Forum » Pomoč in nasveti » Dialer.apk Error
Dialer.apk Error
Someoneilove ::
Z root uninstaller sem zbrisala nekaj aplikacij. Po nesreči sem zbrisala tudi aplikaciji "dialer.apk in phone.apk". Phone storage.apk imam se vedno. Po tem ko sta bili te dve aplikaciji odstranjeni je zacel telefon vibrirat in mi posiljat error da se ne odziva in da se mora zapreti. Telefon sem resetirala, ampak je bil problem se vedno enak. Ugotovila sem da ne morem klicati nikogar, prav tako tudi nihce ne more klicati mene. Iz google-play sem downloadala One Dialer, ampak to se vedno ni resilo problema. Poskusila sem veliko aplikacij vendar zaman. Poskusila sem narediti "factory reset" in spet sem dobila error. Klicnih nastavitev mi sploh ne odpre in mi napise error. Ne vem vec kaj naj naredim. Prosim, ce mi kdo ki se na to spozna pomaga.
Telefon; Samsung Galaxy 5- Gt i5500
Hvala ze vnaprej
I've used Root uninstaller to remove some applications but accidently i also removed dialer.apk and phone.apk . (phone storage.apk is still here).
After that my phone started vibrating and giving me errors as phone.apk is not responding and that the application needs to close.. I re-booted my phone and it was still the same.. I tried to call but it won't let me. It always gives me the same error over and over again. I installed an application onedialer.apk from google play and it's still the same. I tried to do a factory reset and i will get the error again. Also in the settings pannel - call settings is giving me the error. I don't know anymore what to do. I would need a real help.
My phone; Samsung Galaxy 5 - Gt i5500
Please help me
Hvala ze vnaprej
Please help me
andromedar ::
Samsunga sicer še nisem imel, ampak sigurno ima priložen program za posodobitve. Instaliraj ga, če še nisi in zaženi. Ena od opcij je skoraj sigurno 'ponovna namestitev' oz. kaj podobnega. Naredi to.
Pred tem še naredi backup morebitnih podatkov, v kolikor je to sploh še mogoče.
Eh?
- spremenil: andromedar ()
_Denny_ ::
Naredi vse po navodilih s tega linka; uporabi firmware z oznako "I5500XFJPQ Android 2.2 - 2011 May (Europe)". Imaš res srečo, ker sta to glavna apk-ja za klicanje...naslednjič uporabi Titanium Backup root in daj freeze namesto delete. Na tak način lahko brez problema daš un-freeze in stvar spet deluje.
Someoneilove ::
Uporabnik je zbrisal to datoteko.. Drugace imam Froyo 2.2 (operacijski sistem).
Looooooka ::
Zdaj imas dober razlog za nadgrandjo na 4ko :)
"Shit doesn't work anymore"
Ravno vceraj izvedel zadevo na "nepodprti" tablici.
Mi ni nic zal.
Mi ni nic zal.
- spremenilo: Looooooka ()
| » | D3 GO, Amis MobiaTV, T-2 tv2go [Hacked APK][ROOT] (strani: 1 2 3 4 … 7 8 9 10 )Oddelek: Mobilne tehnologije | 187288 (45486) | yani2000 |
| » | Stanje pripravljenosti na tabliciOddelek: Pomoč in nasveti | 2092 (1862) | bond007 |
| » | Firmware I570EXXJC5 za samsung galaxy spica (strani: 1 2 )Oddelek: Mobilne tehnologije | 11971 (8397) | globoko grlo |
| » | Android 2.3 prispel za HTC Desire (strani: 1 2 )Oddelek: Novice / Android | 21638 (19249) | sgdjkdlsugi4 |
| » | Quake 2 in 3 nativno na AndroiduOddelek: Novice / Android | 9755 (8004) | Tomozuki |
