Forum » Pomoč in nasveti » Frekvenca RAM
Frekvenca RAM
TadyM ::
Pozdravljeni,
Danes sem gledal mojo frekvenco RAM. Program prepozna da deluje na 666Mhz, ker pa de DDR3 pa je to potem 1332Mhz. Mogel pa bi biti na 1600Mhz. Kaj bi bilo narobe, da bi bila hitrost premajhna. Matična plošča podpira DDR3 2200/1600/1333/1066/800 MHz memory modules.
Hvala za odgovor in LP.
TadyM ::
Intel Core i3 550 @ 3.20GHz
Sem pogledal se za procesor:
Max Memory Size (dependent on memory type): 16 GB
Memory Types: DDR3-1066/1333
# of Memory Channels: 2
Max Memory Bandwidth: 21 GB/s
Physical Address Extensions: 36-bit
Kaj pa pomeni max memory channels?
- spremenil: TadyM ()
amigo_no1 ::
Dual channel, naketeri čipseti omogočajo tudi triple.
http://ark.intel.com/products/48505/Int...
Memory Types DDR3-1066/1333
Je normalno, rami bodo v navezi s tvojim procesorjem delali na max 1333 Mhz.
http://www.tomshardware.co.uk/forum/299...
The official Intel spec limits the memory to DDR3-1333 speeds. However, if you put the processor into an overclocker-type P67 mainboard, you will be able to set the RAM to 1600, 1866, or even 2133 speeds. You will get the full speed out of your RAM as long as you buy one of those supported speeds (1066, 1333, 1600, 1866, or 2133). If you buy DDR3-2000 RAM or some other strange speed, it will down-clock to the next lowest supported speed (for 2000, that would be 1866).
in
You can still overclock.
By the Intel spec, the memory controller is overclocked at anything above 1333. Also, if you have 1600 RAM for example, you could run it at 1866. There's a lot less granularity in the RAM overclocks, but you can still overclock it.
- spremenilo: amigo_no1 ()
subby ::
Praktično ni razlike, pusti kakor je. Ram ti dela na 1333, ker mu toliko dopušča procesor. Če bi hotel 1600, bi bil potreben overclock.
Jst ::
Poglej za "Profile X.M.P." v CpuID v SPD, če ti ram sploh podpira XMP profil.
r3dkv1c4 ::
r3dkv1c4 ::
| » | i7 930 plata Asus P6T Deluxe in ramiOddelek: Strojna oprema | 2856 (2630) | RejZoR |
| » | Problem: Nov RAM ista hitrostOddelek: Pomoč in nasveti | 1407 (1013) | first_line |
| » | Koliko navijanja zdrži i5 stock cooler? (strani: 1 2 )Oddelek: Navijanje | 5050 (3858) | 123_meni |
| » | ASUS Maximus IV Extreme-Z ali Gigabyte GA - Z68X - UD7 - B3Oddelek: Strojna oprema | 3978 (3753) | TOP |
| » | Vse po malemOddelek: Kaj kupiti | 1324 (1185) | -THX- |
