Forum » Zvok in slika » zvok s tv kartice
zvok s tv kartice
Jan987 ::
Imam sistem v podpisu ter pa grafo all in woder 9800se ter pa tv kartico win fast 200/xp expert.
Problem je v tem, da sliko prikazujeta obe, zvoka pa noče nobena. Probal sem tudi ponovno naložiti os a je ostalo isto. Uporabljam xp-je. Zvok v vseh drugih aplikacijah deluje BP.
Kaj je narobe da zvok ne dela?
HerrFlick ::
Pa imaš inštalirani obe kartici naenkrat? Lahko, da se "tepeta" med seboj, če sta obe inštalirani. Poskusi samo z eno (a nima all-in-wonder že svoj tv tuner?).
Jan987 ::
ja sej zdej imam samo all in woder ker sem pač nabavil all in woder grafično tadruga pa ni inštalirana. Tud prej k je bla samo tv kartica niblo zvoka
HerrFlick ::
Selecting the sound card
connector for TV audio input
The sound card connector determines which mixer slider is
controlled by the ATI Multimedia Center’s volume slider.
1 Click the Setup button in the TV Player control panel,
then click the Display tab.
2 Click the Initialization Wizard button, then click the Next
button twice.
3 In the Typical Audio Connections page, check I have
connected the cable to confirm that you have connected
your ALL-IN-WONDER card’s audio output cable to your
sound card’s Line-In connector.
4 Click Next to open the TV Sound Initialization Wizard.
5 Click the audio input that matches the connection between
your ALL-IN-WONDER card and your sound card.
(Line-In is the standard audio input when the
ALL-IN-WONDER card’s audio output cable is connected
to the sound card’s Line-In connector.) If you are not sure
how it is connected, click each source (CD Audio, Line-In,
etc.), and listen for the sound.
button twice.
Jan987 ::
na grafični so samo video aut in video in ter da dvi in antena priključki.
A mi prosim lahko tist sestavek prevedeš v slo ker ne obvladam glih angleščine najbolj
| » | Zvok ob predvajanju filmaOddelek: Pomoč in nasveti | 1308 (1158) | iloveboobz |
| » | Soundbar ne igraOddelek: Pomoč in nasveti | 1985 (1835) | eno_ime |
| » | Ne predvaja novega audio CDOddelek: Pomoč in nasveti | 2606 (2562) | Tea Time |
| » | pohitritev dsl ali kabelskega neta v win xpOddelek: Omrežja in internet | 2180 (1918) | BlueRunner |
| » | Zvok z vecih cd-romov?Oddelek: Zvok in slika | 2562 (2333) | Justy |
