Forum » Strojna oprema » SSD in ACHI?
SSD in ACHI?
DrSergioDJ ::
Kako pomembo je, da je v biosu premaknjeno na ACHI namesto IDE?
Matična plošča: Sabertooth p67
Če imam v načinu IDE, mi delajo vsi sata priklopi in posledično vseh 7 diskov, ki so priklopljeni (+ dvd rw).
AS SSD benchmark mi za samsunga 830 256gb pokaze tole:
V primeru, da dam na ACHI, mi dveh diskov zadeva ne najde (najde sicer jih pod disk manage, samo initialize ne dela... :/)
Grem sedaj preklopit še na ACHI in zalepit še tisti screenshot...
DrSergioDJ ::
A kdo pove meni, laiku, kaj v praksi pomeni razlika pri 4K-64Thrd ter score-u?
Na SSD-ju imam OS in programe, vse ostalo je na drugih diskih..
amigo_no1 ::
4k in 4k-64thrd
http://www.myce.com/review/ocz-vertex-4...
AS SSD benchmark also tests 4K threaded performance. This is very exciting, as this test is the first available test that I am aware of, that simulates how a PC operating system actually works. A modern PC and OS, such as Windows Vista/7 does not just run a single thread at a time, it runs many threads. The AS SSD benchmark "4K 64Thrd" tests run 64 threads simultaneously throughout the test. If this result is good, then you can be pretty sure the drive will perform extremely well as a system drive.
DrSergioDJ ::
A ima potem kdo idejo, zakaj mi 2 diskov ne zazna v ACHI mode oz. sta neuporabna...?
SplitCookie ::
Jaz sem imel cirka 100MB manjši read in porazen write
Problem z registrom ?
SplitCookie> Prevoziš RDEČO ! jype> Ja? A to je kaj posebnega?
Ramon dekers> Ječa je lahko naravno okolje potem ko se adaptiraš.
jype> CPP ne spoštujem _NIKOLI_
DrSergioDJ ::
Ne vem, če je problem z registrom (ker se ne spoznam toliko, da bi znal to preverit).
2 diska mi ne najde pravilno - oba sta vidna pod Manage - Computer Management - Storage - Disk Management ampak mi takoj prikaze pojavno okno, v katerem piše:
Initialize disk:
You must initialize a disk before Logical Disk Manager can access it.
Select disks: (na opcijo je samo 1)
Spodaj mi da na izbiro MBR ali GTP. Karkoli izberem, mi napiše "The system cannot find the file specified".
Če bi se dalo zrihtati, da bi mi vsi diski na ACHI delali, bi bilo super...
Initialize disk:
amigo_no1 ::
Bios ju pravilno prepozna ?
Kaj neznanih naprav v device managerju ?
Modela&velikost diskov ?
http://www.asus.com/Motherboards/Intel_...
Kam ju imaš priklopljena ?
Tvoja mb ima 2 različna kontrolerja za sata (Intel P67 in JMicron JMB362).
Intel(R) P67(B3) chipset :
2 x SATA 6Gb/s port(s), brown
4 x SATA 3Gb/s port(s), black
Support Raid 0, 1, 5, 10
Marvell(R) PCIe SATA 6Gb/s controller : *1
2 x SATA 6Gb/s port(s), gray
JMicron(R) JMB362 controller :
1 x Power eSATA 3Gb/s port(s), green
1 x eSATA 3Gb/s port(s), red
- spremenilo: amigo_no1 ()
DrSergioDJ ::
U bistvu ima Intel in Marvell, JMicron je za eSata
Diski so:
5 x Samsung 1TB HD103SJ F3 Spinpoint
1 x Samsung 1,5TB - model napišem zvečer, ko bom doma, ne vem iz glave
1 x SSD Samsung 830 256gb
Bios..če je na AHCI, sploh ne vidim vseh SATA priklopov, le 6 (namesto 8) mi jih kaze (kolikor sem gledal gor in dol po biosu, je vse vklopljeno).
Če premaknem na IDE, moram na SATA Controller 0 in Controller 1 vklopiti funcijo Enhanced, da mi podpira 2 x sata 6gb/s in 2 x Sata 3 gb/s (controller 0) in 2 x sata 3 gb/s (controller 1).
Neznanih naprav v Device managerju ni.
Kam sta priklopljena, ko ju ne vidim, sporočim zvečer.
Diski so:
- spremenilo: DrSergioDJ ()
DrSergioDJ ::
Če pustim na IDE, imam v biosu takole (bios je zadnji za sabertooth p67)
Tu vidim vse diske (pri izbiri boot override-a)
Če premaknem na ACHI, se mi namesto prve slike v tem postu pokaže takole:
V ACHI mode mi Device manager pokaže tole:
DrSergioDJ ::
Evo, preveril še kateri controlerji imajo čez ta dva diska.
Priklopljena sta na Intel P67 Serial ATA 3.0Gb/s. Konektorji so 4-je (po 2 "v paru"), diska sta priklopljena na 1 konektor iz para.
Obstajalo naj bi še tole:
http://knowledge.seagate.com/articles/e...
A čakam na odgovor, če smem to patchati brez backupa oz. podobnega.
DrSergioDJ ::
Velja še omeniti, da na ACHI mode mi pod boot override še vedno kaže vse diske.
Pa v IDE mode mi da opcijo "varne odstranitve" (tam, kjer USB varno odklopiš) za 2 diska (a ne ta, ki ju pod ACHI ne vidim)... na ACHI mode ju tam ni.
nobody?
nobody?
| » | Počasen SSD (strani: 1 2 3 )Oddelek: Pomoč in nasveti | 27352 (2268) | nsa_ag3nt |
| » | SSD in AHCI modeOddelek: Strojna oprema | 7418 (5409) | AC_DC |
| » | nadgradnja računalnika (strani: 1 2 3 )Oddelek: Strojna oprema | 18705 (15303) | Kaj |
| » | Mi lahko nekdo razloži razliko med SATA portiOddelek: Strojna oprema | 3926 (3311) | iloveboobz |
| » | Marvell ali Intel kontrolerOddelek: Pomoč in nasveti | 1673 (1427) | tropinovec |
