Forum » Operacijski sistemi » microsoft update (problemi)
Dr Živago ::
sedaj, ko hočem preveriti za posodobitve preko ie, se mi je pojavil problem pri microsoft update, saj mi hoče kar namestiti kao na računalnik, češ da je novo pri microsoftu, (pa saj že imam microsoft update v start meniju).
potem pa mi se mi pojavi ta napaka, ko kliknem, da namesti:
Please change your Internet Explorer security settings
To save changes to your settings for this website, you need to enable userdata persistence for Internet Explorer. Complete the steps below, and then click Change settings to the left and try saving your changes again.
In Internet Explorer, on the Tools menu, click Internet Options.
Click the Security tab, click the Internet security zone icon, and then click Custom Level.
In the Settings dialog box, scroll to the Miscellaneous section.
Under Userdata persistence , select Enable.
Click OK and when the security warning dialog box appears, click Yes.
Read more about steps you can take to resolve this problem (error number 0x800A0046) yourself.
a se to pojavi še pri komu ali samo pri meni? kaj naj naredim?
- spremenila: Dr Živago ()
TechBeats ::
to je ena stran, ki se predstavlja kot ms updajte, zato raj to ne poskuši, ker te preusmeri na eno drugo stran in ti ukrade podatke (nism sigurn sam enkrat je mene en spyware program upozoril, da stran MS update is a possible hijack page)
MS stran update -original (se odpre u IE)
probi ta link, če se ti bo isto odprla una nova stran, k je na screenshotu, če ja potem imaš hijackt stran
Dr Živago ::
kaj pa je hijack stran? isto se pokaže (slika zgoraj) pa še podroben opis:
Now you can get updates for Windows, Office and other Microsoft applications all in one place. Microsoft Update is a new service that brings you all the features and benefits of Windows Update plus downloads for other Microsoft applications including Office.
Start Now
Benefits
Improve your computer’s health and security.
Regularly update your computer with the latest software from Microsoft to boost the security and reliability of your Windows PC.
Easy and flexible.
Microsoft Update is easy to set up and use. Download and install updates automatically, or customize the choices that are right for you.
New features, better performance.
Every month, Microsoft releases new drivers and software that increase the performance and functionality of your Windows-based computer. Get enhancements as soon as they are available using Microsoft Update.
Are you a Server Administrator?
Click here to see what Microsoft Update can do for you. Works with Automatic Updates:
Adds an easy link to your Start menu:
kaj pa tebi prikaže? mislim, včeraj je še normalno delovala stran (iskanje updatejev pa ostalo), zdaj pa ne več.
Start Now
Benefits
Easy and flexible.
TechBeats ::
Dr Živago ::
polaufi spybot search & destroy 1.4 (men sezdi, da mi je ta program najdu)
kje to najdem? kaj pa je sploh hijack?
točno to mi je še včeraj pokazalo na isti strani, kot imaš na slikah, zdaj pa ne. sicer sem šla na http://www.microsoft.com/en/us/default.aspx pa "security & updates" in kliknila na "microsoft update", pa je spet ista slika.
btw, s katerim programom ti je uspelo urediti slike in dati na internet, da bi še jaz dala gor, kako izgleda ta stran?
TechBeats ::
Spybot search & destroy 1.4 -link
tu je ta program, sam na en link klikni in ti bo začel downloadat, pa updejti seveda.
Hijack = ugrabitev strani oz. se izdaja kot lažna stran.
te slike sm pa prenesu iz, www.photobucket.com (kle mam narjen svoj account), maš pa tud slovensko, mensezdi da je www.shrani.si
aja, za sliko sm pa dal printscreen in potem odpru paint oz. slikarja in dal paste notr v paintu in to je to
probi polaufat pa spybot če bo kej boljš.
Dr Živago ::
hvala. ;) kje pa najdem printscreen? btw, ko sem resertirala računalnik, mi je update na strani normalno deloval, tako, da ne vem, čemu je včeraj kazalo drugače.
TechBeats ::
Ja neki vsaj pomoje tole ne štima, probi še ta program Spyware Blaster 3.5.1-link, ta ti pa zablokera take hijackt strani.
AciD TriP
Dr Živago ::
En knof naprej od F12
@#000000:
na moji tipkovnici je potem to delete - je to ta printscreen?
@#000000:
| » | Čuden zvokOddelek: Pomoč in nasveti | 923 (826) | Ciklamen |
| » | problem pri windows XP (taskbar)Oddelek: Programska oprema | 2322 (2161) | Dr Živago |
| » | počasno odzivanje My Network...Oddelek: Omrežja in internet | 1465 (1269) | TechBeats |
| » | Virus - TrojanciOddelek: Pomoč in nasveti | 2012 (1752) | TechBeats |
| » | samodejno prikazovanje pornogafijeOddelek: Omrežja in internet | 2058 (1521) | danim7 |
