Linksys WRT54G težava
d4vid ::
Dobil sem Linksysa WRT54GL. Router ima težavo da se ga ne da resetirat na originalne nastavitve, zato se ne morem prijavit v spletni vmesnik. Gesla ne vem, ker ga je lastnik pozabil.
Hotel sem flešat ddwrt, vendar ga verzija 7 ne podpira. Med drugim ko sem poskusil tiščat reset gumb dokler nisem videl "management mode firmware upgrade" je napisal upgrade failed.
Zanima me, kaj še lahko storim? Ta verzija je "čudna", ima namreč malo rama in atheros procesor...
Hayabusa ::
WRT54G =! WRT54GLm 54GL sta samo 2 verziji 1.0 in 1.1.
Povej serijsko tvojega routerja (CDFE ali nekaj podobnega).
Linksys WRT54G series @ Wikipedia
  • spremenilo: Hayabusa ()
d4vid ::
Na njem piše WRT54G ver.7
S/N: CDFE1H454043
Hayabusa ::
Ja, imaš WRT54G v7.
Je na njem stock fw (VxWorks based) ?
nekaj informacij:
http://wiki.openwrt.org/doku.php?id=old...
This device runs Atheros's own bootloader, and VxWorks proprietary OS, which doesn't have network (ethernet) firmware uploading/downloading support, so no boot_wait either. It supports uploads/downloads via serial console (XMODEM). It also seems that SMC removed the atheros board configuration data from the flash ROM, so it has to be reprogrammed.
http://support.linksys.com/en-eu/suppor...
izberi fw v"7.0" in poskusi flashati s stock fw.
30/30/30 metoda
http://community.linksys.com/t5/Wireles...
1. Press and hold the reset button for 30 seconds.
2. Then, unplug the power keep holding down the reset button for
another 30 Seconds.
3. Plug back the power back in, and keep holding down the reset button
for 30 Seconds.
4. Release the reset button.
UG, PDF # 51
http://downloads.linksys.com/downloads/...
9. I forgot my password, or the password prompt always appears when I am saving settings to the
Router.
Reset the Router to factory default by pressing the Reset button for 10 seconds and then releasing it. If you
are still getting prompted for a password when saving settings, then perform the following steps:
d4vid ::
Stock firmware ne deluje... Piše upgrade failed.
Bom poskusil 30/30/30 (zakaj se mi je zdelo da je 20/20/20?)
Drugače pa LAN in WLAN lučki utripata zelo čudno... Enkrat ena nato druga (izmenično)
d4vid ::
Ne deluje nič od naštetega... Kje na vezju je pa JTAG, da bi še tako poskusil flešat?
Hayabusa ::
d4vid ::
Po vseh poskusih ga še vedno nisem resetiral. Ruter se prižge in oddaja brezžično omrežje. Gesla ne vem ne za administracijo, ne za WiFi.
Še kakšna ideja?
lukaz ::
Z kablom povezat gor pa bruteforce passworda?
težka bo.
Tudi če ti uspe pridit v nastavitve, jih boš zgubljal ob rebootih, ker če se neda resetirat, pomen da je flash fuč..
d4vid ::
lukaz je izjavil:
Hja... Lahko bi poskusil samo težava je, da bo najbrž trajalo predlogo (ne vem dolžine gesla...). Maš kako idejo kater program naj uporabim? Ali zaženem backtrack?
Je kaka možnost da se zamenja cel flash? Sicer znam spajkat, ampak glede na razmik med pini sam to težko naredim... Sem že gledal da so menjal ram in tudi flash za večjega...
  • spremenil: d4vid ()
težave z Linksys Wireless- WRT54G routerjem
424197 (2116) AC_DC
WRT54GL me ne spusti na Facebook :O
Oddelek: Omrežja in internet
245017 (4662) Er333
Kako popraviti router Linksys WRT160N po neuspešni nadgrandji firwara! NUJNO!
93917 (3744) Padly88
nastavitve ali downgrade router-ja WRT54GL
192972 (2397) nx6325
Naložil DD-WRT sedaj pa ne morem na orig. firmware
202264 (1719) zzitop
