Forum » Pomoč in nasveti » Problem z toolbar
Problem z toolbar
drecos ::
Imam problem z tooblarji.Namestil sem Magic Ball 2 in zraven je namestilo toolbar Search Here in ko sem odstranil Magic Ball 2 se je toolbar se vedno prikazal v Internet Explorer, v programi tega toolbarja ni, rad pa bi ga izbrisal.Prosim za pomoč da zbrišem ta toolbar.
SLIKA:
drecos
SLIKA:
drecos
- spremenil: drecos ()
johan11 ::
Instaliraj si Revo Unistaller - ko ga boš odprl ti bo pokazal vse programe in toolbare , ki jih imaš - potem pa brišeš
Hayabusa ::
V add/remove programs ga tudi ni ?
http://technet.microsoft.com/en-us/maga...
Fix Unwanted Changes to Settings
If the home page or other settings have changed, you can reset all browser settings except for Favorites, Feed, Internet Connection Settings, Group Policy Settings, and Content Advisor Settings by following these steps:
Close all windows except for one Internet Explorer window.
Click Tools and then click Internet Options.
In the Internet Options dialog box, click the Advanced tab.
Click Reset.
In the warning box that appears, click Reset.
Click Close and then click OK twice. Restart Internet Explorer.
ali
http://www.pcworld.com/article/241720/h...
Click Reset.
ali
- spremenilo: Hayabusa ()
| » | Gmail težavaOddelek: Omrežja in internet | 1035 (906) | mirc001 |
| » | Msn TEŽAVA...!!! čudna zadevaa...Oddelek: Pomoč in nasveti | 2263 (1888) | d3n!5 |
| » | microsoft update (problemi)Oddelek: Operacijski sistemi | 2461 (2281) | TechBeats |
| » | Kako v Win2k premakniti mapo Documents and Settings?Oddelek: Operacijski sistemi | 2542 (2508) | Mercier |
| » | Logitech MouseWare bug (?)Oddelek: Pomoč in nasveti | 2610 (2206) | Swiwer |
