Forum » Operacijski sistemi » OpenSUSE pomoč
OpenSUSE pomoč
Redorange ::
Rabim malo pomoči.
OpenSUSE 12.2, 64bit
Poizkušam namestiti tole zadevo ampak ne gre.
Sem tudi že brskal po netu kako se namešča ampak brez uspeha. V mapi je datoteka install in sem bral, ampak ne gre. Ker mam 64bit je treba nekaj ne vem kaj in v konzoli me ne spusti naprej.
Qt4, boost, libusb, marble, openssl imam nameščeno,
chrpath pa mi ga ne najde.
To je v datoteki install:
Install instructions
Dependencies
To compile igotu2gpx, you need:
- qt4 (http://www.qtsoftware.com/)
- boost (http://www.boost.org/)
- boost-program-options (http://www.boost.org/, included with boost)
- libusb 0.1 (on Linux, http://libusb.sourceforge.net/)
- libusb 0.1.13 (on Mac OS X systems, http://www.ellert.se/twain-sane/)
- chrpath (on Linux, optional, makes it possible to run the program without
installation)
- marble (http://edu.kde.org/marble, optional, openstreetmap display of tracks)
- openssl (on Windows already on install, otherwise only at runtime, http://openssl.org)
On a Ubuntu system, this should get you the dependencies:
sudo aptitude install libqt4-dev libboost-dev libboost-program-options-dev \
libusb-dev libmarble-dev chrpath
Compiling
Linux
On a Linux system, you can compile with:
qmake && make && sudo make install
If you get error messages about "Unknown test functions" from qmake, try
qmake-qt4 instead of qmake.
If you are on a 64bit system and your distributor ships 64bit libraries in
/lib64 and /usr/lib64, use "qmake LIBDIR=/usr/local/lib64".
If you use a compiler older than gcc 4.0.0, use "qmake CLEBS=novisibility".
If you get an error message of
/usr/local/bin/igotugui: error while loading shared libraries:
libigotu.so.1: cannot open shared object file: No such file or directory
although it got installed correctly, you might be missing library path. It
might help to create a file "/etc/ld.so.conf.d/local.conf" with the following
content:
/usr/local/lib
and run:
ldconfig
- spremenil: Redorange ()
Redorange ::
Tako sem probal:
Password:
linux-b0y5:~ # cd /home/bojan/Dokumenti/igotu/igotu2gpx-0.3.0
linux-b0y5:/home/bojan/Dokumenti/igotu/igotu2gpx-0.3.0 # qmake
If 'qmake' is not a typo you can use command-not-found to lookup the package that contains it, like this:
cnf qmake
linux-b0y5:/home/bojan/Dokumenti/igotu/igotu2gpx-0.3.0 # make
make: *** No targets specified and no makefile found. Stop.
linux-b0y5:/home/bojan/Dokumenti/igotu/igotu2gpx-0.3.0 # make install
make: *** No rule to make target `install'. Stop.
Password:
cnf qmake
amigo_no1 ::
Imaš nameščeno vse, kar je navedeno pod "Dependencies" (vrstice med 9-17) ?
Jih imaš ?
39 If you are on a 64bit system and your distributor ships 64bit libraries in 40 /lib64 and /usr/lib64, use "qmake LIBDIR=/usr/local/lib64".
Jih imaš ?
- spremenilo: amigo_no1 ()
NeMeTko ::
glede na tole:
bi se vprašal, če sploh ima qmake na sistemu?
cnf qmake
Redorange ::
qconf - Configuration tool for qmake, tole ni nameščeno. Probam.
Isto kot prej.
Isto kot prej.
Zvezdica27 ::
lp,
kolikor vem je qmake program v paketu qt3 ali qt4, ker je pač del Qt... goooglam, gledam pri meni (ubuntu)... aha, paket qt4-qmake - je na OpenSUSE isti? maš ta paket? Če ne, ga namesti (pač poglej, ne vem kako to v zypp pogledaš, poglej man) in komanda bo delala...
zz
zz
Redorange ::
libqt4-devel, bo kar sem dobil po netu.
Zdaj pa tole:
bost-po, nimam nameščenega (imam 6 drugih) in ga tudi ne najde. Je pa cel kup drugih bost na razpolago.
