV_Zaposleni_skupno_PostneStevilke2`
FOREIGN KEY (`idPosta_ZacasnoPrebivalisce` )
ON DELETE NO ACTION
ON UPDATE NO ACTION)
ENGINE = InnoDB;
-- Table `mitzen01_veem`.`ZZasV_Zaposleni_SluzbenaIzkaznica`
CREATE TABLE IF NOT EXISTS `mitzen01_veem`.`ZZasV_Zaposleni_SluzbenaIzkaznica` (
`idZZasV_Zaposleni_SluzbenaIzkaznica` INT NOT NULL AUTO_INCREMENT ,
`idZZasV_Zaposleni` INT NULL ,
`DatumIzdaje` DATETIME NULL ,
`StevilkaIzkaznice` VARCHAR(45) NULL ,
`StrokovnaUsposobljenost` TEXT NULL ,
`Aktivna` CHAR(1) NULL ,
PRIMARY KEY (`idZZasV_Zaposleni_SluzbenaIzkaznica`) ,
INDEX `fk_ZZasV_Zaposleni_SluzbenaIzkaznica_ZZasV_Zaposleni1_idx` (`idZZasV_Zaposleni` ASC) ,
CONSTRAINT `fk_ZZasV_Zaposleni_SluzbenaIzkaznica_ZZasV_Zaposleni1`
FOREIGN KEY (`idZZasV_Zaposleni` )
REFERENCES `mitzen01_veem`.`ZZasV_Zaposleni` (`idZZasV_Zaposleni` )
ON DELETE NO ACTION
ENGINE = InnoDB;
-- Table `mitzen01_veem`.`ZZasV_Zaposleni_Pogodbe`
CREATE TABLE IF NOT EXISTS `mitzen01_veem`.`ZZasV_Zaposleni_Pogodbe` (
`idZZasV_Zaposleni_Pogodbe` INT NOT NULL AUTO_INCREMENT ,
`DatumPredlozitveVzorca` DATETIME NULL ,
`DatumSklenitve` DATETIME NULL ,
`DatumZacetkaUporabe` DATETIME NULL ,
`DatumZakljucka` DATETIME NULL ,
PRIMARY KEY (`idZZasV_Zaposleni_Pogodbe`) ,
INDEX `fk_ZZasV_Zaposleni_Pogodbe_ZZasV_Zaposleni1_idx` (`idZZasV_Zaposleni` ASC) ,
CONSTRAINT `fk_ZZasV_Zaposleni_Pogodbe_ZZasV_Zaposleni1`
ON DELETE NO ACTION
ENGINE = InnoDB;
SET SQL_MODE=@OLD_SQL_MODE;
SET FOREIGN_KEY_CHECKS=@OLD_FOREIGN_KEY_CHECKS;
SET UNIQUE_CHECKS=@OLD_UNIQUE_CHECKS;
Napaka, ki jo vedno dobim, pa naj delam karkoli je:
Napaka
Poizvedba SQL:
`id` INT( 8 ) NOT NULL AUTO_INCREMENT ,
`username` VARCHAR( 90 ) CHARACTER SET 'utf8' COLLATE 'utf8_slovenian_ci' NOT NULL ,
`application` VARCHAR( 200 ) CHARACTER SET 'utf8' COLLATE 'utf8_slovenian_ci' NOT NULL ,
`creator` VARCHAR( 30 ) CHARACTER SET 'utf8' COLLATE 'utf8_slovenian_ci' NOT NULL ,
`ip_user` VARCHAR( 32 ) CHARACTER SET 'utf8' COLLATE 'utf8_slovenian_ci' NOT NULL ,
`action` VARCHAR( 30 ) CHARACTER SET 'utf8' COLLATE 'utf8_slovenian_ci' NOT NULL ,
PRIMARY KEY ( `id` )
) ENGINE = MYISAM AUTO_INCREMENT =346 DEFAULT CHARACTER SET = utf8 COLLATE = utf8_slovenian_ci;
Kaka ideja?
Hvala za pomoč!
Nobody is perfect! But who wants to be nobody?
- spremenil: Mavrik ()
keworkian ::
Odstran
CHARACTER SET 'utf8'je
COLLATE 'utf8_slovenian_ci'dovolj
Obscenities in B-Flat
mitja ::
Sem odstranil. Pa ni šlo.
Sem odstranil tudi COLLATE '*'. ..ista napaka...
Kaka ideja?
Kaka ideja?
mitja ::
V bistvu je to kar sem naredil lep primer gledanja v nekaj kar ima pomanjkljivost zaradi šlamparije. :D
Sem ugotovil, da ima mile prav. V bazi je bilo še ene par takih cvetk.
Hvala vsem za pomoč!
| » | MySql Vprasanje - problem dupliciranih kljucevOddelek: Izdelava spletišč | 1886 (1708) | KernelPanic |
| » | C# - MySQL - šumnikiOddelek: Programiranje | 2572 (2471) | Matthew |
| » | FULLTEXT indeksi - problemi pri osnovnem primeruOddelek: Programiranje | 1213 (1134) | barelyLegal |
| » | MySQL in czsOddelek: Izdelava spletišč | 3969 (3059) | krho |
| » | kako spreminiti vse php fajle in celo bazo v utf-8Oddelek: Izdelava spletišč | 1583 (1363) | Senzacionale |
