Forum » Loža » Bill Gates = Satan?
Bill Gates = Satan?
(sic) ::
To ti, da nekaj za premišljevati:
Something To Think About
Did you know that Bill Gates'
real name is William Henry Gates III?
Nowadays, he is known as Bill Gates (III)
where III means the order of third.
So what's so eerie about this name?
Well, if you take all the letters in Bill Gates III
and then convert it into ASCII code
(American Standard Code for Info. Interchange)
and then add up all the numbers....
You will get 666,
which is the number of the beast.
666
b = 28
I = 73
L = 76
L = 76
G = 71
A = 65
T = 84
E = 69
S = 83
I = 1
I = 1
I = 1
Add these numbers and they equal 666.
Coincidence? Perhaps....
Maybe, but take Windows 95 and do the
same procedure and you will get 666 also.
And even MS-DOS 6.31 adds up to 666.
Still think it is coincidence?
Stay with me....it gets better.
For those of you who still have the
old excel 95 (not office 97) try this out:
(this really works)
1 - Open a new file
2 - Scroll down to row 95
3 - Click on the row 95 button to highlight the entire row
4 - Press tab to move to the second column
5 - Now, move your mouse and click on help at the top
6 - Then click on "about Microsoft excel"
7 - Press ctrl-alt-shift and click on the
tech support button at the same time.
A window will appear with the title:
THE HALL OF TORTURED SOULS.
This is really eerie, okay!
It has a doom style format and you can walk
all around the hall using the arrow keys.
On the sides of the walls are the
names of the tortured souls....
Now walk up the stairs and then come back down,
facing the blank wall.
Now type in EXCELKFA;
this will open the blank wall to reveal another
secret passage, walk through the passage
and do not fall off. This is difficult to do.
When you get to the end you
will see something really, really eerie.
As of this point in time,
countless witnesses all over the world have
verified that it is a real eye opener.
It could be a joke by MS programmers.
Or is it?
Would it be too surprising if Bill Gates was the antichrist?
After all, the bible fore told that someone powerful
would rise up and lead the world to destruction.
And Bill Gates definitely has this
kind of power in his hands.
More than 80% of computers in the world
today run on windows and DOS
(including those at the Pentagon).
If all of his products have some kind of
small program embedded, like this
"hall of tortured souls", that can give him
control to set off nuclear arsenals,
create havoc in security systems and
financial systems all over the world, etc.
All from his headquarters.
This isn't too far from reality.
Just by using the Internet Explorer
may just allow him to map out
what you have on your computer
bit by bit each time you log on.
Perhaps the end of time is near and
this is just the tip of the iceberg?
Quote from the Bible:
"He also forced everyone, small and great,
rich and poor, free and slave,
to receive a mark on his right hand
or on his forehead,
so that no one could buy or
sell unless he had the mark,
which is the name of the beast or the number of his name.
This calls for wisdom. If anyone has insight,
let him calculate the number of the beast,
for it is man's number.
His number is 666.
Revelation 13:16-18
This is something you should think about.
If the Bible, in the book of Revelations,
says that without the sign of the beast,
one would not be able to buy,
sell, do business transactions, etc.,
then my question to you now is this....
Is the Internet a necessity today
for doing business?
The Internet also bears the gn.
Note that the Internet is often
referred to as the...
World Wide Web, or www.
Another way to write W is
V/ or VI.
W W W
VI VI VI
6 6 6
Here is something to ponder.
Isn't everything going towards the Internet?
(i.e., buying, selling, business transactions)
Isn't Microsoft always on the move to have
a monopoly when it comes to software technology?
And now the Internet?
Revelations also says that the mark of the beast
will be carved on one's hand and on one's forehead.
If the Internet would indeed be the beast,
aren't we all starting to carry it on our hands and foreheads?
The screen is the forehead and
the hand uses the mouse.
Are things finally starting to fall into place or
are we just letting our imagination run????
Remember, the devil came to cheat,
steal and to destroy.
So, be vigilant about Bill Gates and Microsoft!
Coincidence? Maybe..........maybe not
anyway ....its something to think about aint it !
You will get 666,
666
b = 28
I = 73
L = 76
L = 76
G = 71
A = 65
T = 84
E = 69
S = 83
I = 1
I = 1
I = 1
(this really works)
1 - Open a new file
Or is it?
or on his forehead,
His number is 666.
Revelation 13:16-18
for doing business?
V/ or VI.
W W W
VI VI VI
6 6 6
- zaklenil: Ziga Dolhar ()
MUC ::
Bullshit .. velike male črke so vzete, tako da se vse izide .. skratka bedarija na ^2.
Poleg tega | nima ASCII kode 1, ampak veliko več .. spet bedarija na ^3.
Naprej se mi ne da več, je pa še velik drugega.
(sic) ::
McWolf:
Jaz si bom zrihtal Excel 95 samo zato, da vidim, če je ta zadeva resnična...
Če pa ma kdo nameščenega ali pa ga ma doma pa naj preveri.
Thomas ::
Tole je tipična past za naivne možgane.
Neumnost za neumnostjo ...
Vendar se ob kakšni komu zazdi, da to bi pa znalo biti več kot naklučje. Potem se sproži še "kaj pa če je vse res".
In en tepec več!
In en tepec več!
| » | Najboljši vici (strani: 1 2 )Oddelek: Loža | 34174 (3576) | twom |
| » | IPv6 - Imam ga, mnogo njegaOddelek: Omrežja in internet | 4914 (3847) | darkolord |
| » | Nov članek: "All your firmware are belong to us" (strani: 1 2 3 )Oddelek: Novice / Nova vsebina | 20267 (17107) | arrigo |
| » | Jest mam virus a?!Oddelek: Pomoč in nasveti | 2812 (2569) | Kriko |