Zdaj pa tole:
linux-b0y5:/home/bojan/Dokumenti/igotu/igotu2gpx-0.3.0 # qmake WARNING: /home/bojan/Dokumenti/igotu/igotu2gpx-0.3.0/clebs.pri:147: Unable to find file for inclusion localconfig.pri which: no chrpath in (/sbin:/usr/sbin:/usr/local/sbin:/root/bin:/usr/local/bin:/usr/bin:/bin:/usr/bin/X11:/usr/X11R6/bin:/usr/games:/usr/lib/mit/bin) Project MESSAGE: ------------------------------------ Project MESSAGE: Required dependencies: Project MESSAGE: ------------------------------------ WARNING: /home/bojan/Dokumenti/igotu/igotu2gpx-0.3.0/clebs.pri:127: Unescaped backslashes are deprecated. Project MESSAGE: Looking for qtversion430 : yes Project MESSAGE: Looking for boost-po : no Project ERROR: Please install the necessary (devel) packages for boost-po! linux-b0y5:/home/bojan/Dokumenti/igotu/igotu2gpx-0.3.0 #
crniangeo ::
Convictions are more dangerous foes of truth than lies.
OmegaBlue ::
Poglej da imaš v yast nameščene patterns-openSUSE-devel_C_C++ in patterns-openSUSE-devel_qt4, s tem dobiš vsa potrebna orodja. Za boost bi mogel zadostovat boost-devel paketek.
Namesti te paketke in poženi, če ne dela se oglasi nazaj
Redorange ::
Nič od tega nisem imel.
Sedaj pa:
libmarble - ni na seznamu, je libmarblewidget13 - nameščen
libusb - nekaj je nameščeno, je pa še cel kup drugih
libusb10 - ni na seznamu
chrpath - nameščam zdaj
Nič od tega mi ne najde:
marblevisualizer
libusbconnection
libusb10connectio
Sedaj pa:
linux-b0y5:/home/bojan/Dokumenti/igotu/igotu2gpx-0.3.0 # qmake WARNING: /home/bojan/Dokumenti/igotu/igotu2gpx-0.3.0/clebs.pri:147: Unable to find file for inclusion localconfig.pri which: no chrpath in (/usr/lib64/mpi/gcc/openmpi/bin:/sbin:/usr/sbin:/usr/local/sbin:/root/bin:/usr/local/bin:/usr/bin:/bin:/usr/bin/X11:/usr/X11R6/bin:/usr/games:/usr/lib/mit/bin) Project MESSAGE: ------------------------------------ Project MESSAGE: Required dependencies: Project MESSAGE: ------------------------------------ WARNING: /home/bojan/Dokumenti/igotu/igotu2gpx-0.3.0/clebs.pri:127: Unescaped backslashes are deprecated. Project MESSAGE: Looking for qtversion430 : yes Project MESSAGE: Looking for boost-po : yes Project MESSAGE: ------------------------------------ Project MESSAGE: Suggested dependencies: Project MESSAGE: ------------------------------------ Project MESSAGE: Looking for libmarble : no Project MESSAGE: Looking for libusb : no Project MESSAGE: Looking for libusb10 : no Project MESSAGE: Looking for chrpath : no Project MESSAGE: ------------------------------------ Project MESSAGE: Additional features: Project MESSAGE: ------------------------------------ WARNING: /home/bojan/Dokumenti/igotu/igotu2gpx-0.3.0/clebs.pri:47: Unescaped backslashes are deprecated. Project MESSAGE: Building with marblevisualizer : no Project MESSAGE: Building with libusbconnection : no Project MESSAGE: Building with libusb10connectio: no Project MESSAGE: ------------------------------------ Project ERROR: No device drivers found, please install either libusb or libusb-1.0 (alpha quality driver) linux-b0y5:/home/bojan/Dokumenti/igotu/igotu2gpx-0.3.0 #
marblevisualizer
libusbconnection
libusb10connectio
| » | [Code:Blocks, c++] Program ne najde knjižniceOddelek: Programiranje | 1786 (1565) | gtu |
| » | Arhiviranje serverja s TAR - incremental in FTP na drugo lokacijo in email report - SOddelek: Operacijski sistemi | 2001 (1912) | Daedalus |
| » | [C++Qt] libs, style-sheet in opravilna vrsticaOddelek: Programiranje | 1590 (1499) | 'FireSTORM' |
| » | [Windows]Qt 4.3.0 Open SourceOddelek: Programska oprema | 1790 (1503) | BigWhale |
| » | Google Earth odslej tudi za Linux (strani: 1 2 )Oddelek: Novice / Ostala programska oprema | 9832 (8010) | der_Alte |
