zvok preko HDMI kabla
zerdoner ::
lep pozdrav.
Comp imam na tv priklopljen preko hdmi kabla. rad bi, da mi zvok na tvju predvaja kar preko tega kabla vendar nekak ne dela. v biosu imam nastavljeno na audio hd. enkrat mi je zadeva delala sedaj pa ne več. v win mi vse lepo kaze kot, da zvok dela vendar na tvju ni zvoka.
maš v audio devices nastavljen output na HDMI?
Click on "Control Panel"
- With the Control Panel in "Control Panel Home" view please click on "Hardware and Sound"
- Where it says "Sound" in green letters there are three options below that are in blue click on "Manage Audio Devices"
- This will bring up a window labeled "Sound"
- On the "Playback" tab there is listed the sound options available to you. One should read "Digital Output Device (HDMI)" Click on that.
- There should now be a check mark on that option.
- The Sound should then play through your HDMI hookups to the TV.
  • spremenil: mtosev ()
OZZY ::
Nastavitev audio naprav. Poglej pod privzeto napravo in jo spremeni na HDMI output. Je pa res, da potem ne dela zvok preko slušalk.
Go with the flow.
Zvok ob predvajanju filma
171284 (1134) iloveboobz
DVI(PC)--->HDMI(TV) ni zvoka (strani: 1 2 )
Oddelek: Zvok in slika
6323127 (12239) BorutK-73
LG le5300 in Pc -ni zovka
51141 (1081) sebas4
zvok s tv kartice
61173 (1144) Jan987
Zvok z vecih cd-romov?
142532 (2303) Justy
